Question about Seagate FreeAgent (ST305004FDA1E1-RK) 500 GB USB 2.0 Hard Drive
How to ST305004FDA1E1-RK chance disk - Seagate FreeAgent (ST305004FDA1E1-RK) 500 GB USB 2.0 Hard Drive
Hard disk not detect
open the case and extract the hard disk from case then check it but putting data cable and power cable in it.
Jan 03, 2013 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
I have a hdd freeagent goflex 500 giga i formated my hdd after that i didint detect my hdd . please help me
First of all, check it with partition magic 8 and reformat if the partitions show in this software. And secondly, try to connect with another PC or it may the problem with your data cable but its chances are very low.
Please try with my above two options at least I assure you that your problem will resolve.
you can contact me for further more details
Best of Luck
Mar 11, 2011 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
I always get an i/o device error when trying to copy files from my hard disk to my system
Reseat the data cable inside the Seagate drive. If you know the Seagate to be operating correctly, can you copy files from your computer to the Seagate? The answer should be no. In that case either the Seagate HDD is failing, failed or the USB port is improperly operating.
Mar 09, 2011 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Microsoft Windows asking me to backup the files in drives because hard disk has encountered a problem. How to solve the problem without backing up of the files?
There is no way you can avoid this because if the hard drive fails you will lose your data.
Do you want to risk losing your data?
The problem could be some bad blocks on the hard disk and Scan Disk may fix this problem BUT there is a risk this process may wipe out some data files or may require re-formating the hard drive.
The hard drive may be corrected by re-formatting the hard drive, but this process will wipe your data off this hard disk.
Nov 29, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
My 500 gb does not work on Windows 7 anymore
i think its a problem with the device drivers, try it on another pc to ensure the problem is not from the drive,
Oct 10, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
I'm trying to sync my files from my old computer
no you can what you have to use is files and setting transfer wizard in windows xp you can start the Files and Settings Transfer Wizard by clicking Start on the computer running Windows XP, pointing to All Programs, Accessories, System Tools, and then clickingFiles and Settings Transfer Wizard. (If both computers are running XP, you can start with either one.)
just select "i want create wizard disk in following drive " and select you external disk drive tha will do the trick...
Apr 11, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
The USB port on my seagate 500GB external drive has broken off, and is somewhere inside the case.
You should be able to pop open the enclosure to retrieve the hard drive. You may need to take out a few screws.
Once you've done that, you can purchase another external USB enclosure to replace the broken one.
Aug 09, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Seagate FreeAgent  (ST305004FDA1E1-RK) 500 GB USB 2.0 Hard Drive Logo
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
