Sharp dv rw250h error C104 - Televison & Video
2 Suggested Answers
SOURCE: copying vidoe to dvd
Hi, if you still have the problem of unable to copy from video to dvd,then just follow these instructions, on the Remote, (when you have both the video tape that you wish to copy in the machine and the blank disc also in the machine ) Press the DUBBING Button(This is 2 buttons along from the Record button),almost immediately a message will pop up asking if you wish to copy VCR to DVD.
Hopefully this is of help to you. Regards. Gary
Posted on Feb 10, 2009
How do i select finalise on sharp dv-rw 250h remote control
If you are using the original remote or one which matches all of the functions, make sure that no DVD or VHS tape is being played and that the recorder is on. Make sure that there is sufficient space left on the disc. (The space needed depends on chapter/disc titles.) Then press Setup on the remote; it should be below the arrow keys but the position may vary. Use the Up/Down arrows to select System Setup and press Enter. Select Disc Setup and press Enter. Select Finalise and press Enter. Select Start with the Right/Left arrows and press Enter. Wait for the procedure to finish.
Note: only discs recorded on this particular device can be finalized on the DV-RW250H. On some other Sharp DVD recorders, the Disc Menu is accessed directly from the Setup menu.
I hope this helps.
Sep 20, 2016 | Sharp Televison & Video
Selective playing of DVD's on Sharp DVD Recorder
Given that the machine will read disks it has written itself but not play regular discs, I suspect the lens assembly is slightly out of alignment and needs adjusting. This is not normally something you can do at home unless you have the correct test gear. It will need to go to a repair shop. One thing you can try before that is to clean the lens. Buy a quality (Scotch 3M, Philips ) cleaning disc and try it. Could be it's only a speck of dust on the lens.....
Aug 01, 2007 | NAD C541 CD Player
Error code L4 30
L4 error code mean your copier motor fail problem.
Please press # Interrupt C interrupt press 16 press start key or print key.If are not fix this problem please check motor fuse or any kind of gear was broken.
Dec 16, 2009 | Sharp AR-M455N Copier
Mita AI-3010 with error code C104 after coming out of sleep mode.
indicative of faulty main board or firmware, can be updated with compact flash card
Jul 30, 2009 | Kyocera KM-1510 Copier
Sharp DV-RW340U will not record new dvds, give error message :E24
ensure you are using DVD-R not DVD+R discs. if what you are attempting the record is copyright protected, depending on the protection, you may not be able to record.
Feb 08, 2009 | Sharp DV-RW340U DVD Recorder/VCR
Copying vidoe to dvd
Dec 02, 2008 | Sharp DVRW250 DVD Players
Cameras
I took mine to an authorised repair center,but was of no help. The error generally shows due to IC problem OR the head has some issue. Do not try any DIY.
Feb 14, 2008 | Sharp Viewcam VL-Z3U Mini DV Digital...
Sharp DVD disc error
I've found out that the recording speed is important for this model. The speed on the dvd must be 4x or less. If your using an 8x or 16x it will not work. Hope this helps.
Maybe you can help me. I'm looking for the 4 digit code that goes into the remote to make it compatible. I think it's in the operators manual, which I no longer have. If you can find this number I would really appreciate it.
Oct 12, 2007 | Sharp DV-RW340U DVD Recorder/VCR
DVD recording or playing.
Where can you find the 1-2X DVD, I have only been able to find 1-4X and none of these work.
Feb 07, 2007 | Sansui VRDVD4005 DVD Player/VCR
Standby
If both decks have a disc or tape in it , the unit shut down because of a power supply glitch or a mechanical trouble shut down the system control system. One way to possibly get them out is unplug unit for a few hours or overnight even better. Before you plug back in press the eject button and hold it in while you plug it in. Dont let go untill the tape comes out. Now if it comes out then unplug the unit anf replug back in and wait a few secs. to let it reset and do its thing. then see if it will turn on and try to eject the disc. if this dosent work then its a power supply problem and its going to need serviceing unless you know your way aroundservo controls and power supplys . Remeber always unplug these units as they do have voltages on the primary side of the transformer that can bite ya. Good Luck
Jun 05, 2006 | Sharp DV-RW340U DVD Recorder/VCR
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
