Question about Sony Playstation 3 40GB System Console
PS3 (playstation 3) screen goes black during gameplay?
It works
but when i play any game the screen goes black for about a minuit then goes to normal again, and keeps repeating it. sound plays during the black bits.
all connections are fine tv works with my pc, xbox and dvd player fine
  • 18 Answers
SOURCE: Games run on hdmi, but not Blu-ray movies
You most likely have the updated drivers. You may have to go and change a setting. I found an answer on the PS3 website that may be of some use to you. I hope this helps you: http://boardsus.playstation.com/playstation/board/message?board.id=ps3&message.id=1662191 From the site: "go to bd/dvd setting and set the "108024hz" option off"
Posted on Aug 19, 2007
  • 3 Answers
SOURCE: xbox 360 flickers across screen
it is your av cable however the components in the cable get a small static boost when u are using your controller so it becomes an intermittent fault ie;....when in game vidios or watching dvds, u rarely use the controller so u dont see the flickering and u only see it when in game play because u are in constant contact with the controlls and the components inside the av cable recieve a small static boost causing the interference.
Posted on Oct 07, 2008
SOURCE: Playstation 3 wont play PS3 Games
Im pretty sure you need to replace the laser
Posted on Nov 17, 2008
  • 77 Answers
SOURCE: XBOX flashes color spots on screen during game play..
it may be your tv, not your 360, check connections, or fix geometric settings (if you live near a fault, or if you have your tv on top a mini fridge.)
Posted on Jan 11, 2009
  • 23 Answers
SOURCE: PS3 freezing during gameplay
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like Freezing up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up
Posted on Apr 09, 2009
Ps3 trips off at specific points during gameplay
well you can check to see if it is overheating, put your hand over the vents, if they are cold then its overheating
Jan 28, 2012 | Sony Playstation 3 (PS3) Console
My ps3 keeps freezing during games
Problem: Your Playstation 3 console is freezing during gameplay. There are usually two problems that would cause your Playstation 3 to freeze during
gameplay. I will start with the most common problem:
1. The Blu Ray Laser is wearing out. This is a common issue among the newer video game consoles. The laser is constantly lighting up to read the discs while you are playing your Playstation 3 whether you are playing games, Blu Ray movies, or DVD movies. Eventually the laser will burn out. As it starts to wear out, first the games or movies will freeze. After a while, it will not read Blu Ray at all. Finally it will quit reading anything. You can find lasers at the following website starting at $49.95. The same website also performs repairs of the Playstation 3 console:
http://store.richspsxparts.com/pl3paac.html
2. Overheating. This is less common. If your PS3 freezes and you shut it off and back on and it comes on ok, it's probably not overheating. If heat is the problem, it will freeze right away if you turn it back on right away without giving it time to cool off. If it turns on OK with no problem and doesn't immediately freeze up, the laser is your issue. If you turn it back on and it freezes right away, your PS3 may be overheating.
If your PS3 is overheating, the best thing to do is to make sure you do not keep it in an enclosed area. Playstation 3 systems and XBox 360 systems run very hot. You must keep it in the open so it gets as much cool air as possible! You can also upgrade the fan inside of your Playstation 3 with the Whisper Fan which increases cooling. You can also find it at the following website:
http://store.richspsxparts.com/newpl3ps3taw.html
Apr 19, 2011 | Sony Playstation 3 (PS3) Console
Hi, when i start my FIFA it loads my trophie collection, then i can choose which language i want. then there comes this screenie from Official licenced product, with Petr Cech in the background. but that...
The game is default to your PS3 Language as default in order to change the Language during gameplay you must change PS3's Language.
Hope this helps.
Apr 18, 2011 | FIFA 11 for PlayStation 3
My game wont play and the home screen is white instead of blue whats wrong
psn is either down or updating.No gameplay whatsoever will not work and trying to play will result in losing that games trophies.Just hang in there.
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
Screen freezes
its broke. take back to store. likely issue with graphic processor overheated one too many times. PS3's are best run in small cramped wooden enclosures that dont allow air in. err no thats not right.... that kills them.
Aug 25, 2009 | Sony PlayStation® 3 (80GB) Console
While playing any game the system locks up and will not continue.
sounds like a laser problem....when they start to go bad they will freeze up during gameplay or during a movie.
Aug 09, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont play ps2 games
ps3 games are not supose 2 play ps2 games
Jul 25, 2009 | Sony Playstation 3 (PS3) Console
My ps3 after in hour of playing freezes and won't play
This is a common problem that can be one or two reasons. One is that your PS3 is overheating during gameplay and is shutting down or freezing. If this is the case you should make sure your ps3 is clean of dust and is in a well insulated area. Try investing in an external fan that will keep your system cool during gameplay.
Secondly you may have a problem with the laser reader. If this is the case you will need to have it repaired by sony. You may be covered under a warranty, so please contact sony to find out your options.
You can contact sony by calling the number listed on the back of almost all of your video game booklets.
Happy Gaming and Good luck to you.
Oct 17, 2008 | Sony Playstation 3 (PS3) Console
Ps3
the console is probably PAL not NTSC
Check in the menu to be able to change the gameplay you might get luck
or
you might need a MOD chip of some sort.
Google it. You can find some good places.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jun 07, 2008 | Sony Playstation 3 (PS3) Console
Open Questions:
Sony Playstation 3 40GB System Console Logo
306 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
