Question about Garden
I have a 32 cc craftsman and the pull cord doesn't engage the motor
2 Suggested Answers
erickg
  • 116 Answers
SOURCE: REplacing the pulling cord on a gas trimmer
those are usaully under your pull start cover and if its broke you can buy a new rope but if its broke near handle i would open it and retie it to save ya money. but remember to wind spring a little to keep tension on it before pushing it through the hole for handle.
Posted on Apr 17, 2009
Starting issue
the starter gear inside the pull cord is not engaging
this is a non servicable part
approach supplier and buy a new pull starter
Mar 26, 2014 | Craftsman 2-Cycle Mini Tiller
I have a Craftsman/Chamberlain 1/2 hp 315mhz Garage door opener model 139.1845.DM just stopped working. The motor runs the chain moves, the door doesn't open. Whether I use the remote or pad still n
All garage door openers have a quick release. Have you checked to make sure that is locked in place? Most have a cord hangin from it and you pull it which releases it from the chain. Make sure that is engaged and it should work.
Dec 02, 2011 | Home Security
Craftsman 3/4 chain drive will not open, when pressing wall switch I hear click at the unit and the programming light will flash, but it doesn't open the door, or close for that matter the motor...
The unit is for sure repairable. You should remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor and it will be obvious if it is bad. If you have had electrical storms it may have gotten to your logic board. You need to pull it and check for burnt or missing traces on the printed circuit.
Aug 09, 2011 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman lawn mower starter cord doesn't retract after mower starts.
I have had this situation before on a lawnmower. I didn't have a craftsman, but is probably the same issue. Basically, the spring that recoils the cord back in either broke or came unwound. When the mower is not running, the cogs on the pull chord keeps the cord from coming out. When the mower is running, the spring is not wound enough to hold the chord in and thus releases or doesn't hold it in.
Try pulling the pull chord assembly off and rewind the spring.
May 05, 2011 | Craftsman Garden
Have a Craftsman 1/2 HP Garage Door Opener, been working fine. Now when you start it you hear the motor running as normal but the chain doesnt move?
You must ensure the drive chain is engaged to the door puller.
Sometimes the emergency release if pulled (red cord) the drive and the coupling come separated.
Make sure the pin is back in place (pull release cord and make sure pin springs back in).
The run an open close cycle, it should pick up the drive again.
Please dont forget to vote this answer was helpful and accept my answer.
Many thanks
Feb 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
32 cc craftsman trimmer starts but will not run at full rpm
Air fuel mixture problem,,,you need to have the filter pulled out and cleaned. Check fuel system for debris and clean, that includes all the fuel lines and possibly disassemble carb and clean and reassemble.
Apr 27, 2010 | Craftsman 25cc Gas Line Trimmer
My craftsman 32 cc 2 cycle line trimmer doesn't
Check the line head and cable, there may be grass or something like twine twisted between the shaft and housing. If nothing is found there take the spark plug out and see if it will turn over, possibly liquid gasoline has gotten into the cylinder somehow.
Jul 05, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc Line Trimmer pull start will not engage engine.
Hi I have a craftsman 4 cycle model no. 316.791970 gas trimmer. When I pull on the rode there is little resistance . I took the sparkplug out and put a flash light down the hole and there is a thing that is moving . What should I look next, or do you know what is wrong? Thanks for any help! I've had it only 3 years and already Sears have replace the clutch assy.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
Pullcord violently retracting on Craftsman lawnmower
It is possible that the 'dogs' that engage the crankhaft were stuck in the out (engaged position). Once the engine started, it wound the rope in the opposite direction until the dogs slipped and retracted. Romve the top cover that includes the pull start unit. Check for smooth and sticky free operation while pulling on the cord. Try using a very light oil to lube if nessesary.
Apr 29, 2009 | Sport & Outdoor - Others
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
