Question about Greenlee 5715 Gas Lamp Tester New
How to use discharge lamp tester Beha lt277 - Greenlee 5715 Gas Lamp Tester New
2 Suggested Answers
  • 308 Answers
SOURCE: where can I download a manual for a BEHA/Greenlee
http://65.36.183.19/greenlee/im/IM1056.pdf
Here is the manual for the tester.
Hope this helps
Posted on Nov 17, 2010
How do I discharge a JVC hd-56g886 TV to change out the lamp
no need to discharge any thing just un plug tv pull out lamp assy. and replace clean dust out of the air filter and any whear else turn on and reset lamp timer in menu good luck ,butler
Oct 02, 2016 | JVC Televison & Video
Change headlamp
Check for power at headlamp socket with tester. If no power, check fuses. If power but still no lamp check ground wire connection with tester. If all check out you have a bad lamp bulb.
Dec 03, 2014 | Kia Optima Cars & Trucks
94 Mercury Cougar 4.6L Int Lamps 10Amp fuse blows
replace the door jamb light button, it's probably bent therefore not pushing in when door is shut, and when door is shut it grounds out, and it wld'nt effect the dome light because it's in the circuit befor the dome if this is the case and you find it's bent or crimped try to bend it back out,
Aug 25, 2012 | 1994 Mercury Cougar
My 12 horse brigs and straton riding mower keeps discharging its self what do i do
"testing" with a fog lamp wont prove anything other than charge state! You need a load tester!
Check the fluid level inside the battery, Your starter may be going bad.
May 26, 2012 | Garden
How to use a continuity tester
The most basic continuity tester (or test light or toner) are often said to provide a simple "go" or "no go" type indication (you'll see below that this is not entirely true). They usually are self powered by a battery, and have two probes to make contact with the circuit, component, wire, etc. under test.
Continuity testers are used on dead or un-powered circuits only. Likewise, they need to be tested prior to use to make sure that the battery, lamp, etc. are in good working order. Testing is done simply by touching the probes together. When connected to each other, note the intensity of the indicator - whether it is a lamp, audible alert or other indication. This is your 100% continuity reference indication.
If there is a complete path or circuit between the probes on the tester, an indication will be given. This could be brightly lit lamp, tone or buzz sound from a speaker, etc. A circuit with only fair or poor continuity may provide a dimly lit lamp or a "sick" sounding buzzer. Keep in mind that some items under test may have very poor continuity - say 20% or 30% or other unknown value that will not be sufficient to provide an indication - but will still conduct. This should alert you that a continuity tester really isn't a "no go" indicator. This is important to remember. This is where an Ohm meter shines when compared to a simple continuity tester. It will pinpoint just how much continuity there is in a circuit.
I hope this helps!
May 12, 2012 | Measuring Tools & Sensors
Ok, is there a trick to a 925ABD lamp socket, turn key, 3 way switch to make it work if it stops or do you need to replace it? Chick doing her own honey-do list. Thanks!
yes,easiest is the total replacement. its simple if you have any kinda of continuity tester , you can get at radio shack for about 12 bucks,and the socket for about 3 dollars.remove the socket with a small screwdriver ,unplug first.check new socket with the tester by putting the tester to ohms mode,to make sure you are doing correct put the 2 leads together meter will show a dead short.you want to connect the hot lead to the base of the socket and the white or nuetral lead to the shell or side of the socket. using the tester to make sure put one lead of the tester on the screw that connects the wire and the base of the socket,the tester will show a dead short thats your hot lead
Jul 02, 2011 | Cooper Industries 925ABD lamp socket, turn...
Slow battery drain on my 2000 GMC jimmy. tried to clip the vanity lights on sunshade. could this be the problem? is there a fuse or a different way to make sure these are shut off and not draining the...
Easiest way to find the drain is to perform a parasitic draw test. Put a voltmeter in-line with the ground side of the negative battery lead and terminal post. Then disconnect your vanity lamps and see if the voltage drastically goes down. If not, you can start to disconnect things, like trunk lamps, dome lamps, fuses, etc. to see if they make a difference. The easier way, remove the vanity lamps and start vehicle for a couple weeks and see if problem goes away. Another thing is to check the battery, sometimes the battery can be weak and lose its charge. Surface discharge and corrosion at battery terminals and battery surface can also cause this, clean all terminals and battery surface if you think this could be a problem.
Nov 29, 2010 | 2000 GMC Jimmy
If I am trying to find the 'hotwire' for lights how do I do that? Do I touch 1 wire and the junction box then the other and the junction box and whichever lights the instrument that is the hot wire?
Test for hot wire:
By code, hot wire should be black.
Take photo of wiring so everything can be put back.
Remove wires from device.
Separate wires for testing.
Use ordinary tester.
Test each wire to bare ground wire.
Tester lights up on hot wire.
Now test for neutral wire.
You know hot wire.
Test each hot wire to other wires (except bare ground)
Tester lights up on neutral.
If you do not have a tester, take ordinary wall lamp.
Plug on wall lamp has 2 prongs.
Prongs should have a hole.
Spread prongs apart.
Wrap bare copper wire into hole on prong1.
Turn on power.
Test prong2 to each wire.
Light comes on when prong2 touches hot wire
Nov 22, 2010 | Sperry Instruments HST401 Voltage...
Greenlee 5715 Gas Lamp Tester New Logo
106 people viewed this question
Top Greenlee Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Greenlee Measuring Tool and Sensor Expert? Answer questions, earn points and help others
