Sony tv - 29 wega model no kv-dz 29, m81 - Televison & Video
  • 1694 Answers
SOURCE: Sony WEGA TV Model KV-32FS13 analog or digital?
No...your set has a digital tuner. Many of us will have a source
box for other reasons, such as getting sports packages or
movie channels......T.
Posted on Feb 27, 2008
SOURCE: I have a Sony FD
THE TUBE COULD BE GETTING WEAK . IF YOU GIVE
ME THE BLINKING I COULD TELL YOU BETTER, IT ALSO COULD BE A SIGN POWER SUPPLY IS GOING .BOTH PROBLEMS CAN BE FIXED I WOULD WAIT FOR TV TO GO OUT BEFORE FIXING INTERMITTING PROBLEMS ARE HARD TO FIX ESTIMATE ON REPAIR IS AROUND 160,00 DOLLARS
THANKS DOCTOR VIDEO
Posted on Apr 25, 2008
SOURCE: Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
1. Place set on flat solid surface (garage floor or driveway).
2. Bang into it with SUV 3 or 4 times.
3. If set fails to respond, crush against garage wall or drive over it
Posted on Jul 09, 2008
  • 586 Answers
SOURCE: Standby indicator light on TV flashes - Sony TV
    Please check fisrst that indicator liight (LED) blinks how many times.it could be from 1 to 8 times and the interval would be of three seconds.So, count the led flashes how many times and then tell me i will try my best to find and fix the solution.
Thanks
Posted on Nov 19, 2008
  • 15 Answers
SOURCE: CAN'T FIND ENGLISH USER MANUAL
You might try and order manual # 4-087-509-21 its only $9.00 and is for model KV-HX700
Posted on Apr 30, 2009
WHAT IS THE MODEL NUMBER OF THE REMOTE FOR SONY TRINITRON 29 WEGA KV-SW29M50
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 09, 2014 | Sony FD Trinitron WEGA KV-SW29M50 29" TV
Sony model KVSR29M9K ,
Hello
What is the problem with your Sony TV? Please be clear in your problem post. Without any details about the fault, how one can suggest a solution to you?
Give details about the problem please.
Dec 30, 2011 | Sony FD Trinitron WEGA KV-29LS35 29" TV
What is the FBT no of sony kv-sw29m50
check this out .you would be able to get the Number
http://elektrotanya.com/sony_bx1l-kv-sw29m31k_kv-sw29m50_kv-sw29m60k_kv-sw29m90k_kv-sw29m91.pdf/download.html
Jun 17, 2011 | Sony FD Trinitron WEGA KV-SW29M50 29" TV
Sony Trinitron WEGA KV-XJ29M50 29" TV - Dead, LED flashes 2 times
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 24, 2010 | Sony KV-XJ29M50 29" TV
Stand by light flashes 7 times and tv will not turn on
Sony Trinitron Wega KV-34HS420 blinks 7 times it means the the Horizontal Deflection stopped.
There are two cause for this: B overcurrent is detected (IC5007 is defective) or there is a over heating is detected by the Thermistor (TH5002). Both of these parts are on the DZ Board. If you order the DZ Board from the "Partstore.com" it will cost you $395.95 minimum. The Thermistor TH5002 (part # 1-807-796-11) cost $4.95.
This IC chip IC5007 is no longer available at Partstore.com. You could purchase it from other stores. Not sure of price.
Replacing the whole DZ board would for sure fix this problem but at close to $400.00. Then what if another board or your picture tube goes out soon.
Better to go buy a new flat panel LCD from Costco for around the same price.
Hope this helps
Bobby Guel "aka poolmvp1"
May 31, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony wega trinitron(1999) KV-36FV15 Moved tv now audio no video
Seven blinks, pause, seven blinks, etc. means "Horizontal deflection stopped" and indicates a serious problem, probably on the D or DZ board (whichever is applicable).
If this is the case, the TV will have to be serviced by a professional.
I hope this helps :)
Best Regards,
James
Jul 29, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony WEGA KV 32FS100
No picture. Standby light blinks 5 times. Tried unplugging and restarting. Same problem
Dec 22, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony Wega KV MOdel
hello, you may have a manual switch botton problem, check those volume control switch, do some test, check the board for some cold solder or short connection. ty
Nov 19, 2007 | Sony FD Trinitron WEGA KV-36FS320 36" TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
