Question about Hunter 52" Ceiling Fan With Light And Remote Control
I bought a house with hunter remote control 52" fans, and one doesn't work, I replaced the battery and still doesn't work. How can I verify the remote code is correct for this fan? The code on the fan is 1005 and the remote has jummper pins 1-4.
  • 10,865 Answers
Set the remote to match the fan code. be sure you have a good battery in the remote and in thereceiver which is in the dish at the ceiling holding the electrical wires
Posted on Jun 23, 2009
How can I replace the receiver on hunter tribeca ceiling fan
The black & white on one end go to the house wiring. The other three go to the fan wiring. Black to black, white to white & connect last two wires together.
Aug 17, 2014 | Hunter 52" Ceiling Fan With Light And...
Fan only runs on slow speed
The receiver in the fan housing may have failed.
Apr 20, 2017 | Hunter Dryers
I bought a house 5 years ago with a Hunter fan installed with a remote control. It has model 84757 on back of fan and it stopped working so I just changed the wall on/off switch which was broken. Now the...
Replacing the batteries (2) should solve the problem. There batteries in the handheld remote and batteries in the receiver inside the fan's cowling. When installing the batteries, be sure they are facing the proper direction. If they aren't the remote will not work. Also, keep in mind, the wall switch must be ON when using the remote control.
Hope this helped you.
Jul 19, 2011 | Hunter Heating & Cooling
Hunter ceiling fan 52 ",
Hey dale. Sounds like either the integrated remote pack inside the fan housing might be bad, or the reversal switch part. If it has a switch on the fan housing to change it from forward and reverse, you could try going to a hardware store and replacing that switch. If that doesn't work, then it is probably a bad remote receiver pack iside the fan, it will be a bigger, probably black little box. If this is the case, your better off getting a new fan, as it will cost about the same. If your fan doesn't have a little switch to change blade direction, 9 out of 10 times it is the receiver pack. If your fan does have a switch for fan direction, there is a good chance it is a bad switch. It could also be both. After 10 years with the fan, you might seriously want to consider purchasing a new fan.
May 17, 2011 | Hunter Ceiling Fan Remote Receiver...
I dropped my remote and now it won't work. I changed the battery, didn't' work. I bought a universal Hunter Remote that the guys at Lowe's told me would work, didn't work. I called Hunter, she said I...
There should be a series of little jumper switches (usually 4 white I think) inside the remote that should match the fan. sometimes you can get to from the battery cover, sometimes you have to unscrew the remote case. The instructions should mention this. Not sure if the fan itself has switches, or just hard set. Either way that's only 16 combinations to try.
Sep 20, 2010 | Hunter 52" Ceiling Fan With Light And...
Light won't work on hunter fan with wireless remote
probably your lights are blown replace them.good luck.
Feb 28, 2010 | Hunter 27187 Remote Control
My hunter fan remote control is not working
First of all you should check & ensure the infrared is emiting from the remote control. Though we cant see this infared beam with bare eyes, i found a trick to do so in http://www.unique-stuff.co.cc/fixing_remote_control_check_infrared.html Most of the problems is weakened infared beam. Replace the batteries when needed.
Dec 22, 2009 | Hunter 52" Ceiling Fan With Light And...
Hunter Fan - Remote
Most likely the fan turns on with a wall switch and then as long as the power is there [ wall switch left in on position], the remote works
Apr 26, 2009 | Universal Remote Control Hampton Bay...
Dryers Logo
586 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
