Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
My HLN5065W works great though Directv, but when I play a DVD or VCR tape I get wavy lines in the picture...any idea what that could be? I replaced the analog board to no avail. Could it be the digital board?
  • stu99nelson Jul 14, 2009
    This is a great way to know what problems you are having before you call in a tech! I can now probably fix this myself. Thanks for the quick & accurate responses!!
  • 6,784 Answers
HI. If these lines appear throughout the entire movie or, program and, they span then entire screen, this will confirm A digital Board issue. one or more of the board components are showing signs of failure at this point. it is recommend to replace this failing board in this case.
**NOTE-- IF these lines are vertical, this will confirm Light engine issues but, if these lines are horizontal, this will be the Digital Board.
Posted on Jul 13, 2009
  • Michael Masters
    Michael Masters Jul 13, 2009
    Although I'm sure this is an issue with the digital board, i would like to see a picture of this set in action if possible. you may email this photo to localwonder@aol.com if you wish. this will increase the accuracy of my solution greatly.
  • Michael Masters
    Michael Masters Jul 14, 2009
    Hi. Thanks for the picture. That is defiantly a digital board issue but, just to make sure it isn't a simple lose or, worn cable, check the linking cable between the DMD module and, Digital board. It will look like an DVI cable. if the cord is connected and, in good condition, replace the digital board.
I have certain movies for my grandchildren. There
I assume the picture after viewing your "certain movie" you have a snowy type of picture with sound? This is because your "certain movie" will have a bad section or worn section of tape & is making the heads dirty. Is there a part of the "certain movie" that gives wavy lines or the picture breaks up? If a tape is constantly used it causes the oxide coating of the tape to flake & dirty your heads. You could try a head cleaning tape although these sometimes do not do a thorough clean.
Jul 01, 2009 | Philips Televison & Video
No color and sporatic play on VCR mode, with zv420mw8
If this problem happened within a few seconds, you probably have dirty heads. If It happened slowly you could have an alignment problem. Both of these problems should be repair professionally.
Fuji
Jan 29, 2009 | Philips Magnavox DVD/VCR Dual Player
No picture when playing a VHS tape
Nothing has worked! Talked with a tech on the phone line and she said unit is bad. Everyone seems to have problems with this type of unit period so I am returning it and giving up. Even the responses from others have not proved effective. Lousy product!
Jan 05, 2009 | Philips Magnavox DVD/VCR Dual Player
Panasonic DMR-EZ47V Fuzzy horizontal line in VHS mode
Dirty heads or the recording was from a different brand VCR and the Panasonic cant get the right tracking. Try manual tracking just a little in either direction to you get the right one.
May 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Playback problem on SP Tapes - Top 1/3 of screen wavy lines
there are guide posts that the tape goes around, they need to be adjusted if your good at that stuff take off cover and while playing tape be careful you could damage video head.with flat srew drive . adjust right post buy turning clockwise or counter clockwise. this could be hard i hope i helped , When i first started ny video shop 1987 we started doing only vcrs.
The video head also could be bad. thanks doctor video
May 04, 2008 | Sony SLV-D350P DVD Player/VCR
Vizio liquid crystal tv l32hdtv
Check the cable connections and/or replace the cables to the AV2 input.
If replacing the cable doesn't provide a solution, try running your DVD through the input. Since it works fine now, you would be checking the input AV2 by putting your working DVD. If the DVD plays with no problems, the input is fine.
Also try the VCR using coax into the TV instead of RCA into AV2. This will give you some idea about the condition of the VCR.
I suspect either the VCR or the cables.
Apr 22, 2008 | Vizio L32 32 in. LCD HDTV
Philips DVP 3150V
saida horizontal com deficiencia faz com que a fonte aciona circuito de proteção.
Feb 09, 2008 | Philips CCB092AT 9 in. TV/VCR Combo
Video Tape picture shakes horizontally
needs tape path alignment or cleaning done
Jan 15, 2008 | Philips DVDR3320 DVD Recorder/VCR
Used a wet VHS cleaner and now my VCR doesn't work right. Help!!
The VHS cleaning cassette possibly deposited fiber in the heads in the drum. You may need to open the cabin and examine the heads and the mechanism for foreign matterial.
Feb 02, 2007 | Proscan PSVR72 VHS VCR
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
48 people viewed this question
Jerry Greenberg
Jerry Greenberg
