Question about Carrier 38CKC042 Air Conditioner
Fan will run, but compressor wont come on. Not cooling at all. also blew a fuse. replaced fuse still same problem.
    Sergeant:
  • 340 Answers
Stop replacing fuses your wasting you money. short in the compressor Call for service.Tom
Posted on Jun 23, 2009
2012 power star has no aircondioner fan working in cab compressor blew up and been replaced now no fan working
check for a wire connection at the compressor that runs the incab fan
check for as fuse problem
Nov 06, 2016 | Cars & Trucks
My frige & freezer do not cool,light & freezer fan run,compressor & coil fan do not run,air is blowing out of air vent in freezer,no cooling at all
If the compressor isn't running, the refrigerator or freezer won't cool - period. Hopefully, by now, you've had a repair technician come and troubleshoot the problem.
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
What would be the top 2 reasons 1 of the outside 20 amp fuses would blow?
There are only two possible things that it could be. The compressor or the fan motor. The compressor is self contained and cannot be serviced. You just replace the whole thing. The fan motor can be replaced.
Jul 11, 2013 | Heating & Cooling
Tempstar Air Conditioner wont come on
Sounds like you need a new contactor in the condenser. The low voltage is grounded. Remove the low voltage (likely 2 wires) at the condenser and wire nut the wires leading inside. With an insulated screwdriver manually push in the contactor and be sure both compressor and fan run. Then replace fuse and turn power on to air handler with a call for cooling. Obviously the outdoor unit won't run because you unhooked the low voltage but if fuse doesn't trip then it's likely the contactor. Good Luck
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 10, 2017 | Heating & Cooling
Bought a used 93 mazda protege.(as is) A/C compressor does not start or engage.. When warmed up and running large primary fan is on. I fouund aux fan fuse removed from fuse box.under hood. I also found aux...
Sounds like u have a bad fan for 1,Im sure who disconnected it may have found an expensive problem they didn't want to deal with (electrical, ac compressor etc) Good luck, have it ckd
Apr 07, 2017 | 1993 Mazda Protege
Compressor wont turn on. fan runs central unit
first check you thermostat settings and make sure that it is on a cooling setting if ok it can be the fuse that sends the power to the outside unit if fuse is ok it can be the capasitor for the compressor if ok you may have to check the compressor for open windings or ground fault so you will have to replace the compressor or the relay which is after the thermostat
May 03, 2010 | Amana PTH153B50AE Air Conditioner
The cooling fans stop working
check your sensor that controls the cooling fans.may need to be replaced.
Jan 01, 2010 | 2003 Chevrolet Impala
Fan runs, cooling and heating do not.
sounds like capasitor blew, or bug or snake or someyhing got into compressor area if outdoor heatpump or unit, could be snails also. if so might have killed compressor or something else electrical
Jun 14, 2009 | Heating & Cooling
Frigidaire FRS2345AB9 Not Getting Cold Enough
Check the fan in the freezer side to make sure it is running. If the fan is running and you have frost, then you have a defrost problem, Heater is not coming on to melt ice. If fan is not running replace fan.
Mar 09, 2009 | Frigidaire FRS23H5AS Side by Side...
Carrier 38CKC042 Air Conditioner Logo
159 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
