Lean on me - Audio Players & Recorders
  • 3,961 Answers
The song? What is your question?
Posted on May 17, 2014
Who all can take up lean six sigma training?
Everyone of the others who haven't, except those that don't
Apr 08, 2016 | John Wiley & Sons The Lean Six Sigma Guide...
FUEL BANK LEAN, WHAT CAN CAUSE A LEAN FUEL BANK?
Its Lean when you have more air then gas. Its Rich when you have more gas then air. So if its too lean check your air supply, filters, etc.
Mar 08, 2015 | 1999 Dodge Intrepid
Engine light on and misfiring and want to fix this and get it running smooth
The cylinder misfires cause lean or rich
fuel trim
A constant lean on fuel trim, is a rich condition
driven lean by pcm to correct
If two cylinder are affected & are together or maybe
not ,then smoke the intake for vacuum leaks
A leaking injector is obviously a rich senerio
Converter only works with the O2 Sesnors to report
back the rich or lean to pcm
You need to get rid of the misfires before any fuel control
returns to normal
Mar 08, 2013 | Cars & Trucks
2007 Hyundai Entourage codes P2187, PP0174,P2189,P2195,P2270,P2272
I've come across these codes before. In almost every case there was an air leak in the intake air hose (hose between the engine air filter & the throttle body). Inspect this hose & tubes attached to it. This is especially true when the lean code includes the comment 'at idle'
P2187 - System too lean at idle Bank 1
P0174 - System too lean Bank 2
P2189 - System too lean at idle Bank 2
P2195 = HO2S Signal Biased/Stuck Lean (Bank 1 Sensor 1)
P2270 = HO2S Signal Stuck Lean (Bank 1 Sensor 2)
P2272 = HO2S Signal Stuck Lean (Bank 2 Sensor 2)
P2187 & P2189 = In order to provide the best possible combination of drivability, fuel economy and emission control, the PCM uses a closed loop air/fuel metering system. The PCM monitors the HO2S signal voltage and adjusts fuel delivery based in closed loop fuel control. Changes in fuel delivery will be indicated by the long-term and the short-term fuel trim values. The ideal fuel trim value is around 0%. The PCM will add fuel when the HO2S signal is indicating a lean condition. Additional fuel is indicated by fuel trim values that are above 0%. The PCM will reduce fuel when the HO2S signal is indicating a rich condition. Reduction in fuel is indicated by fuel trim values that are below 0%. The DTC relevant to fuel trim will be set when the amount reaches excessive levels because of a lean or rich condition
Aug 31, 2011 | 2008 Hyundai Entourage
P2197 p2187 p2177 p2195 p2179 p2189
P2197 - Oxygen Sensor Signal Biased/Stuck Lean Bank 2 Sensor 1
P2187 - System Too Lean At Idle Bank 1
P2177 - System Too Lean Off Idle Bank 1
P2195 - Oxygen Sensor Signal Biased/Stuck Lean Bank 1 Sensor 1
P2179 - System Too Lean Off Idle Bank 2
I am not sure what your Mazda is, but from the sounds of it, both of your Oxygen Sensors are shot. Replace them both, or check for vacuum leaks. It may be a good time to inspect and replace the PCV Valve and PCV Valve hose, too.
Mar 12, 2011 | Mazda MAZDA6 Cars & Trucks
What do the codes 1128, 1129, 1133, and 1134 mean on my Porsche Boxter 2001?
code P1128 02 sensor bank 1 lean
code P1129 02 sensor bank 1 lean to limit
code P1133 02 sensor bank 2 lean
code P1134 02 sensor bank 2 lean to limit
fuel system is lean.
Jan 29, 2011 | 2001 Porsche Boxster
P0313;Misfire Detected with low fuel P0171-System too lean{bank1} P0174 System too lean{bank2} drive cycle
P0313 - Misfire Detected with Low Fuel
P0174 -System too Lean (Bank 2).
P0171 -System too Lean (Bank 1).
P0171 and P0174 mean "system too lean" for banks 1
Aug 24, 2010 | 2000 BMW 3 Series
Failed inspection on 2004 Ford F150,heritage series ; Fault Code; P0174: System too Lean.I changed PCV valve and Hose to valve cover gasketbut still failed inspection.Please Help
Have you checked for any small vacuum leaks on any of the emissions hoses? A vacuum leak causes a "too lean" reading. If no leaks, you could have a malfunctioning emissions valve, bad oxygen sensor or fuel injection problem. First I would remove the spark plugs to see if they verify that you have a lean condition. Lean plugs will look white. Google for an image of what a lean burning plug looks like if you like. If they look like burning lean then proceed to trouble shoot each possible area. For example if only one plug shows lean but the others don't you know to look at the injector for only that one cylinder. So don't mix up which plug came from which cylinder.
Sep 12, 2009 | 2004 Ford F150
4 codes P0171,P0174,P2195,P2197
Hi
171 system too lean
174 system too lean
2195 - 02 ozygen sensor signal stuck lean Bank1 Sensor 1
2197- 02 ozygen sensor signal stuck lean Bank 2
Sensor 1
The 2 front 02 sensors are located on the front of
the exhaust manifold.
Should solve problem and increase gas mileage.
Apr 01, 2009 | 2003 Ford Expedition
96 Buick Roadmaster running lean.
That is an oxygen sensor, these sensors send a signal to the computor to adjust the rich/lean fuel mixture.
When a code comes up for them, they generally need replacing.
Mar 30, 2009 | 1996 Buick Roadmaster
14 people viewed this question
 Grubhead
Grubhead
