Question about Garden
Maxtra gr 007 five horse power four stroke engine rotavator
4 Suggested Answers
  • 137 Answers
SOURCE: explain the four stroke cycleof a three cylinder
It is the same as any other engine no matter how many cylinders there are. . A 4 stroke engine has the intake stroke then compression then ignition then exhaust.(piston goes down for intake stroke,then up for compression then it fires the fuel air mixture from the intake stroke and that pushes the piston back down and on its way back up the exhaust valve opens for the exhaust stroke)
Posted on Nov 18, 2009
sisadsl
  • 1508 Answers
SOURCE: describe the differance between two stroke and fou...
two strokes fire every time the piston gets to the top ( every two strokes of the piston, down, up)and the fuel in and exhaust out is controlled by holes in the barrel called ports, they need oil mixed with the petrol to lubricate the piston and engine bearings.
Four stokes fire every second time the piston gets to the top( or every fouth stroke of the piston, down, up down ,up) the fuel and exhaust are controlled by valves that are pushed open by the cam, oil is pumped from the sump to the top of the motor and to the bearings for lubrication
Posted on May 21, 2010
  • 51127 Answers
SOURCE: Where is the thermostat in a 2008 Mercury for stroke outboard 20 horse
in the head of course .
Posted on Mar 03, 2016
The tines are not moving forward on my Rotavator. The engine is Tecumsah Vantage 50. The tines move backwards and the engine seems fine. The rotavator will not move forward
I have seen a number of domestic rotavators but haven't yet seen one with a reverse gear. You didn't make it clear in your description whether yours has a reverse gear and that is all that is working or whether it usually only moves forward but is moving backwards?
While it is theoretically possible for a 2-stroke engine to run backwards, your engine is a 4-stroke that is incapable of running backwards and so it would seem the gear selector is stuck if it has one or someone has carried out repair work and made a mistake or something else is broken.
The only thing that comes to mind is some of the older designs used an over-long drive belt that crossed in the middle like a figure eight in order to reverse the driven pulley and replaced the belt with one that seemed the right size would cause the machine to run backwards.
More information needed, perhaps...
Jul 24, 2016 | Garden
What does the 5hp mean
it is how much power the motor has. In the old days people travelled on horses . One horse produced one horse power. So if you had a buggy with 5 horses attached to it you had a five horse power buggy. So your schredder engine has the equivalent power produced by five horses.
https://en.wikipedia.org/wiki/Horsepower
Jun 29, 2015 | Troy-Bilt Heavy Machinery
Need Parts
For the pole saw parts go to the link Pole Saw
Apr 22, 2014 | Maxtra Trimmer 30cc 2-stroke Gas Pole Saw...
Parts
this pole breaks because the gear inside is made of puter and when it gets warm enough it melts or breaks the teeth the only solution is to take it out and find some place that makes them to replace it
Maxtra long pole hedge trimmer has bolt with stripped thread.
same thing happened to me, I had to make another one there made of some kind of puter
Apr 07, 2014 | Maxtra Trimmer 30cc 2-stroke Gas Pole Saw...
What type of oil does a pp420 briggs and stratton lawnmower use,thanks,kev.
10W30 or SAE 30 oil is fine for four stroke engines up to about 4 HP. For higher horse powers a more viscous oil is normally used like 10W40 or 15W40
Have a look at this video for details on checking oil levels and type:
http://www.briggsandstratton.com/engines/videos/Maintenance%20Repairs/Checking%20The%20Oil%20In%20Your%20Briggs%20and%20Stratton%20Engine/
and this webpage:
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/Engine%20Oil%20Recommendations/
Sep 03, 2011 | Briggs & Stratton Garden
My bike wont go any faster than fifty five miles an hour
That is about right. 125 cc four stroke engines do not make enough power to exceed that speed.
Jun 09, 2011 | 2000 Suzuki DR 125 SE
Points replacement on a flymo rotavator with a ducati engine
you can replace the points take the points out & take them to a local small engines shop the might be able to match them up with new ones
Jun 08, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
