I have been my qsc for 5 year now its starting to loss its nomol power what could be the problem
  • 3,368 Answers
If the input levels are the same then the amp is starting to fail.
Posted on Nov 27, 2014
Qsc usa 900 power amplifier coming on but no signal.what can be the problem.I check all outputs
Are you then saying you have no sound, yet the amp is on? If so, with the unit off, listen carefully to the top of the amp. When you first push the power button, you should hear one click, followed by another click, about 5-20 seconds later. I'm guessing you hear the first click, but not the second. Is that correct? If this is correct, and you are interested in having your QSC repaired, Please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Jan 22, 2015 | QSC Audio Players & Recorders
Lost power
might be the fuse or its power supply board faulty. check and confirm, if the power supply unit is faulty talk to qsc the have replacement modules as repair might give you hard time.
Apr 15, 2014 | QSC K12 Powered Speaker Package
Qsc hpr153i rattle
Please specify a bit more, does the rattle is physical(Enclosure structure) or electronically hear thru speaker(Power Amp Common Issue)? I have the solution for the amp issue, let me know.
Mar 20, 2013 | QSC Audio Products QSC HPR153I 12 SPEAKER
Not putting out sound fan on light on
A common issue with the QSC RMX series amp is faulty volume pots, so i would recommend go this way first of all, let me know a bit more to improve help.
Feb 04, 2013 | QSC Audio Products QSC RMX 850 RMX850...
Qsc hpr181i blow fuse
Two possibilities here, one is a cracked pin on one of the power supply UF diodes and the other one that the power output devices got fried.
Jan 30, 2013 | QSC Audio Products QSC HPR 181i
My QSC PLX 2502 amp completely blew. Channel 1 has been giving me problems for a year and I have had the amp about 3 years. This past week it drove into the red so much and I could not stop it. Well now...
You should NOT drive the amplifier into the clipping mode continuously. There is a possibility that you have fried your speakers or that they are the real problem. You haven't told us what you were driving, however this amp will deliver 450 Watts per side RMS at 8 ohms which means your speakers have to be rated at least that much RMS power for continuous. When speaker voice coils fry, they can wipe out amplifiers. Let us know what speakers you are using and how they are configured. This amp is going to be expensive to repair I can tell by looking at the schematic: Here is the schematic:
http://elektrotanya.com/qsc_plx2502.pdf/download.html
Scroll down to "get manual" and click to download it. IGNORE other download links.
This amp has circuits to boost the power supplies to the amps to handle the peaks. It is rather complex but the schematics are complete and have good explanations... some of the best I have seen. There are going to be a lot of destroyed components and great care has to be used after repair to "cold start" the unit to make sure nothing else is bad or it will blow up again. Most people do NOT have trouble with the QSC amps... so do tell me what speakers you are using and how they are configured so we can verify the design is correct. This amp is rated for 8 ohms so USUALLY only ONE speaker can be connected per side... and finding an 8 ohm speaker that can take 450 watts continuous RMS isn't easy. People fall for the advertising claiming "Peak" and "Program" power which are FAKE advertising... ONLY use continuous RMS power when sizing amps and speakers. There are MANY ways to cook out equipment... One is to boost the bass or the treble way up. Another is to NOT use balanced interconnect lines between mixers and your amps. Yet another is to NOT power ALL interconnected equipment from a single receptacle or power conditioning module. Please describe your setup further so I can help you more!
Sep 20, 2011 | Qsc Plx-2502 450w Per-Ch. 8 Ohms Amplifr...
MAckie 1604 VLZ Pro Mixer, running QSC 1850 with jbl's from main outs. I would like to hook up powered subwoofers. What is the correct pathway? kenshireman@msn.com
The best way is to use a two-way crossover between the mixer and the amplifiers. In your case, the low output from teh crossover would go to the powered subs, the highs to the QSC. Use the crossover adjustment to set the frequency crossover point to get the sound quality you require.
Dan
Mackie 1604 ---> Crossover --- Highs ---> QSC --->Speakers
-----> Crossover --- Lows ---> Powered Subs.
Jan 27, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
Quiet Amp
sounds like you need a preamp. i would need more info to be sure. good luck
Feb 11, 2010 | QSC CX302 2-Channel Amplifier
QSC ISA 280 Stereo Power Amp stopped working
This is a very precise questions as QSC amp are pretty rare and high end electronics equipment. There is no way getting an answer other than getting the amp at a sound shop for repair, wich might go for a visit at QSC anyway. From a sound shop repairman...
Sep 07, 2009 | QSC ISA 300Ti Amplifier
 Grubhead
Grubhead
