Question about Bernina Bernette 75
My bernette 730 will do all the stitches required but only in reverse
Is it possible to replace the stitch length lever (22 in manual) on a bernina record 730?
Most likely. If the lever has been damaged, it may be found by picking up a machine (for parts or repair)--check eBay. Check with your Bernina dealer. Frequently, they will have parts from used machines.
Aug 24, 2016 | Bernina Sewing Machines
I have a bernette 720 with no instruction manual, where do I re fill bobbin?
You can obtain the manual on line free at: http://homeappliance.manualsonline.com/manuals/mfg/bernina/730.html?p=1
It may be useful in the future for other things once you get stitching. Enjoy.
Oct 12, 2014 | Sewing Machines
Bernette 75 won't Zig-Zag
Is there a stitch width setting and has to be set to a number greater than zero?
May 14, 2010 | Bernina Bernette 75
My Bernina 730 record can only run the zig-zag stitch. The tech said the motor was "weak". Will replacing the brushes in the motor fix the stitch problem?
Sewing machines needs full service now and then (every 10 years will often do). The motor on the 730 series is actually as powerful as they get on domestic machines, and handles just about everything that fits under the pressure foot. Only if the machine has been used a lot over the years are the brushes worn down, but it might need new grease not matter how little it has been used.
However, the stitch applications can sort of gum or clog up if the machine has not been used for ages. Take a look in the manual and oil ever point suggested every time you take out the machine. Try them now and then on slow speed, that might get every function to run smoothly again.
This is as good a machine as any out there, favorably compared to any new machine under 500£. It sews perfect stitches on just about any material, and is well worth a full professional service (At a shop they will always recommend a new machine they want to sell you). All kinds of pressure feet and accessories are available in regular sewing shops and online.
Check with different shops for price on full service. This is a great machine what ever they tell you.
Nov 20, 2009 | Bernina Bernette 75
Bernette 134D
Stitch length should be set between 1 to 2.
May 26, 2017 | Sewing Machines
Bernina 1630 problem
Your feed dogs sound like they are getting stuck,chec whether they are on the down position,and also make sure that you have cleaned any lint that builds up in the bobbin area, if all fails it will have to go into the technician,
Sep 01, 2008 | Bernina Bernette Deco 600
Sewing Machines Logo
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
