Question about Sony RMT-V501E Remote Control
What to do when I accidentally press the sleep button and the remote doesn't work anymore?
I was trying to go into the next channel and I accidentally press the sleep button and when I try to go into the next channel it doesn't work any more.what am I suppose to do?
2 Suggested Answers
nuclearfish
  • 4 Answers
SOURCE: Can't change channels.
http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DOCS
you can also buy a universal remote and it might help you. keep in mind, the remotes don't always have the right buttons labeled, so sometimes you have to try all of them first before finding the right button to bring up the setup menu.
Posted on Oct 17, 2009
My Technika LCD32-229 is just over 12 months old and has suddenly decided not to respond to the remote or on/off control on the TV. If I turn of the power at the mains for 30 seconds or so, it will then...
HERE'S THE ANSWER TO YOUR PROBLEM:
The possible reason why your TV doesn't respond to your remote is probably the battery of your remote. Maybe it has been used up to it's fullest capacity, so try checking it up. In case, it has been used up, try to buy a new one.
The possible reason why your TV doesn't stay on is still your remote control. Maybe you have accidentally set it to "sleep mode." When it is set into sleep mode, it turns on just for a shorter time. It cannot stay on longer.
So, here's what you've got to do. Check your remote. When the remote works already, press the sleep button remote again. I hope it works for you.
Thanks.
Jul 23, 2011 | Televison & Video
My ilo tv will not change from channel 3. The
You may have accidentally pressed 'Favorite' on the remote which will lock the controls. Try pressing 'Favorite' to unlock the controls.
Jul 10, 2010 | iLO 2600 Television
Can this remote work with the Western Digital HD player? How would you find this code?
1. Manually turn on the device (TV, VCR, etc.) to be
controlled.
2. Press and hold the CODE SEARCH button until the
red indicator stays on, then release the CODE
SEARCH button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to
300 times) until the device to be controlled changes
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing CHANNEL UP changes
direction to forward again.
5. Press and release MUTE to install the code.
Jul 17, 2009 | Philips Magnavox MRU1400 Universal remote...
Sleep Timer on remote does not work
First try to access the sleep timer menu from the controls on the TV to verify the TV is working.
If that works then the remote has the problem.
Now try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
If this does not work, then you may need a new remote unit.
Mar 10, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Lost remote mrd 310
most universals will use this method.
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Nov 29, 2008 | Philips Magnavox Learning Universal Remote
My remote is driving me CRAZY!!!!!!!
1) Manually turn on the device to be controlled.
2) Press and hold CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
3) Press and quickly release the desired mode button (TV, VCR etc.) . The red indicator blinks off once.
4) Press the CHANNEL UP button repeatedly ( up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press the CHANNEL DOWN button to backtrack through the library until the device changes channel. Pressing CHANNEL UP changes direction forward again.
5)Press and release MUTE to install the code.
Hope it helps~
Oct 27, 2008 | Philips PM435S Remote Control
Thanks but i need more help
Don't be panic.
Check the batteries of your remotes control. FIRST
Be sure to aim the control to the sensor of your tv.
Usually you have one remote for your tv and the other to control the cable box or digital box.
You have to set the RMC10 again using the code of your tv Silvania (like the first time)
Then set your tv on channel 3
Another thing, be sure that you are hitting the right buttons.
The control doesn't work if you hit on the top any key instead of cable
What i mean?
The remote has on the top 4 key usually (tv, cable, vcr, aux, etc).
You must hit first cable to set the control to cable
1, Manually turn on the device(TV, VCR, etc.) to be controlled.
2. Press and hold the code search button until the red indicator stays on, then release the code search button.
3. Press and quickly release the desired mode button (TV, VCR, ect.). The red indicator blinks off once.
4. Press the Channel up button repeatedly(up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press channel down button to backtrack through the library until device changes channel. Pressing Channel up changes direction forward again.
5. Press and release Mute to install code.
Don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Let me know how it is going!
Oct 18, 2008 | Electronics - Others
Remote not working on TV
Try programming with Code Search:
Hope this helps :)
Jun 13, 2008 | Philips Televison & Video
Panasonic pv-df2704 27"
Try this:
2. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press the CHANNEL DOWN button to backtrack through the library until the device changes channel. Pressing CHANNEL UP changes the direction to forward again.
If it's still not working, these are the codes that are given for your tv on the phillips website: 0718, 0416, 0007, 0618, 0807, 0039, 0739, 0345, 0696, 0901, 0608.
May 29, 2008 | Philips PM435S Remote Control
Old philips tv model no 21PT1532/05
this may be too late, but i had the same problem, then discovered that if you press the top of the volume up/down buttons together, the menu comes up. I was trying to solve another problem this way when I accidentally locked the TV. The instruction booklet tells me that you can only unlock it with the remote control, but that has long ago bit the dust. Does this mean that I'll never be able to turn it on again??!!
Nov 03, 2007 | Televison & Video
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
