Question about Ricoh Aficio 3025 All-In-One Laser Printer
Ricoh sp3510 cartridge required error
    Champion:
  • Ricoh Expert
  • 208 Answers
As in a toner empty error? Otherwise, it needs a new PCU.
Posted on Jan 02, 2015
Ricoh Irregular Toner error message Toner levels appear OK, reseated the cartridges, but same error.
Take the toner cartridge out and shake it vigorously. The toner level inside may be getting low so shaking it distributes what's left.
Sep 14, 2017 | Ricoh Office Equipment & Supplies
Printer Ricoh sp 210SU "service call error SC491". using compatable cartridge instead of Ricoh original. Service centre suggests to change the cartridge to solve the issue. any idea else pl share me
SC491 on a Ricoh SP 210SU is a code for bias leak.
The machine detects that a bias leak has occured from the drum charge, development charge or transfer charge.
PWM signals are sampled at 20 msec. intervals. This SC is issued if 10 PWM samplings within 200 msec. are abnormal.
• HVPS (high voltage power supply) harness loose, broken, defective
• HVPS board defective
• AIO terminal defective (the terminal for the toner cartridge)
• Cycle the machine off/on
• Check all the harness connections of the HVPS
• Check spring-loaded AIO terminal installation behind the HVPS.
• Replace HVPS.
Usually this error is related to the cartridge. Some manufacturers of compatible cartridges will replace the cartridge with a new one.
At least they should give a discount based on how many pages that was printed before it failed.
I have not seen this problem with a new genuine Ricoh cartridge.
It is important that the cartridge is not refilled more then 3 times. There is no counter on this, and companies that refill cartridges they collect (with unknown number of cartridges) may have problems quite often.
May 11, 2017 | Ricoh Office Equipment & Supplies
How to reset replacement required print cartridge ricoh sp 3510/3500
"Replace Print Cartridge" remains in
display. Then a new AIO cartridge must
be installed. This feature is a safety
measure to prevent the used toner tank
from becoming full (there is no toner
overflow detection mechanism).
Dec 05, 2015 | Ricoh Aficio Sp 3510sf All-In-One Laser...
Add toner see instructions in front cover to replace toner
Hi
You say you have checked the toner and there is "enough inside", I don't know how you can check this and the error suggests that the cartridge needs replacing. Have you tried a new cartridge ? This is the first step.
Is the cartridge you get the error with a Ricoh cartridge or a compatible. If compatible this could be the cause of your error.
Cheers
Dec 06, 2014 | Ricoh Aficio mp2000 Copier Machine
Ricoh sp3510 sc542
This is the correct solution to resolving SC542 error on a Ricoh SP3410 SF and SP3510SF:
Press Clear/Stop button once and then press 1 0 7 and then the Start button to enter the "Engine Maintenance" in Maintenance Mode. Select "Fuser SC Reset" and execute..press ok. Turn main power on and off. Issue will be resolved.
Mar 16, 2014 | Ricoh Aficio SP3410SF Laser Print
Ricoh CL2000 SC486
it is the problem your cartridge sensor chip.You change cartridge unite & buy new cartridge than solve it
May 30, 2009 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio 450
Its coming from your finisher. Its a stapler error. Make sure the cartridge is in all the way. If you open the door make sure it is parked in the home position for you to access it.
If you changed the cartridge recently, make sure it is inserted all the way.
Jul 17, 2008 | Ricoh Aficio 450 Copier
Add Black Toner Msg.
Try taking out the cartridge and reinstalling it. Was this a original ricoh toner cartridge or a el cheapo cartridge off the internet?
Mar 19, 2008 | Ricoh Aficio CL2000 Laser Printer
Ricoh error code sc291
There's a list of Ricoh error codes right here: http://www.tecnodigitale.com/riparazioni/pdf/Codici_errore_Ricoh.pdf but it doesn't indicate an sc291 for the 3800 or for any other model for that matter.
There are usually contacts on the cartridge that interface with a reader in the printer to detect the chip in the cartridge. Examine a cartridge and look for any electrical contacts, make sure they don't look damaged or dirty clean them with 98% isopropyl alcohol. With the printer powered off and upplugged, try to find the corresponding contacts inside the printer for each of the contacts on the cartridge, clean those too.
If that doesn't change, try a different cyan cartridge, if that still doesn't work you will probably have to get the machine serviced.
Jan 14, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio 3025 All-In-One Laser Printer Logo
62 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
