When I turn the air conditioning on at the thermostat nothing works
2 Suggested Answers
SOURCE: My Thermostat is flashing "L6"
The battery needs replacing.
Posted on Oct 18, 2008
What will make the heater in my car just stop working?
Do you mean that colds iris blowing out or that the lower is not working? Check fuses first. May also be time for a new thermostat.
Jan 23, 2015 | Air Conditioning and Heat for GMC Yukon
Air not working
you have a 24 volt problem or you need batteries in your thermostat
Sep 03, 2014 | Heating & Cooling
Home air condition thermostat is blank. My home's central air condition stopped working. So the first thing I did was check the thermostat and it was blank. I then went down to the basement and got the...
Put new batteries in the thermostat. Make sure that the switch that power the furnace is in the "on" position. Sometimes people mistake that switch for a light switch and turn it off.
May 23, 2014 | Heating & Cooling
What does -AC on honeywell chronotherm III thermostat mean?
AC means "air conditioning." If the AC icon is showing on your thermostat it means that your air conditioning is activated and should come on when the temperature threshold you've set on the thermostat is reached.
For example, if you've set the temperature level to 78 degrees, when the house temperature goes above 78, usually by about two degrees, the air conditioner should cycle on to cool it back down to 78 degrees at which point it will then turn off.
This information should be in your air conditioning/heating system or thermostat owners manual. If you don't have the manual, you should contact your air conditioning dealer or your builder to secure a replacement. The manual is essential for proper operation and maintenance of your system.
May 14, 2014 | Heating & Cooling
Thermostat?
Thermostat is for engine coolant temp,
nothing to do with air conditioning
You need a shop to diagnose the a/c
system
Jun 29, 2013 | Air Conditioning and Heat for Saturn...
Heat is working
Hmm... so is the heat running at the same time as the air conditioning or did you mean to say heat is not working? I could probably help you but I need more specific wording of your problem.
However if you just posted to say that your heat is working, then I say congrats cause its cold out there tonight. j/k.
Try to describe what happens when you turn on the thermostat, like does the blower come on and it just blows cold air or nothing happens at all or thermostat doesnt work ect. ect.
I'll be on for a little bit tonight if not I will check back for you in the morning. :)
Feb 01, 2013 | Goodman CLQ36AR49 Air Conditioner
Dometic air & analog thermostat control kit
Had one doing similar recently, and after a thunder & lightning storm. Nothing worked, but kept blowing 2 amp fuse in thermostat, when anything tried, heat or cool. Pulled plastic control box down from inside upper unit (AC) made sure breaker was off, took of plastic cover and smelled inside, and could smell burnt plastic smell. Replaced, control box, that got fan only working. Tried another thermostat , everything worked as it should. Turns out the lightning, or power surge, or whatever, shorted out the thermostat, and control box at same time.
Aug 03, 2008 | Dometic Rooftop RV Air Conditioner
Our air conditioning was working during the day. when one family member turned the air up from 72 to 75 she saw the screen process what she wanted and walked away. when another family member went to turn...
open the thermostat and look for batteries, 3 AA
http://www.heater-home.com/photos/2129-5b.jpg
http://www.heater-home.com/manuals/th8321u1006manual.pdf
Jun 13, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
