Question about Voyetra Turtle Beach Earforce X12 Headset
Why does my turtle beach cut out sound when i plug my turtle beach?
When i plug my lapel mic into my pc i cannot hear any sound from my tutle beach. what shall i do?
  • 63 Answers
SOURCE: my turtle beach x1 mic doesnt work when i speak
What happens if you try using your X1 with a PC? The X1's green plug goes to the green Line Out (or Front) jack on your PC, while the X1's pink plug goes to the pink Microphone jack on your PC. If the X1 mic works with your PC, then the problem is the chat/controller cable and replacing it should fix the problem. If the mic doesn't work, then the headset will need to be replaced. Turtle Beach should be able to do that for you...
Posted on Feb 24, 2010
  • 63 Answers
SOURCE: mic broke
Try using your X1 with your computer. Plug the X1 green plug into the green jack on the PC. Plug the X1 pink plug into the pink jack on your PC. Try using the headset to listen to the sound of your voice. Can you hear your voice through the headset? If yes, then the mic is OK but the chat-controller cable needs to be replaced. If not, then you should contact Turtle Beach tech support at support@turtlebeach.com.
Posted on Mar 11, 2010
  • 63 Answers
SOURCE: people hear themselves through my mic
That's probably because of a bad controller cable. Turtle Beach should be able to replace that for you. You can reach them at support@turtlebeach.com.
  • 63 Answers
SOURCE: Turtle beach x1 mic
I found this on the Turtle Beach website:
http://turtlebeach.com/support/index.php?View=entry&EntryID=607418123
This test is to find out if your "Talkback Cable" has failed or the "X1 Mic". It is for the PC only not for the Mac. If it works with the PC but not with the Xbox, then your Mic is good but you need to replace the Talkback Cable.
First, make sure the X1 mic mute switch on the amplifier is turned on. Switch it back
and forth to clear out anything that might have built up on the contacts. If that's
not the problem, then try the X1 mic with your PC to see if the level is OK.
If the X1 does not work on your PC then replacing the 'Puck' will not fix the problem.
Make sure that you do not leave the 'Puck' connected while connecting to PC.
1) Take the pink plug from the X1 and plug it into the pink jack (Microphone input)
on your PC's soundcard.
2) Take the green plug from the X1 and plug it into the green jack (Front L/R Out or
Line Out) on your PC's soundcard.
3) Take the USB plug from the X1 and insert it into a USB port on the PC (not a USB hub)
4) In the soundcard's control software, enable the Microphone for playback.
In the Microphone > Advanced settings, enable the Microphone Boost.
5) Adjust the volume for the Microphone to about half-way up.
6) Adjust the overall playback volume to about half-way up.
7) Put on the headset. Make sure the Mute switch on the X1 amp box is not set to Mute
(the LED should be green).
Now speak into the microphone. Do you hear your voice in the headphones? If so, the
mic works and your X1 headphones should be OK. If you still cannot get the X1 mic to
work over Xbox Live, then you need to take a closer look at Dashboard settings and
other connections, or check the integrity of your X1-Xbox Controller Cable.
In order to enable the chat make sure that the Mute button in the Off position.
If it is on the ON position the Mic will not work.
Red = Muted
Green = UN-Muted
To find out if the Xbox Controller Cable 'Puck' has failed, you may also try the 'stock'
cable that came with the Xbox. If the original Xbox cable is working, you know you have
a cable that has failed.
Since these cables have to be lightweight so that they do not "weigh you down" while
playing, caution should be exercised not to pull them or get them caught under furniture
etc.
Here is a video showing how to test the mic with your PC in Windows XP:
http://www.youtube.com/watch?v=Vissxo8furo
  • 18 Answers
SOURCE: cant hear anyone on xbox 360 when using a x1 turtle beach
You need a replacement talkback cable. You can purchase one through the Turtle Beach site or by contacting their support about a replacement.
Hello all this my Z11 tutle beach headset The
this could be your pc driver problem. try to update/repair/modify your drivers and configure its headset settings from your audio driver.
Nov 05, 2013 | Turtle Beach Earforce Z11 Pc Headset
When i talk people cant hear me though turtle
If you have an X1 headset...
Try using the X1 headset and mic with your PC (sound card). Green plug goes to green jack, Pink plug goes to pink jack. Can you hear your voice thru the X1 mic on your PC? If yes, then the mic works but the chat-controller cable is probably broken and should be replaced. If no, then the mic may be broken and you should contact Turtle Beach's tech support for help -- support@turtlebeach.com.
Mar 04, 2010 | Voyetra Turtle Beach Turtle Beach Ear...
I am having troubles with my Turtle Beachs X1s
You may have kinked your controller cable when you moved all your Xbox stuff. You might as well get a replacement controller cable--Turtle Beach sells them for only $4.95 on their website. I'd recommend the newer white one since that looks to be a lot thicker.
Feb 24, 2010 | Voyetra Turtle Beach Ear Force X1 Headset
My tutle beach makes a wierd noise to my friends but i dont hear it
If you're using a wired controller, try a wireless controller. Sometimes connecting the USB on the controller and USB on the X1 to the XBOX can cause noise from the controller that can leak into the chat signal.
Feb 18, 2010 | Voyetra Turtle Beach Turtle Beach Ear...
My Turtle beach X31 keeps cutting my mic out from chat so i can't hear poeple and they cant hear me but i can still hear sounds in the head set
That sounds like the chat/controller cable might be to loose in the headset jack. Turtle Beach has a newer cable available that should fit tighter. Their email is support@turtlebeach.com.
Jan 16, 2010 | Voyetra Turtle Beach Ear Force X3 Wireless...
My turtle beach x1 stopped working
What happens if you try your X1 on a PC instead of on your Xbox? That's a good test of the mic... Here's how:
- Plug the X1 USB into a USB port on your PC. - Plug the X1 green plug into the green Line Out jack on your PC. - Plug the X1 pink plug into the pink Microphone jack on your PC.
Try recording the sound of your own voice on the PC, using Sound Recorder or whatever. Do you hear the sound of your voice? If so, your mic is working and the X1 chat/controller cable is probably broken. Replace the chat/controller cable.
If not, then the X1 mic is broken and you should contact Turtle Beach for service at support@turtlebeach.com.
Jan 09, 2010 | Voyetra Turtle Beach Ear Force X1 Headset
Mic wont work, i can hear friends but they cant hear me.
Can you try using the X1 mic on your PC? Green plug to green jack, pink plug to pink jack, USB plug to USB port. Talk into the X1 mic. Can you hear your voice? If yes, then you probably have a bad chat-controller cable. If no, then your X1 mic may not be working. If that's the problem, you should contact Turtle Beach tech support for help. support@turtlebeach.com.
Dec 24, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
Everything works in my turtle beach x1 but people cant hear me speaking
Have you tried using your X1 on your PC? Plug the green plug to the green jack, pink plug to pink jack, USB plug to USB port. Speak into the mic and you should hear yourself in the headset. If you can hear yourself, then the problem is the chat-controller cable and you should get that replaced. If not, it may mean your X1 mic is broken and you should contact Turtle Beach about that --- support@turtlebeach.com.
Oct 24, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
Computer wont recognize the microphone on the turtle beach x4
Jul 21, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
Mic broke
May 23, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
Voyetra Turtle Beach Earforce X12 Headset Logo
15 people viewed this question
Top Voyetra Turtle Beach Radio Communications Experts
Michial Gueffroy
aravind shet
aravind shet
Are you a Voyetra Turtle Beach Radio Communication Expert? Answer questions, earn points and help others
