Question about Pioneer DEH-P7800MP
I have the same problem i lost my manual an i can get to put my aux on can some 1 please tell me the steps on how to put in the aux...... (perika06) my stereo is the DEH-P7800mp pioneer
    President:
  • Pioneer Master
  • 1,114 Answers
I accidentally unplugged the hard drive, the DVD drive and the aux input without making a note of where they were attached.
As per your hard drive and your DVD drive, you should see the SATA(serial ata) ports on your motherboard. NORMALLY, these are marked starting with either a 0 or a 1... ex: SATA 0; SATA 1; these are used to help the motherboard use the right sequence as it boots up. ***THOUGH THESE PORTS MAY BE NUMBERED, THE BOOT DEVICE OPTIONS CAN BE MANIPULATED FROM INSIDE THE BIOS***
Now, as per your Auxiliary input, you should see printed on the board a port that says Aux 1. I assume you are trying to get the front USB\card reader port on the front of your unit hooked back up. If you will look at the pin configuration holes on the Aux cable then you SHOULD be able to match that up with what you have on the board.
Hope this helps.
If you need any further assistance please let me know.
Apr 15, 2016 | Computers & Internet
I have apex dt-250a digital converter box and I lost the remote. Purchased RCA universal remote and I have not a clue what codes I need or how to enter them. Can you help?
I programmed a Radio Shack 5-in-one remote to my Apex DT-250. Select cabel/satelite, hold p until the light blinks twice, then enter the code 0749. It works! If your universal remote uses a three digit code, use 749. If it uses a five digit code, use 00749. I HAVE A PROBLEM THOUGH... I don't know how to scan for channels! It says "please do auto channel search", but how do I do that? Please, if anyone has this answer, let me know. I finally programmed the universal remote, but it's basically useless without being able to do an auto channel search.
Jan 31, 2011 | RCA Televison & Video
I have an RCA RCR312W remote and lost my manual, request the steps needed to program my JVC tv / I have the codes, just need to know the steps to take ... Thank you
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
Thank you
Jan 16, 2011 | RCA RCR311B Remote Control
TRYING TO PROGRAM REMOTE IT IS A RCA REMOTE LOST INSTRUCTIONS TO REMOTE.
HI, Direct Code Entry:
Code Search: 1. Turn on the device you wish to control.
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote 2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Nov 08, 2010 | RCA Universal Remote Control
I HAVE A RCA 3 DEVICE REMOTE CONTROL AND LOST THE MANUAL.I NEED THE CODES TO PROGRAM IT. WHAT DO I NEED TO DO?
Thank you
Nov 06, 2010 | RCA Universal Remote 3 Device Remote...
I have a rcr312wr,I lost manual,I want conect it to dvd samsung...which is the code and the steps???
HI,
Direct Code Entry:
Code Search:
Thank you
Sep 15, 2010 | RCA 3-Device Universal Remote with...
Lost the manual,i don't know what steps to take to program my rcr412bn remote? to my sharp tv.
HI,
Direct Code Entry:
1.Press and hold "CODE SEARCH".
2.Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3.Enter the 3-digit code number.
4.Release "CODE SEARCH".
With the device on, press another button to test. If it does not work, repeat steps 1 thorugh 5 with other codes.
follow the below steps to set remote with out codes
Code Search:
1.Turn on the device you wish to control.
2.Press and hold "CODE SEARCH".
3.Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5.Press ON/OFF repeatedly until the device turns off.
6.When the device shuts off press and release ENTER.
To get the code please go to below website
http://remotefinder.rca.com/default.aspx?site=rca
Thanx
Jul 26, 2010 | RCA Universal Remote Control
RCR460 Remote Control: I need to know how to program my rcr 461 to my tv....
Please follow the below steps to set up your programme
Direct Code Entry:
  1. Find the code your device.
  4. Enter the 3-digit code number.
  5. Release "CODE SEARCH".
  6. With the device on, press another button to test. If it does not work, repeat steps 1 thorugh 5.
Code Search:
  5. Press ON/OFF repeatedly until the device turns off. You may have to do this up to 100 times.
  7. Try using the remote. If it does not function repeat steps 1 through 6.
Please
Provide model of your remote
device to be programmed(VCR,TV)
Make name(toshiba,sony)
Thanx
May 16, 2010 | RCA RCR460 Remote Control
My olevia tv and Ge Remote control wont work lost code. Help?
USING CODE SEARCH FUNCTION
If your TV, VCR, DVD, etc. does not respond after you have tried all the codes
for your brand or if your brand is not listed, try searching for your codes by
following the steps below.
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR
LIGHT lights, then release.
3. Press and release the device button for the device you are
programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will
blink once then remain lit. For AUX, press AUX then the device
button you are assigning to AUX.
Feb 01, 2010 | GE JASRM24912 Remote Control
I lost my codes and directions on how to program my universal rca remote
Hi ,
I have given the following links which have the step by step process for programming universal rca remote
http://www.thompsontv.com/rcarc.html
http://www.ehow.com/how_9191_program-rca-universal.html
Thank you!!
Jul 22, 2008 | RCA Audio Players & Recorders
Pioneer DEH-P7800MP Logo
269 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
