Question about OKI Office Equipment & Supplies
How to fixoki c301cn error 545 ? 546 547 making a grinding noise when starting improper cartridge lock position
SOURCE: Error code 5100 on my Pixma iP6600D.
I had the exact problem described and it was the following:
one of the ink cartidges had popped out of place "inside" the printer housing on the right hand side, and was catching as the printer tried to start up.
By using a thin object such as a ruler, I could press the ink cartridge back into place to allow the ink cartidges to come out from the printer side area. Once out I properly reseated the ink and all seems fine.
Posted on Sep 04, 2008
  • 67 Answers
SOURCE: Cannon MP830 Printer cartridge jam
So you cant get the ink tanks in place properly?
Have you tried this method to ensure they're properly seated? Is the printer on or off when you try to seat the tanks?
Refer to the following steps to verify the ink tanks are seated correctly:
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  3. Open the inner cover.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press down on the ink tank until a click is heard, thereby making sure the ink tank is seated properly.
    Note:
    Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
  5. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note:
    Ink Tank Lamp
    You can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  6. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Posted on Apr 04, 2009
SOURCE: cartridge jammed grinding noise
I just did a cleaning.
Posted on Apr 29, 2009
aicaxz
  • 511 Answers
SOURCE: HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
Posted on May 29, 2009
spiceprince
  • 31 Answers
SOURCE: My HP pinter makes a grinding noise when printing,
Clean Both the colour cartridges and black cartridge as well
Posted on Jul 24, 2009
2009 hyundai sonata ,makes a grinding noise when starts, and it will start while the key is on the , on position it doesnt have to be in start position to start.it also grinds when i go from drive to park....
my 2009 Hyundai Sonata was making a grinding noise like the starter was locking up i would move the key a little back and noise will go away everyone i brought the car to said it was the starter except one mechanic said its a starter relay switch on the ignition so i took his word on it and paid $100.00 the problem is fix so before you spend over 300.00 for a starter ask about this most mechanic will say if it not the problem he will credit the $100.00 towards the repair of the starter
Sep 08, 2013 | 1999 Mercury Cougar
Grinding noise
could be the laser unit on top of the printer out of whack -i have the same fault also
Jun 29, 2012 | Lexmark E120n Laser Printer
In the maintenance section Inkjet Cartridge Repacement does not work. The cartridge does not move into position to be replaced.
Hi!
Does it make a grinding noise when you change the button to replace the ink? As if it is trying to move the cartridge holder to a position where you can replace the ink?
If the cartridge holder has like a lock to keep the ink cartridges in place, try to use a flat object that you may insert to push it down.
One or two things- you may have not close that ink latch properly so it won't move, or the mechanism for printer is damaged.
Thanks for your time and using Fixya Online Support. Cheers!
Jan 02, 2011 | Epson Stylus Photo R300 InkJet Printer
How do I get my HP 5610 All-in-One Printer back online? Also, the display window on the printer is saying "Cartridge Error: Refer to device documentation to troubleshoot". When I looked into the owner's...
Try reinstalling the cartridge. Also listen carefully to the cartridge assembly movement. If you hear any grinding type noises your cartridge is reaching the proper home position. This will cause a cartridge error. If there is any grinding noise you may be in for a long task of realigning your cartridge position to its proper spot. Make sure that the position of the assembly is dead center when you reinstall the cartridge. If it is not move it the center as a starting point. Keep at this moving the assembly in either direction until you no longer hear grinding as the assembly attempts to find its home position. Good luck! Be patient. It may also help to completely unplug the printer for 30 seconds between adjustment attempts.
Nov 03, 2009 | HP Officejet 5610 All-In-One InkJet...
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
I have seversal problems -- The Scanner Lock is on and I can't figure out how to turn it off. Now I can't copy or fax. The machine makes a grinding noise when I turn it on. I think this started after...
The lock is a slide switch next to the large glass when you open the top cover, when it is locked the scanner can't move and makes a grinding noise. It's easy to bump into the locked position and easy to unlock.
Sep 02, 2009 | Samsung CLX-3160 All-In-One Laser Printer
May 29, 2009 | HP Office Equipment & Supplies
Horrible grinding noise
The problem sounds like a broken or stripped gear in the printer. If the unit is under warranty I would contact the authorized repair station for that printer in your local area.
Nov 10, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Printer makes noise while cleaning heads
Grinding noise is most likely caused by the carriage lock getting stuck and holding the print head at the home position. The noise is caused by the toothed belt that pulls the head back and forth, skipping over the splines on the motor drive wheel. If you have been able to print since the problem occurred, chances are that it has freed itself up and will be fine. Regarding the loss of cyan & magenta output, follow the solution given in my previous posts to complete a manual under-head cleaning cycle. This should get you going. Check this previous post for cleaning info: http://www.fixya.com/support/t137335-problem_print_outs_from_printer
Jul 05, 2007 | Epson 1000 ICS All-In-One InkJet Printer
141 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
