Question about Black & Decker Blenders
Blender 5901 won't work - Black & Decker Blenders
Why won't the blades turn?
One or both of the drivers are broken, check the clutch on the top of the motor and the other one on the bottom of the beaker. You will find something there worn out or broken.
May 24, 2015 | Blenders
Magic bullet
Blenders usually have some sort of interlock that prevents power from being turned on if the container is not locked in place. This could be the reason for the problem
Apr 25, 2013 | Emson Magic Bullet Express Blender
Ginny's blender lights keep flashing
you have to have the top part on before you turn on the blender
Sep 09, 2012 | Blenders
Blender overheated
If it won't run once it has cooled down, you have probably cooked the electric motor, which is not worth trying to fix.
If you have some time to poke around, it is vaguely possible that a switch has burnt out, which can be fixed/cleaned. Another longshot is a burnt out fuse, but I doubt it has one.
Jul 22, 2012 | Oster Fusion 7-Speed Food...
I have a Waring BB185 Blender and the blender jar won't properly fit on the blender clutch. I think the clutch on the blender is somehow bent? Is the repairable? Thanks!
Hello, wendy
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about blenders andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances5.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Sep 02, 2011 | Waring BB185 Work Top Blender
My blender is leaking slightly from underneath the blade. Is there a way to tighten the blade coupling?
I am guessing you have a KSB52. If the leak is through the blade spindle then tightening won't help. The "wingnut" is tightened through use anyway. The most likely cause is a failed seal. The whole blade unit will need replacing, search Amazon for 9704291
May 04, 2011 | KitchenAid KSB560 5 Speed Blender
Blender has power but won"t turn on
Hello and Welcome to FixYa!
Well the mal-function can be due to numerous reasons. You need to choke out each possibility one by one.
Loose Connections ( Check for all the connections to the circuitry and motor). Bad Starter Button ( Check for the button switching using a Multi meter). Bad Motor Winding (Motor bushes or winding can be the bottle neck).
Check for the quoted possibilities and you'll soon find one good reason for the mal-function.. Feel free to ask anything regarding the trouble.
Concerned.
Feb 25, 2011 | Waring 7011S / 7011G Commercial Work Top...
My kitchenaid blender does not whizz around when it is put together> the couplking spins when the glass part is off that is, when it has nothing on it> the coupling does not look used or...
There are really only two reasons why the blades won't spin, either the coupler is broken, or the blade unit is damaged. Check the picture of the blade unit here: Check pictures of the coupler here: Hopefully it should be obvious whether the coupler is ok, if it is, are both wings on the wingnut under the blade unit?
Feb 16, 2011 | KitchenAid KSB3 Classic Work Top Blender
BIBC1030 Blender: I won the Wolfgang Puck Immersion Blender/Chopper ...
Replacement parts for Wolfgang Puck Immersion Blenders are available here:
http://www.wpcookware.com/categories.asp?cat=26
If you do not see the model number for your product or parts are not shown, suggest you contact their Customer service at 1-800-275-8273 to determine if the required replacement part is available for your model. Alternatively try making an inquiry via their webform:
http://www.wpcookware.com/contact.asp
May 16, 2010 | Wolfgang Puck BIBC1030 Blender
Blenders Logo
Top Black & Decker Blenders Experts
john h
Are you a Black & Decker Blender Expert? Answer questions, earn points and help others
