Question about Microwave Ovens
My Microwave AEG Micromat 153E doesn't heat or cook the food. All functions are otherwise normal
I live in South Africa and bought a house with this microwave. Followed all instructions in manual but to no avail. Hope you can help. CMJ Kannemeyer
  • Shekar Avadhani May 18, 2014
    Hi Christina Kannemeyer, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?also tell me does microwave makes deep hum while started on?
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Does not heat up
Test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
If it additionally does not spin and no light, then check also the door switch and fuse.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
SOURCE: My Microwave does not heat up or cook...
the microwave oven has been working, but all of a sudden it does not heat up.
Posted on May 02, 2009
heatman101
  • 43501 Answers
SOURCE: aeg micromat duo crunch microwave oven, all
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Nov 12, 2010
Aeg micromat 153e
You rather have a bad turntable motor or a stripped turntable coupling.
Jun 22, 2014 | AEG Microwave Ovens
Sharp convection microwave oven model R1875F. It's cooking on the left side faster then the rest of the oven. It seems to burn on the left side and not cook in the middle.
see the next causes. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 03, 2012 | Sharp R-1870 Convection/Microwave Oven
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 08, 2012 | Sanyo Microwave Ovens
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
Aeg micromat duo crunch microwave oven, all functioning but not heating anything
heatman101
Nov 11, 2010 | GE Microwave Ovens
Not heating up
weve found its not worth repairing microwaves
Jun 29, 2010 | Daewoo KOC-925T Microwave Oven
The Microwave is heating up and appears to function normally. But food is not getting heated or cooked up despite any tempearture and power setting. Even water is not getting heated up and butter not...
If you can't get the food warm or hot, the problem is usually that the magnetron has gone bad. It's an expensive part to replace compared to the price of a new oven.
Jan 04, 2010 | LG Microwave Ovens
MY MICROWAVE DOEST HEAT, IT LOOKS LIKE WORK NORMALY BUT DOESN HEAT
pull your magnetron connector out and clean the both pins with alcohols or a metal cleaner and then fix it again and use. magnetron will work surely.
Oct 03, 2009 | Samsung MW8574W Microwave Oven
Hi. I pressed the 'quickstart' button on my micromat 900 w microwave and used it for 10 seconds. On pressing the 'door open' button, the display panel is showing '1' rather than the cooking time or the...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
It may be a problem with a door switch or door switch mount.
Sep 28, 2008 | AEG Microwave Ovens
Microwave Ovens Logo
50 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
