Question about GRY Viore RPT50V24DHD 50" HDTV DLP TV
Viore tv shuts off as soon as powered up - GRY Viore RPT50V24DHD 50" HDTV DLP TV
I have a viore lcd tv and i dont have the remote the issue is that i cant get to the hdmi with the tv/av button. It just goes to the menu or it shuts off the tv
Don't you hate that, now-daze most all functions are available only with the remote. Here's a link to ebay, selling Viore remotes, find your model....it's the only cure.
http://www.ebay.com/bhp/viore-tv-remote-control
Apr 25, 2017 | Viore Televison & Video
42 inch viore smart tv works great but then just shuts off ?
it may be interference with other remote operated items within say 300 ft of this tv..like celphone signals..or some electrical issue creating an electromagnetic field strong enough to makle it work funny..check all electrical components for interference issues..
Jan 07, 2014 | Viore 42" 1080p Led42vf80 Lcd Led Hdtv
My viore tv shut off by it self.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, I suggest it is better to refer it to a qualified service
technician, since the back cover has to be opened for investigation/rectification.
Aug 21, 2012 | Viore 22" LED LCD HDTV
I'm trying to reset my viore tv but it want stay on long enough
My Stand By light,Timer/Temp light,Lamp light is blinking. My T.V will come on for just a few minutes then it shuts off. then my lights flash on and off.
Mar 12, 2011 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
My Viore clicks like its gonna come on then it shuts down after 3 sec. What could the problem be?
Its the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.]
This will help.
Aug 11, 2010 | Toymax Viore 42 in. Plasma TV
What is the code for cable remote
Viore told me that they do not have a code that can be input into any remote. I have two Viore TV's... just bought my 2nd a few days ago. You will always have to use the Viore remote to power up or just turn off the cable instead. Not sure that turning off cable completely turns off the TV though.
Jul 31, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
Need code for Viore TV to program LG RC897T DVD/VHS Recorder
I believe Viore is the same as Samsung. I only noticed this by accident as I bought a Viore TV and my friend bought a Samsung and I noticed both remotes were identical. I tried the Samsung codes and the remote worked. Good luck! Kevin
Dec 29, 2008 | LG RC897T DVD Recorder/VCR Combo
Viore 52' TV randomly shuts off. front lights blink then stop.
I am having the same problem with my PRT50V24D shutting off and blinking lights. After going to viore.com and calling the number listed, I got recording to call another number. When got rep on line I was told it is made by Samsung, Called their tech support and was told that sounds like power problem or bulb getting ready to go. Also if outside of warranty will have to call repair man to see what's wrong. I will have a repair man out next week and will post his results here. Most likely it's the same issue. This is the tech support number for Samsung 1-888-697-2247. Good Luck man. Matt
Dec 05, 2008 | Televison & Video
Viore DLP TV
The lamp is most likely over heating. Check the fan in the lamp assembly compartment. Its located in the rear of the tv... try removing the lamp compartment and replacing the fan.
A quick fix is to put a small 7-10 inch box fan with its back flush to the lamp
compartment's vent - this will draw the heat out.
Sep 10, 2008 | LG 42LC2D 42 in. LCD HDTV
GRY Viore RPT50V24DHD 50" HDTV DLP TV Logo
54 people viewed this question
Top GRY Televison & Video Experts
Paul Bade
Ronny Bennett Sr.
Ronny Bennett Sr.
Starnley Johnwells
Starnley Johnwells
Are you a GRY Televison and Video Expert? Answer questions, earn points and help others
