Question about Sewing Machines
My sewing machine has been working fine but when I changed thread colour and bobbin the motor works but there is real restriction on the needle and it struggles to go up or down at all. Have looked fo
My machine is 28 years old and this is the first problem I've had!
  • 55 Answers
Hi sounds like either some thread caught up somewhere... or the needle tension is far too tight.... I would check for caught thread under the needle plate.
Posted on May 17, 2014
SOURCE: Thread won't catch bobbin
I hope to God nobody else pays more for a repair than the machine is worth.
It's ridiculous to spend $300 for that repair since the machine is available almost everywhere for way under $200. You could have thrown that one in the trash and bought a new one cheaper than the repair!!
I paid $129 for mine, had the same problem with two, yes, two of them, and sent them back and was sent another which so far is working fine. There seems to be a flaw in the engineering of that machine since so many people are experiencing the same problem. The machines DO have a warranty so please, please, be careful of unscrupulous repair people. Oh, I'm sorry but I need to mention that I bought my machine from eBay and it was a refurbished machine sold by Ken Sewing and Vacumm in Muscle Shoals, Al. They stand behind their products and were very nice to deal with, they even paid for the return shipping on the two that I returned. Hope this helps y'all.
Posted on Nov 10, 2008
SOURCE: Not picking up the Bobbin thread
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Posted on Nov 17, 2008
sew dutch
  • 24 Answers
SOURCE: Top thread won't pick up the bobbin thread
re insert the needle, maybe you did not put the needle up as far as it is to go. Make sure the flat side of the needle is to the back of the machine. Without any thread in the machine hand turn the wheel and look to see if the hook of your bobbin would/could catch the thread (to see if timing is right)
then thread the machine and hand turn the wheel and see what it is doing.
Your timing might be off, but I do not think that is likely. Though it is possible that when the needle fell out, it hit something hard, broke, and pushed the machine out of timing. then you need to bring it in.
Posted on May 26, 2009
SOURCE: Just bought machine, new needle, thread, Needle
try sewusa loads of manuals and sewing diagrams. Since its a older machine.I would clean and oil it also.Lint can cause all kinds of issues.
Posted on Dec 29, 2009
SOURCE: Brother VX-1120- The needle is not picking up bobbin thread.
I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
Posted on Oct 30, 2010
My Kenmore Sewing Machine's needle is locked down
best suggestion try inserting new needle. cotton up the top suggests needle problem or incorrect top thread tension, this would effect the feed dog. Because thread is black and most recent use was with pink, the problem thread was already there perhaps in cavity above bobbin but below throat plate. I have had this happen and nothing will move, untill needle released. The bobbin holder tension may also need adjusting after the knots of black cotton are removed.
Nov 07, 2013 | Kenmore 15516 Mechanical Sewing Machine
HOW DO YOU CHANGE FROM ONE COLOUR BOBBIN TO THE PREFILLED NEXT COLOUR BOBBIN
hold thread end w/3" length and put the it in the bobbin case and make sure its unwinding clockwise..Feed thread thru the higher left metal notch and pull to lower left notch and make sure the thread stays behind the spring slot and leave about 4"tail...put bobbin in its place lining up the white dots close the case and turn the wheel to drive down needle holding the needle on the machine base losely and draw the bobbin thread up
Mar 22, 2013 | As Seen On TV Sewing Genie Mechanical...
Top thread is breaking on Janome 6600P
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Jan 16, 2013 | Sewing Machines
Juki ddl 8700 my machine was sewing fine I put in a heavier (jean) thread. Now it wont pick up the bobbin thread to sew at all? Help?
try changing the needle to one that will work with heavier thread
you may have to change the bobbin to heavier thread also
try adjusting the tension also
Sep 25, 2012 | Juki DDL-8700
I'm new to sewing, have threaded my bobbin, installed it in its casing, and threaded my machine. But when I take the needle down to pick up the bobbin thread, nothing happens. I've taken the bobbin out...
I am having the same problem !! was sewing fine then it stopped, have changed the cotton, needle, took case out and put back in , checked tension on all settings but still not picking up the cotton . Motor works fine and every thing all seems ok but cannot figure out why its not picking up the thread.All i can think is needle is not going down far enough to make contact but took needle out and lowed it but still nothing. Hope some one can help !!!!!!!!!!!!!! PLEASE
Jan 15, 2011 | Singer 1507
I have a new machine at it was working fine...suddenly it began sewing the design with bobbin thread. Rethreaded, changed bobbin, and changed needle (over and over). Also, change tension. No help. No...
The way the thread passes thru the bobbin tension on this machine makes it real easy but sometimes the thread doesnt go where it is supposed to. Try doing it several times, you can feel the thread get tension when it fits in correctly.
Good Luck
Aug 30, 2010 | Brother PE770 Computerized Sewing Machine
Sewing machine won't raise the bobbin thread
Hi. The two main reasons why the top thread doesn't pick up the bobbin thread is either the needle is inserted wrong or the needle is bent. Since your machine was sewing properly until the thread broke, I'd be inclined to think the needle may have gotten bent. Sometimes this can happen if you sew over a pin.
Change the needle (making sure the flat side of the needle shank is inserted properly for your machine) and see if that solves the problem. Let me know if it helps, ok?
Robbie
Jun 07, 2010 | Singer Sewing Machines
Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Apr 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Thread caught up around bobbin!
To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
Nov 12, 2007 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
