Question about Medical Resources Inc. Medical Student and Residency Question of the Day
Does high bllod pressure cause hearing loss - Medical Resources Inc. Medical Student and Residency Question of the Day
OUTDOOR UNIT START AND IMMEDIATELY STOP
Its probably a safety causing it to cycle off, or a component failure. It may have a low pressure safety switch. In the event of freon loss, this safety does not allow operation to prevent compressor damage. Or it has a high pressure switch. Same process but prevents excessive freon pressure.
Mar 07, 2017 | Heating & Cooling
My pressure Washer Pump Leaks water and does not pump normal?
If the pump is leaking water then you have a packing issue. this will cause a loss of pressure as well...check out here for parts Pressure washer parts catalog quick links Pressure Washers High Pressure... also check out here for specs and diagrams http://www.arnorthamerica.com/pumpbd.html
Aug 27, 2014 | Annovi Reverberi Garden
CHECKED THE FUEL [PRUSSURE AT THE FILTER AND IT READ 70PSI ON MY 1987 THUNDERBIRD IT SHOULD ONLY BE 40
If you read the pressure at the fuel filter location of course it'll be high!!! it still has a ways to travel, not to factor in the pressure losses! and then the fuel pressure regulator!
Jun 22, 2012 | Cars & Trucks
When i put gas in my 2003 cts its hard to start,and i can hear a noise coming from the the gas tank area
I see 2 things to test and not knowing what sound it makes, I make these recommendations.
First, when you open the gascap, your sealed system is no longer sealed. This means the vacuum must be restored to reseal the system. You have a venting system which can be checked with a smoke test machine.
This usually makes a Code or lights a check-engine light, but I imagine since the car is not running but only cranking the light may not go on. The noise you hear may be valving closing to create a vacuum. But since this is interferring with the starting, the integrity of the system should be checked.
The fuelpump and fuelpump pressure regulator should be checked. Your fuel should not leave the engine high and dry for several reasons. The system should maintain line pressure even overnight. The fuelpump should be capable of repressurizng the system within seconds, so hard starts should not occur from this. Loss of the vacuum seal on the gascap should not cause the fuel to drain from the lines and the pressure regulator should provide a one-way valve to prevent loss of pressure.
I work primarily on Ford products and unless GM has some sort of prevention system for starting with no fuel, there should be no reason to have these problems.
I would like to know how this ends up when you find out.
There are really
Mar 30, 2012 | 2003 Cadillac CTS
Code p0190 what is it
There is not a cut and dry one answer fixes it for this code, it has to do withthe fuel supply manifold pressure sensor not reading correctly. Here is the diagnostic info.
P0190 FORD - Fuel Rail Pressure Sensor A Circuit out of range
Symptoms - Engine Light ON (or Service Engine Soon Warning Light)
- Engine will not start Possible causes - High fuel pressure
- Low fuel pressure
- Damaged FRP sensor (most common)
- Excessive resistance in the circuit
- Low or no fuel
- Wiring harness connector of the fuel pressure sensor
- Vacuum leaks
- Fuel leaking causing loss of pressure
Jan 27, 2012 | 2004 Ford F150
Blower for air conditioner works but no cold air comes out
it sounds like either you a/c compressor isnt working properly of you have a leak in the a/c system causing a loss of refrigerant. a way to see if your compressor is working properly is to open te hood and have someone sit in the car with the key on engine off and have them push the a/c button on and off. you should hear a definate click coming from the compressor. if you dont hear a click it would be because your compressor failed or there isnt enough refrigerant in the system for the compressor to come on. there are two pressure switches a low pressure switch that tells the compressor to come on once the pressure drops to a certain point. and a high pressure that tells the compressor to shut off once it reaches a certain pressure. you can try recharging the system yourself by going to your local auto parts store and buying a recharge kit. this may solve the problem but if it leaked off once, chances are its going to do it again so i would take it to a shop and have them test it for leaks.
Aug 21, 2011 | 2004 Dodge Intrepid
I have a Lumiscope Digitronic model 1085M. The
I just Rec'd a model # 1133 this A.m. I went to take my Husbands's bllod presure and it the ERr kept coming up so I plugged it into the electric socket I just hope that is all it is and were do I go to register this blood presure mesaurer for the wranty
Jun 03, 2010 | Lumiscope 1080 Deluxe Auto Blood Pressure...
Oil guage drops then goes to high range
sounds like your sending unit needs to be replaced cheap fix and if your oil pump losses all its pressure you will begin to hear knocking coming from your motor from the top under the heads.
May 27, 2010 | 1991 Buick Park Avenue
Oil pressure goes low when engine is warm
metal expands when heated, you are losing pressure through a leak caused by the expanding metal. Its impossible to know where the pressure loss is.
Another possiblity is that the oil pressure sensor is failing at high tempurature. You could replace the sensor to see if that is the problem
Sep 13, 2009 | Chevrolet Blazer Cars & Trucks
Medical Resources Inc. Medical Student and Residency Question of the Day Logo
67 people viewed this question
Top Medical Resources Inc. Facebook Apps Experts
David Payne
David Payne
Bill Boyd
ray gallant
Are you a Medical Resources Inc. Facebook App Expert? Answer questions, earn points and help others
