Hja8703 will not drain
The machine has stopped mid cycle and will not drain water. Have tried turning off and on trying different programmes, including empty water, but goes around for 10minutes or so then stops again. Once stopped it flashes two lights, start triangle and start delay button three flashes every ten seconds. Any idea what's wrong and how I can get my clothes back?
    Problem Solver:
  • 11 Answers
Before doing any of the below please try not to get any electric wires wet and make sure the plug is off oor better still unpluged....good luck.....tip be carefull not to pull any little wires off......it might have somethink stuck in the pump causing the machine not to empty the water (the pump is normaly found under the bottom of the washing machine) if you do undo the pipe going to the pump watch out because there is water in there most of the time.......also check the filter because somethink could be stuck in there (these are normaly found on the front of the washing machine under the bottom front cover).....be careful because a little bit of water comes out...
Posted on May 17, 2014
barkencoa
  • 3463 Answers
SOURCE: Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Posted on Jan 16, 2010
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
  • 9 Answers
SOURCE: I have a beko 5140w
check the timer..
Posted on Oct 11, 2010
  • 14 Answers
SOURCE: Error code E04? Doesn't drain or spin. Machine
SEIMENS FRONT LOADER ULTRA SENSE DRAINING PROBLEM
On my SEIMENS washer, which is about the same as BOSCH, the drain problem seems to be usually a small sock jammed in the intake of the drain pump, or possibly in a hose before the pump. I found a quarter and a couple of staples in the attached settlement area where junk settles to avoid jamming the pump. Also a lot of dirt.
On the lower front under the door, while facing the washer, is a round plate with a little hole in it. Put something sturdy, a little bigger than a toothpick in there, and rotate the plate about a 16th of a turn, maybe a little more, and it comes off.
Take duct tape or similar and tape up the edges of the hole and a nearly vertical bar in the hold on the left side, because the edges will cut your hand, like they did mine.
Inside the hole you will see a black turn knob inside. Turn it left very slowly, only after you figure out where the water will go, probably a small bucket or two of it. I used a 4" funnel which got most of it, I think, funneling into the bucket. Maybe you can be more creative, but it is what was at hand. Still got water on the floor out of the garage into the street. Turn left slowly, so it doesn't dump water outside of the funnel. You will see the water is brown, silt, dirt and stuff.
If you get a lot of water out, that means the blockage is probably at the pump. If you don't get water out, the blockage is probably in the hoses from the washer, which means you need to undo hose clamps going into the pump and clear the blockage. That is harder.
Most likely it is something in the pump area itself.
After most or all of the water is gone, and it doesn't seem to unscrew any more, tug on it and it will come out exposing the pump and probably the sock.
Remove the sock, and check the pump impellors to make sure they are intact. If gone, that means a new impellor and probably a pump. Then move the impellor, it should click as it moves and stop. If it does, you have found the problem. Sock blocking the outlet.
Carefully clean out the **** inside the pump settlement area. If you leave any of the sandy gritty clumpy stuff it can ruin your pump. Also clean the plastic thingy you pulled out, and make sure the threads and sealing surfaces are clean there too.
Then screw it back in firmly, and start the washer, without clothes. I would just fill it up, starting the cycle, until it starts to agitate, then go to the drain position
With luck, it will now drain. .
This will save you a service call for something easy to fix yourself.
Posted on Jan 31, 2011
  • 6277 Answers
SOURCE: My Candy washing machine stops
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 12, 2011
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
There was a power cut mid cycle after which the start/pause button just flashes but wont start.
Is it possible that the outage was caused by a power surge that might have killed your programmer?
May 30, 2015 | Washing Machines
It is a Bosch WFF2000. The programme stopped mid
circle at bottom right take it off there is a filter there remove it and look of obstructions.WATER WILL POURE OUT!
Jun 23, 2010 | Washing Machines
E20 fault display
E20 is a fault either in the filter/pump or drain.
The water must be drained thru. the little hose by filter or get machine to back door and undo filter plug and drain onto back step its quicker.With filter out see if any blockages,shine torch up in filter hole turn to spin/drain and see if pump blade spins if not then get long screwdriver and turn blade to free if no joy pump has to come out to free,hopefully this will work and refit plug and check for leaks.Then try again.
Good luck.
Apr 19, 2010 | Zanussi ZWF1420W Front Load Washer
Jan 16, 2010 | Hoover Washing Machines
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
Rotating programme unit stops mid cycle, all programmes
according to that i think the problem come from timer after you fix this problem pleas donot select your program during conncting electrical power thankyou
May 27, 2009 | Whirlpool AWM5145/2 Front Load Washer
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Washing machine keeps stopping mid cycle
If you found coins and such in the drain filter then there is a possiblility that the impeller in the drain pump motor was damaged and you are not getting good water flow thru it. The machine will error out and stop mid cycle if it detects it has not drained in a set amount of time. OE indicated a drain error. I suspect you need to have the drain pump motor assembly replaced.
Nov 20, 2008 | LG WD-1280FHD Front Load Washer
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
