Question about Welding Tools
Wolfweld arc 130
Manual
Miller 130 wire advances, fan runs, but will not arc as wire comes out
Most of these machines (would have to have serial number to be sure) will not feed if their is no output voltage, since part of the motor voltage comes from the arc voltage.
So, I would suspect broken wires, either in the work lead or the gun. If it arcs just a little, probably the gun. One place the work lead breaks is right at the back of the clamp. Pull on the insulation and see if it "stretches". If so, the wire there is broken.
Feb 21, 2015 | Miller Welding Tools
230 volt welder
Breaker must be 50A and the size wire should be a 8/3.
Feb 23, 2014 | Welding Tools
When releasing the thumb control to cast the line drops free (making it unable to cast)
you have to release the button after you start your cast, distance,height and length of cast is determined by where you release the button inside the forward arc of your cast, just like throwing a baseball.
Oct 18, 2013 | Zebco 33 Authentic Spincast Reel, 1 Ball...
MY CLARKE WELD 235 TEN TURBO ARC WELDER HAS SUDENLY STARTED BLOWING FUSES WHEN IT ARCS UP ANY IDEA
More then likely you have a shorted component (positive or hot wire to ground). Verify that the gun/trigger assembly is in good shape and has no broken wires that are touching the ground or case (may have to disassemble). Thats the easiest thing to check, everything else is inside the unit and will take more sophisticated knowledge and equipment to diagnose.
Oct 12, 2011 | Clarke Power Products Clarke 130EN...
When the welder is first turned on I can weld with gas for about 5 seconds. Then the breaker trips. ( i have the proper wiring and breaker). The more times I reset the breaker the shorter the weld time...
Hi:
Just make sure that if you are using an extension cable between your machine and the power outlet, this cable is at least a 12 gauge size, if you are using a 14 or 16 it's too small to handle the amps.
Other point is to check that your breaker is 20 or 30 Amp capacity.
Hope this help.
Sep 08, 2011 | Clarke Power Products Clarke 130EN...
I have a mercruiser 260 and wheb i connect the 2nd battery it arcs is my isolator bad
Check the polarity, it sounds real wrong, the batteries need to be pos to pos and neg to neg.
May 12, 2010 | ProMariner Battery Isolator 2 Alternator ...
Everything comes on and the wire feeds. However it
Check that your ground clamp is connected to the work piece securely.
Mar 14, 2010 | Clarke Power Products Clarke 130EN...
Welding Tools Logo
41 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
