Question about Dryers
How do I remove the frum from my F&P ED55 Dryer. When it is on it makes a noise only at one part of the drum rotation. I am thinking something like a stud from a pair of jeans being stuck between the layers of the drum. I have dismantle it up till there and all looks good. Thanks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 123 Answers
Sounds more like a pulley wheel gone bad. There are 2 wheels one on each side of dryer drum where it rests . When one wheel goes bad the drum turns on an angle and causes that grinding noise
Posted on Jun 01, 2014
SOURCE: Zanussi TC470 Tumble Dryer - Drum not rotating
Both sound like the drive belt to me - I've just replaced mine.
BirdG is probably snapped.
mildew is on the way - the motor will burn through it if left unfixed.
you may be able to tighten it and get more time out of it but sounds like it has a worn patch and will go soon.
(tightening is easy- just remove the fan belt cover at the back,slacken the large bolt below the motor and rotate the motor to push the jockey wheel harder against the belt, then retighten the bolt.
replacing is harder.
Posted on Feb 09, 2008
JOE LLAMA
  • 26 Answers
SOURCE: LG ELECTRIC DRYER
Henry, its going to be 1 of 2 things. Check inside your drum, see if the vent in the rear has burning or discoloration around it. If it does, it sounds as if your vent is restricted causing the unit to overheat, so clean/fix/replace the venting and your support pulleys will need to be repalce ie flat spots from overheat. If there is no scoarching marks and you know its not the vent or heat issue, the drum seam may have parted causing the thump as every revolution is made.
Posted on Apr 04, 2008
SOURCE: dryer makes noise as drum rotates on ge profile gas dryer
Solution: the drum slides were worn out and needed replacement.
Posted on Jan 14, 2009
  • 69 Answers
SOURCE: my whirlpool cabrio electric dryer makes grinding noise
could be a bearing gone
Posted on Mar 27, 2010
Jahn27
  • 1554 Answers
SOURCE: LG Front Load Dryer -
The drum rollers need to be replaced at once. Disconnect power then remove the three screws attaching the top panel bracket to the rear of the machine. Push the top panel backward then lift to remove.
Remove the two screws attaching the control panel frame to the cabinet. Disconnect the connectors then pull the control panel assembly upward and then forward to remove.
Open the door and remove the two screws from the bottom of the door opening. Remove the four screws attaching the front panel from the cabinet. Disconnect the harness of door switch then remove the front panel.
Disconnect the door lamp and electrode sensor connector. Remove the four screws attaching the front bulkhead to the cabinet then remove.
Remove the drum and the rear bulkhead for complete access of the drum rollers. Reassemble the dryer in reverse order of the disassembly steps.
Please make you accept this post if you find it helpful and informative. Failure to do so will automatically give credit to the first solution no matter how unhelpful or non-informative it is. Accepting the solution will not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Oct 22, 2010
Why is it making noise and smelling like something burning?
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Mar 07, 2015 | EuroTech EDV158 Electric Dryer
The dryer is making a squealing noise when tuning like something needs to be lubricated
DRYER MAKES NOISES.
The blower:
The bearings:
Feb 21, 2015 | Dryers
Asko dryer make a banging noise
GOD IS GOOD !!!!
DRYER MAKES NOISES.
The blower:
The bearings:
Oct 02, 2014 | Asko Dryers
What could make a noise when drum tumbles on Fisher Paykel top loading dryer, Model DEGX2?
GOD IS GOOD !!!!
DRYER MAKES NOISES.
The blower:
The bearings:
Sep 30, 2014 | Fisher and Paykel DEGX2 Dryer
How do I fix squealing and scraping noise in my Kenmore gas dryer 110.74812200?
GOD IS GOOD !!!!
DRYER MAKES NOISES.
The blower:
The bearings:
Sep 21, 2014 | Dryers
Dryer squeeks & takes a long time
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Aug 24, 2014 | Dryers
Motor making noise
DRYER MAKES NOISES.
The blower:
The bearings:
Apr 15, 2014 | Frigidaire FGQ1442ES Gas Dryer
Kenmore 86582800 drum has a high pitched squeak after been on for 5minutes. 1983 model
see this steps and fix it. God bless you
Drive Belt
If the dryer makes noise, the belt may be frayed or damaged. If the belt is damaged, it will make noise every time it travels around the pulleys. The drive belt is a long, narrow band that wraps around the entire drum, then around a tension pulley and the motor pulley.
er
Drum Roller
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers. If one is worn out replace all of them at the same time as a preventative measure.
Drum Roller Axle
Over time the drum roller axles can wear out, causing the rollers to wobble. If this happens the dryer makes noise. If the dryer is making a rumbling noise, check the rollers and axles. If any are worn out, replace them all at the same time.
Blower Wheel
Drum Bearing
Drum Support Roller & Axle
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers or axles may be worn out. After removing the drum from the dryer, inspect the rollers and axles. If one is worn out replace all of them at the same time as a preventative measure.
Drum Support Bearing
The drum support bearing is at the rear of the drum. If the dryer makes noise check this bearing. If it is worn out, replace the entire bearing.
Drum Slide, Glide, or Pad
Drive Motor
Although not very common, if the dryer makes noise the drive motor may be worn out and the motor bearings can become noisy. If this happens the drive motor must be replaced. The bearings are permanently sealed and cannot be lubricated.
Jul 13, 2013 | Dryers
Kenmore electric dryer making loud noise when running
It sounds like the belt that goes around the drum. I have a similar Kenmore, and I get that same rotational thumping noise. The belt is probably about to break or come apart. If you take it off and run it trough your hands, I think that you'll find either belt separation, or a bad spot missing a chunk.
Fortunately the belt is a cheap item. I've kept my Kenmore dryer running over 20 years now.
Mar 18, 2017 | Kenmore Dryers
ED55 dryer making screeching noises
sounds like the rear tub bearing has worn out that would explain the noise and if it got too bad the bearing can break causing the drum to stick and not be able to turn
Nov 26, 2007 | Fisher and Paykel DG05 Gas Dryer
Dryers Logo
Top Dryers Experts
