Question about Ricoh 4506 Copier
ERROR CODE SC 302 IN MP 5000 - Ricoh 4506 Copier
  • 86 Answers
SOURCE: Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
Ickoajnc
  • 183 Answers
SOURCE: Ricoh Aficio MP 1600 Le error code sc 322 occured
Try to reset the machine by turn it off and after 5 second turn it on again by the red switch-plug which is located on the left side in the middle.
If this do not help you will need to cal a technician because the machine have problem with the laser unit.
Please answer do this is helpful.
Regards
Posted on Jan 13, 2010
  • 903 Answers
SOURCE: how can i solve error code sc:302 in ricoh Aficio
You should have a service technician take a look at your copier. SC302 is a charge roller current error, and it could be caused by a number of things, from a dirty charge roller to a faulty high voltage supply board.
In the meantime, try turning the machine off, unplugging it, and then plugging it back in and turning it on the see if the error message will clear.
Posted on Aug 26, 2010
  • 5 Answers
SOURCE: Sir, My copier model RICOH MP
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Posted on Sep 06, 2010
Testimonial: "Sir, Thank you so much for your help, let me try in my copier and revert back once the problem is solved. Thanks Gopalkrishna T N"
  • 398 Answers
SOURCE: Problem with the Ricoh mp c2800 Ricoh error code
If the model ia a MPC 2800 it a controller board issue maybe the operation panel. -carl
Posted on Nov 15, 2010
How to solve this problem sc 302
Hi
I managed to find a list of Ricoh error codes with brief explanations of their causes here:
Ricoh copiers error code messages
This clearly identifies the problem as a laser motor problem - OR
Charge roller, HVT, or fuse FU5 (AFICIO 340, 350 series, 355, 450 series, and 455) - OR
SC-302-01, 02, 03, 04 Charge corona assembly Aficio 550/650
SC-303 Charge corona wire cleaner, disconnected or time out for printer.
All of these sound rather like an engineer requirement but you may be able to something with appropriate spares
Sep 25, 2014 | Ricoh Office Equipment & Supplies
How to clear error code SC302, Dsm615 nashuatec
Yes, mine were successfully RESET from the error code SC:552 and SC:302. Machines runs good, but i about to wander what could be faulty inside, it took one month after error code 302 exist. Mine was exactly DSM615 same model same error code 302 (this is really 302) which resolved by reset. Hopefully machine will run good for two months.
To RESET it
1. Press Yellow button
2. Press 1, 0, 7
3. Hold Orange button for 3 seconds
4. Select MODE 5
5. Select Clear Memory (or something like it) (801)
6. Select 002-Engine
7. Select EXECUTE
8. Turn the switch off and leave it for a minute
9. Turn back machine On.
10. Done, or else there could possibly something else.
Good Luck....
Thanks for using Fixya.
Mar 04, 2013 | Office Equipment & Supplies
Error code sc 302
Hi
This error indicates problems with the laser motor on your printer.
Have it replaced.
Mar 01, 2012 | Office Equipment & Supplies
Error occured SC:302 Functional Problem Turn main power switch off and on if the error appears again. Call Service
SC:302
Charge roller current leak
Symptom: A current leak signal for the charge roller is detected.
Possible Cause:
?? Charge roller damaged
?? High voltage supply board defective
?? Poor connection of the PCU
May 27, 2011 | Ricoh Aficio MP 1600L Black and White...
Sc 302 error code
You have a leak power in the charge roller.
It may just be a defect or poor contact on the roller charge, but you can also have problems in the power supply.
If you have no technical training I advise you to call a professional.
Jan 31, 2011 | Ricoh Aficio MP 1600L Black and White...
How to reset MP161 Ricio
The Ricoh Aficio MP 161 LN give error code - SC 302
Please adivse
Nov 21, 2010 | Ricoh Aficio MP 161 Black and White Copier
Functional problem sc 302 in ricoh photocopier model aticio1600
the charge roller in the drum unit is faulty or need to be cleaned.strip the drum unit and clean the unit
Sep 06, 2010 | Ricoh Aficio MP 1600 Black and White...
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
Feb 02, 2009 | Gestetner DSm615 Digital Imaging System
Ricoh 4506 Copier Logo
179 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
