Question about U-Line Icemaker
No ice is being made, but the unit is on and water is hooked-up.
  • 286 Answers
Depending on the model you have. Your unit will run until the thermostat is satisfied. The it calls for water. Then the next batch will have ice.If its a clear ice then the unit should start to make ice right away. However it will take 5 cycles to get the ice the right size. What model is it?
Posted on Jun 24, 2009
I purchased a LG 24cu ft French door fridge, manual says it takes 12-24 hr to make ice. When I hooked up the water should it have filled the icemaker or will it do that after the 12/24 hr period?
it will take about 12-24 hrs for the unit to be at the controlled temperature that you want -during that time it will be be trying to make ice if you have water hook up turn on the ice maker -but it will take awhile since the unit wont be at temp for the ice to form and accumulate
Jun 29, 2016 | LG Refrigerators
Mbf2256heb maytag fridge My fridge seems to cool properly, but it is making this nearly constant buzzing or grunting sound that stops when you open the freezer (bottom) drawer. Suggestions?
Is you unit hooked up to water because if your unit has an ice maker and not hooked up to water currently, the ice maker will call for water about every 45 mins and cause this noise. To stop this action, lift the bail arm to the off position to avoid or stop this from occurring.
I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 24, 2013 | Refrigerators
Water (and ice) in storage bin.
What is the model number?
Jul 07, 2013 | U-Line Icemaker
Hoshizaki Model KM 630 MAE
Look for a stuck float switch. unit fills with water for 1 minute, then the board "looks" at the float to "see" if there is enough water in the unit to run. If float switch is stuck down, it tells the unit there is not enough water and the unit stays in the fill cycle causing the sump to overflow and send water down the drain constantly. Compressor will not run till the board senses that there is enough water to run.
Jun 25, 2012 | Hoshizaki Freezer Commercial Ice Machines...
How do I hook up water to my fridge
Ice your unit is ice and water capable, there will be a water inlet valve in the lower open portion of you unit. Just unscrew the plug keeping the dirt out and screw on the house water line.
Jan 15, 2012 | Whirlpool Refrigerators
How to turn on ice and water to refrigerator.
if water s hooked to unit and power is on the ice mker and water is auto . make sure the arm on the side of ice mker is down . . mm hope this help mm
Sep 02, 2010 | Samsung Refrigerators
Have a comercial ice machine ,dont know how to hook up!
You gonna have a drain for the reservoir to clean the unit and a drain for the ice bin and then a connection for inlet water. The water valve is the key. Look for it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 27, 2009 | Franklin Freezer Chef FIM70 Commercial Ice...
Ice and water not dispensing
check the water solenoid in the back of the unit where the water line hooks up. sounds like the solenoid is not powering to admit water to the ice maker or dispenser.
Jun 01, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Water and ice
you must hook up a water line to the bottom right rear of unit then push dispenser to purge air from lines, icemaker may need a day or two to purge itself before making ice.
Mar 13, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
U-Line Icemaker Logo
105 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
