Question about Kenwood Car Audio & Video
Showing protected kdc-u3556 showing protected
MY kenwood KDC-W3044 is showing protect on the screen....... what should i do to remove??????
Dec 11, 2010 | Audio Players & Recorders
Kenwood KDC-MP732 CD Player in protect mode how do i get it off had a blown speaker fixed it and still in protect mode
Protect Mode (Blink): The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protection function is activated.
Solution: Wire or insulate the speaker cable properly and press the reset button.
Here is a copy of the Instruction Manual for the Kenwood KDC-X790 and KDC-MP732.
Jul 25, 2010 | Kenwood KDC-MP732 CD Player
I have a Kenwood car stereo model # KDC-MP342U. Protect mode has been activated on it. I found I had a frayed wire on a speaker from window movement and have replaced the wire. When I reset the radio and...
hold down preset 3 & 6 + reset
press preset 1 - shows dc err
press preset 1 - shows dc ok
press preset 2 - shows dc 2-4
press preset 2 - shows dc 2-0
then unit should be ok with eeprom reset
Jul 18, 2010 | Kenwood KDC-MP342U Car CD Player
My kenwood kdc-mp53u flashes PROTECT whats wrong with it?
Protect indicates that there is a short or a grounding problem usually within the speakers2_bing.gif or the speaker wiring. Locate and press the reset button (pinhole). If protect comes back then disconnect all speakers, reset and connect them back one at a time until protect shows up again. This will help you find out where the unwanted DC signal is coming from. If protect shows up when all speakers are disconnected, then it may need service.
Apr 11, 2010 | Kenwood KDC-MP538U Car CD/ MP3 Player
Kenwood kdc-mp208 stuck in ''protect'' mode....
Apr 10, 2010 | Kenwood KDC-MP208 Car CD/ MP3 Player
Code for kenwood car stereo kdc- mp232
showing "PROTECT" ON DISPLAY WHEN POWERED ON
Mar 18, 2010 | Kenwood KDC-MP232 CD Player
Kenwood kdc-w3041 protect mode
Hello ia737,
The "protect" display is probably being caused by a shorted or grounded (touching vehicle chassis or other ground) speaker wire. Check the speaker wires for bare spots, etc and insulate or replace as necessary.
You do not need to remove the fuses to force a "cold reset" of the W-3041. You can simply press the "reset" button on the front of the unit. It's the little recessed button at the lower left of the volume control. Use the straightened end of a paper clip or ballpoint pen to momentarily hold the button in.
Hope this helps.
Jul 23, 2009 | Kenwood Car Audio & Video
I have a kenwood kdc-mp332 and it just show protect i need music now please help
My manuel says : Protect: The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protection function is activated. Wire or insulate the speaker cable properly and press the reset button. I had the same problem with my stereo, but I took it to Geek Squad cause I still have warranty on it.
Dec 06, 2008 | Kenwood KDC-MP332 CD Player
Kdc mp438u
it says protect meaning one of the speakers is shorted troubleshoot my speakers all were good put my old radio in everything worked put the kdc back in verified that the radio is bad took back to best buy interchange for a pioneer for about 60 more
Jul 03, 2008 | Kenwood KDC-X590 CD Player
Security
"Protect" isn't for security on a Kenwood; it's caused by a problem with the speaker output. There may be a defect in the CD player, or you may have a blown speaker or a shorted speaker wire in the vehicle. Try disconnecting all the speakers and see if the unit still shows "protect" when you turn it on. If it still shows the "protect" message with no speakers connected, the unit needs to be serviced; if not, re-connect the speakers one at a time until you find out which one is causing the problem.
Aug 10, 2007 | Kenwood KDC-MP232 CD Player
Car Audio & Video Logo
47 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
