Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Neither fan nor compressor will work. At first, it was just the fan. Took it off, hooked it up outside of the fridge and it workes. Cleaned it, put it back on, and now neither one works. The compressor was working when the fan wasn't, but was getting very hot to the touch. any ideas?? Ann
  • 1 more comment
  • alpartain Jun 23, 2009
    Nothing is iced over. It's been off for 24 hrs.
    No, because yours truly isn't that talented!
  • alpartain Jun 24, 2009
    It means "I don't know how to do that". It means "yours truly"...meaning me.....am not that talented.
  • 483 Answers
Had a same problem last year, the heat exchanger was iced over, took a hair dryer and melted ice. The defrost heater element had gone bad, had to replace it lately.
However, assuming that we have technical expertise please have the following componants tested with a circuit tester :
Defrost Timer
Thermostat
Overload Protector
Let me know if that helped.
Thanks
Fame !
Posted on Jun 23, 2009
  • 1 more comment
  • Sid
    Sid Jun 23, 2009
    All right that sounds like your problem is diifrent then what we faced,
    Did we try testing the componants though ??
    Fame !
  • Sid
    Sid Jun 23, 2009
    Hey,
    I am not sure if we understand that "No, because yours truly isn't that talented" ..
    what was that suppose to mean ?
    Please describe ... ?
    Fame !
  • Sid
    Sid Jun 24, 2009
    In that case there isin't much fixya can proceed with, you might wanna contact a friend/tech to perform what i suggested & things should work for you.
    Kindly rate the solution posted by us as it helps us to analyse the solutions.
    Thanks
    Fame !
Magic Chef Fridge & freezer not cold-both fans running-Compressor hot- cleaned drain tube-outside of fridg cold
Is compressor running continuously or is it clicking on and off every couple minutes? Is there any frost buildup on inside back wall of freezer?
Sep 26, 2017 | Magic Chef Refrigerators
RF267aewp french door refrigerator is acting crazy. Sometimes compressor fan runs, sometimes it doesn't same with freezer fans. Front control panel will not respond so I cannot get into diagno
Had same problem on my fridge a long time ago. Here is what was wrong on mine. Debris had clogged up around the fan blades to the point where the very small motor that runs the fan was not powerful enough to make the fan turn. When this happens the compressor has to work harder and harder until it finally shut down on safety cutout. I had to open the back of the fridge and clean up the fan blades, [ took the opportunity to put a small amount of oil on the fan shaft too, my Norge fridge is now over 50 years old.]
Nov 05, 2014 | Samsung RF267AEWP - 26 cu. ft. French Door...
Freezer side and fridge side not working, temps are freezer 30 fridge 50
Most likely the condenser coil is dirty. It is under the fridge, clean it with a vacuum, or air pressure, blow it out outside it will ne dusty . There are two to three fans. One by the compressor, called a condenser fan. If it is a side by side, usually there is a fan in the freezer section, and one in the refrigerator section. All need to work. If all this is and the compressor is running then chances are the compressor has bad valves. Make sure there is no ice on the coils in the refrigerator and freezer coils. If there is ice you have a defrost problem, which can be fixed. If the compressor has bad valves, get a new refrigerator.
May 08, 2014 | Maytag MSD2454G Side by Side Refrigerator
We had to move our Kenmore 18 fridge to install new flooring. When we hooked it back up, we noticed the 3 sides of fridge (freezer sides & top) were hot to the touch. We have a Kenmore18 with an...
its understandable that you fear the unit catching fire but in that the fridge must get hot in order to work. as the heat creates the cold but! in this case i would say your cooling fan placed at the rear next to the compressor has either stopped working or is in need of its blades being cleaned much like a cooling fan in the home when the blades get covered in silt it stops pushing as much cool air around its blades as per clean ones. so make sure the cooling fan turning on and give the fridge a good clean on the outside around the motor area. most importantly dont worry about fire the unit has many built in safety devices before that happens.
best of luck to you
please take the time to rank this repair
merry christmas
Dec 07, 2010 | Kenmore Refrigerators
Fridge and freezer not getting cold
If it was layed down to move and not let sit for a while before using it again it would not work. Somtimes leaving in off and let it settle will straighten it out but not all time. The oil in the compressor get into the cooling lines and blockes the freon. Other than that, check the condenser coil which are near the compressor. They should be warm when the compressor is runnin. If they are not warm there is a compressor or freon problem.
Sep 01, 2009 | Refrigerators
The freezer is working yet the fridge is not I
pull the frig out from against the wall and unplug then remove the cardboard backing be carful your going to put it back on and see what got lodged into the fan blade that cause it to stop when you cleaned the coils remove the object and plug back in ensure the fan start up put backing on push back
Aug 20, 2009 | Refrigerators
Fridge dont run
if all fan working check compressor call service
Mar 31, 2009 | Frigidaire FRS26R4A Side by Side...
Burnt smell inside freezer.
Generally speaking it is the refrigerator control that controls the compressor operation. Refrigerator is cooled by air from the freezer. When the refrigerator gets down to its designed temperature it shuts off the compressor. The freezer control determines how much air is allowed to flow into the refrigerator section and there-by controls the freezer temperature.
Mar 18, 2008 | Frigidaire FRS26ZSG
Hotpoint Mistral frost free fridge freezer.
This is a little hard for me to understand being a yank and all. 0C is 32 Fahrenheit, right so 4/5 is about 40? make sure everything is working, compressor , evaporator fan motor (the one inside) condenser fan motor (the one outside) if you have one. You should have an adjustment for freezer and one for the fridge sections, right. The fridge section controls what amount of cold air comes from the freezer compartment. Check the vents inside, make sure they are not blocked and they open and close when you adjust the control. If this all checks good then check the thermostat. If the compressor shuts off prematurely, then a new thermostat may be in order. If you think you can do this, find the thermostat, by-pass the wires. this will make the compressor run continuously. After 20 minutes or so it should make the desired temperature or close to it. None of the fans or compressor should turn off while this is by-passed.
Dec 31, 2007 | Freezers
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
81 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
