Question about RTO Sole F80 Treadmill
Wattage of sole f80 - RTO Sole F80 Treadmill
5 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: belt wont start on a brand new Sole F80. Motor
It sound like the motor control board is the culprit. Unplug unit then remove shroud then find the 2 leads that connects the motor to the motor control board disconnect them then plug in unit and see if the display blackout after programing the display then hitting start.
Posted on Mar 13, 2010
  • 33 Answers
SOURCE: I have a sole f80
hai , check communication cable, speed sensor
Posted on Dec 10, 2011
ercupa190
  • 12223 Answers
SOURCE: My Sole F80 deck bounces excessivly when not at an incline.
1) Lube the deck belt, this problem is lack of maintenance, maybe the deck belt is worn.
2) You must align the deck belt see the diagram
3) Lube the rollers bearing very well very important too
see the video: God bless you
Posted on May 15, 2012
ercupa190
  • 12223 Answers
SOURCE: my fans on my brand new sole f80 dont come on
1( test the voltage at the terminal of the FAN, if there are the FAN is faulty.
2( test the voltage at the terminal , if there are NOT TEST why NOT coming voltage to the terminal.
3( follow any wires or plug or connector or loose wires, and TIGHT VERY WELL.
4( test FUSE or c. breaker and replace or reset.
5( Try again, and fix it. See the block diagram attached.
However RUN the software caibration for easy diagnostic, troubleshooting, and fix it quickly.
God bless you
Posted on Oct 02, 2012
How to reset F80?
see the video attached.
Apr 01, 2013 | RTO Sole F80 Treadmill
Sole f80 stuck elevation
LUBE the gear and shaft motor
2) test the input voltage motor, see the diagram attached, if there are the motor need repair.
3)see if there are some relais, and clean for dirty, oxide, or coil. open and replace.
see the block diagram
Run the software calibration for easy diagnose, and troubleshooting.
God bless you
Nov 23, 2012 | Fitness Giant Sole Fitness F80 Folding...
My fans dont come on, on my brand new sole f80 treadmill
1( test the voltage to the terminal , if there are voltage the FAN is faulty, change it.
2( if there are NOT voltage to the terminal FAN, test the line why are NOT coming voltage, test some fuse, or c. breaker, tight any plug, connector, or loose wires.
3( Try again.
see the block di attached. and fix it.
God bless you
Oct 01, 2012 | Sole Fitness Sole F80 Treadmill 2011 Model...
My fans on my brand new sole f80 dont come on
God bless you
Oct 01, 2012 | RTO Sole F80 Treadmill
My control panel on the Sole F80 Treadmill lights up but nothing I press works
adjust the REED SWITCH, see the diagram attached, clean it and tight the wires connector very well.
tight the ribbon cables insides from keypads +tight the wires connector from display board vs lower board and clean it.
God bless you
Jul 22, 2012 | RTO Sole F80 Treadmill
May 15, 2012 | RTO Sole F80 Treadmill
Error code of ls1 on sole f80 treadmill
John what are you talking about. All that's gonna do is give a LS error is you disconnect the motor.
Aug 22, 2010 | RTO Sole F80 Treadmill
Belt wont start on a brand new Sole F80. Motor
Mar 12, 2010 | RTO Sole F80 Treadmill
RTO Sole F80 Treadmill Logo
80 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
