Question about Sharp Aquos Televison & Video
HOW TO FIX THE SOUND ON MY SHARP AQUOS LC-37D4UJ LCD HDTV
HAS PICTURE BUT NO SOUND WHEN I TURN IT ON YOU CAN HEAR POPING NOISE BUT ONLY WHEN I FIRST TURN IT ON THEN NO SOUND
    Top Expert:
  • Sharp Master
  • 75,581 Answers
It's normal, and there is no fault with your set.
Gopakumar Gopalan Google
Posted on May 17, 2014
SOURCE: LC-37D62U Sharp Aquos HDTV Settings
lost sound on Sharp Aquos 37LCD62U
Posted on Jan 25, 2008
bshldn
  • 736 Answers
SOURCE: Sharp AQUOS 52" 1080p 120Hz Flat-Panel LCD HDTV
Press the menu button and scroll over to the setup sub category. Scroll down to reset and press enter. Select yes and then enter. Select yes again and press enter. The television will turn itself off and then back on.
If that basic reset doesn't work call 877-332-7867 to be walked through the no sound troubleshooting up to an INIT. I cannot put the steps for an INIT into print because any wrong move could erase everything from your television.
Posted on Dec 29, 2010
SD Tech
  • 14553 Answers
SOURCE: Unlocking the remote and panel for Sharp Aquos LC-46LE832U 46 in. HDTV LCD TELEVISION
When all else fails read the owner manual page 35:
"• To unlock the buttons on the remote control by using the
touch sensor panel of the main unit (see page 25):
1 Press MENU to display the MENU screen, and then
press VOLl/k to select "System Options".
2 Press CHs/r to select "Operation Lock Out", and
then press INPUT.
3 Press CHs/r to select "Off", and then press INPUT.
4 Press MENU to exit.
• To unlock the buttons on the TV, press MENU on the
remote control, and then select "Off" in "Operation Lock
Out".
Took 5 minutes to find the manual for this unit. GOOGLE
Posted on Apr 05, 2012
SOURCE: no sound on my sharp aquos lc-45gd4u 45 in
Assuming you are using the internal speakers, check and make sure you have the audio enabled. Some TV sets have a option to turn off the internal speakers. Also make sure mute isn't turned on. If you are using external audio setup, double check your connections.
Posted on Nov 25, 2012
SOURCE: Sharp Aquos LC-37GD6U 37 in. HDTV LCD.
i need to study more about lcd/plasma tv and how can i get the spair part as motherboard/powersupply/ccfl/screen mirror
Posted on Jan 23, 2014
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
No sound on my sharp aquos lc-45gd4u 45 in
Nov 24, 2012 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
No picture no sound opc light and power light
This is very common in sharp tvs.U turn it on.U get power on light stable right?U hear a click,one or twice,sometime tv is good right?Sometime POWER light and OPC light flashes?Push the power button on/off couples times will work, picture will come on.If keep trying off/on couples time after POWER and OPC flashes,don't ever stop and never get backlight and picture.Ur Video backlight board is dead must replaced.
Dec 28, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
The power light and OPC light flash but TV won't turn on. On my Sharp Aquos LC-C5255U
try making sure tht tha scart or HDMI cable is securly fitted (depending on which one u using) and this suld solve loss of picture or sound
Jun 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquous will not turn on.
I would check the System Cable that is linking the box to the TV. Then, press the small button called CLEAR in the front of the box. The button should be behind the flip cover on the front right below the PC input ports.
Let me know if this solution works.
Jun 01, 2009 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Sharp aquos lc-52se94u green screen
If it it new, take it back. The product is not working properly.
Apr 30, 2009 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
Speakers making a constant poping noise.
this could be due to some static  please get your electrical point checked up 1st  is your tv hooked to watch television thru RF or AV please have the interlink cables if this does not help get back with more details
Oct 15, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No sound
there many lesson for u are problem, try to change the cable in audio in,if doesnt work try to see expers near you.
Oct 30, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos lc45gd5u
perhaps the power inlet cord or the scart cord needs replacing or perhaps you have a faulty pixel generator. try and replace them if that is the problem. find out first! good luck!
Sep 11, 2007 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Televison & Video Logo
49 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
