Question about Ricoh Aficio Office Equipment & Supplies
Functional problem SC 670 - Aficio Ricoh Office Equipment & Supplies
2 Suggested Answers
  • 26 Answers
SOURCE: Aficio 450 Copier: what is the meaning of sc 670 on 1035 machine...
DEFECTIVE BICU PWB OR DEFECTIVE CONTROLLER PWB THIS IS GOING TO BE EXPENSIVE 1000.00 OR MORE
Posted on May 20, 2010
Ricoh mpc 6000 sc 670
Engine startup error - sudden communication reset between controller and VBCU 7/29/2008 Helpful SC 670 Engine startup error - VBCU defective 7/29/2008 Helpful SC 670 Engine startup error - VBCU installation incorrect 7/29/2008 Helpful SC 670 Engine startup error - LCT lift tray sensor was shorted 9/2/2008 Helpful SC 670 Engine start up error. Check main power supply, cn 409 for 5volts 7/20/2009 Helpful SC 670 Engine startup error - Replace laser unit and follow SP adjustments after laser unit replacement 4/5/2010 Helpful SC 670 Engine startup error - IOB board defective 6/8/2010 Helpful SC 670 Blown fuse 2 on VBCU due to shorted harness in registration motor harness 6/8/2010 Helpful SC 670 Engine start up error - Check wiring for df feed in cover.. 8/6/2010 Helpful SC 670 Engine startup error - Replace finisher main board 10/26/2010 Helpful SC 671 Controller mis-match error - Install correct controller b
THIS UNIT IS VERY HARD TO WORK ON YOU NEED A SERVICE CALL, GOOD LUCK! -Carl
Mar 31, 2015 | Ricoh Office Equipment & Supplies
Imprimente ricoh afico 1224c sc670
SC 670 - Engine response error.
After powerig on the copier machine,a respons is not received from the engine .possible defect controller board or SBCU installed incorrectly.Try reset the code to turn ON/OFF the main power switch.
Mar 01, 2013 | Ricoh Aficio 3232c 3214c 1232c 1224c Oil...
Ricoh sc 672 error on new machine
  1. Go to this code with "Clear Mode"+107+"Clear/Stop" hold for 5s.
  2. Go to System Settings
  3. Go to 5875
  4. Check the setting of SP5875-001. If the setting is set to "1 (OFF)",change it to "0 (OFF)".
Try checking or changing the thermistors!
The metal contact spring on the thermistor broken causing all sorts of 'unrelated errors including 'Please Wait' sc 670 and sc 402...
Feb 28, 2012 | Ricoh Aficio 450 Copier
How to decode Ricoh (Aficio) 1224c with code sc 670 from my color copy mactine....
In the service mode (clear modes 107 hold down clear/stop key) then punch in 7807 on the number pad then execute to reset the sc 670, if it doesn't clear you may have a bad controller board or HDD. Hope this helps
Aug 03, 2011 | Office Equipment & Supplies
May 17, 2010 | Ricoh Aficio 450 Copier
Sc 670 aficio 2045
Did you shift the machine recently? If yes check the connectors in the controller and other boards.
Or the boards are not installed correctly.
Worst case BICU board or controller board defective.
Mar 10, 2010 | Ricoh Aficio 1035 Copier
Service code SC 548 on a Ricoh Aficio SPC 811dn printer, what is it and how to correct?
I have sc 548 error code also. I was following your instruction, but i couldn't enter to service mode. How do i prepare it? Please write this instruction to me step by step.
Apr 23, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Showin cover open but doesnt indicate plus sc code 670
I looked up the error code in the manuals for the 450 and 450e,I tried sc 670, 607, 706 and 760 NONE or those codes exist in either one of my manuals! Sorry. Wish I could help
Apr 03, 2009 | Ricoh Aficio 450 Copier
15 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
