Question about Samsung RS2534 Side by Side Refrigerator
The unit won't stay on.
This is after a month of having the lower freezer door won't stay closed and water drains out of the bottem of the unit. Now the unit won't stay on.
    Scholar:
  • 73 Answers
If the refrigerator wont stay on the start relay may be defective. This may have been caused by the leaking door that overloaded the system. The relay is a small box mounted to the side of the compressor and provides power to the compressor start winding for a split second at start-up to help get the compressor get started. If its defective the compressor may run off and on (a lot) or not at all and the refrigerator will not get cold enough. Fairly easy to do and reasonable
Posted on May 17, 2014
2 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: freezer drain freezes closed which
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 13, 2011
Why Bottom freezer drawer wont stay open
Freezer and refrigerator doors aren't usually supposed to stay open. The units are usually installed so that they're slightly tilted to the back to make sure gravity will close the doors if you forget to. If you are SURE - I mean really SURE - that you want your freezer to stay open you should check the drawer rails to see if they're adjustable; if they are, trying raising the back of the rails (or lowering the front). If the rails are not adjustable, try adjusting the front feet of your fridge so that the front of the whole unit is just a tiny bit lower than it is now. Don't lower it too much! If you do, the doors won't stay closed; they'll leak cold air and you'll lose food.
Jul 18, 2014 | LG LMX31985ST Super-Capacity 4 Door French...
FRIGIDARE FRS26ZSEB: Freezer side, bottom collects ice and then leaks out the door.
If you get ice in the freezer, start checking if the evaporator fan and the defrost system is working.
Try doing a complete defrost, ofthen this can solve the problem.
Cause for ice in the fridge can be evaporator/defrost syste, bad gasket, faulty thermistor.
Sep 14, 2008 | Frigidaire Refrigerators
Why won't the unit stay on?
Fridge FAN CONTINUALLY STAYS ON OR SHUTS OFF WHEN DOOR IS OPENED:
NORMALLY WHEN THIS HAPPENS U EITHER HAVE A DOOR CONTINUALLY OPEN ISSUE OR A BAD DOOR SEAL LETTING AIR IN AND CAUSING FAN TO OVERWORK ITSELF. ANOTHER CAUSE CAN BE DIRTY COILS AND CONDENSER AND LASTLY NOT TO COMMON IS A SHORT IN THE FAN SYSTEM ITSELF. A MORE PROBABLE CAUSE COULD BE BAD THERMISTORS OR EVEN COLD CONTROL THERMOSTAT ( WHEN THE THERMISTORS OR THERMOSTAT DO NOT GET/GIVE A PROPER READING, THEY CAN CAUSE THE FAN TO CONTINUE TO OPERATE AS THEY FAIL TO RECOGNIZE OR REGULATE THE PROPER TEMPERATURE.
May 17, 2014 | Samsung RF217ABBP Bottom Freezer French...
Amana freezer door doesn't fully shut
There is a drain inside the freezer part of the arb2257csr. The drain can get clogged and the water from the defrost process will pool up on the bottom of the freezer. You can gain access to the back of the unit and remove the pan drain to clean it out. Then make sure water flows and ice is not blocking the drain. It takes a long time to melt so I used a turkey baster and put hot water into the drain from the lower inside middle of the freezer. This drain pan can get pretty smelly when rancid oils and such don't evaporate the way it was designed to evaporate the water. The symptoms were ice on the inside bottom and water pooling in the front of the drawer. It also became very hard to close the door due to the frozen door slide. I have not seen anyone report this on any site so far. Everyone talks about the thermostat but no one seems to have arteriosclerosis of the drain tube.
Apr 15, 2013 | Amana Refrigerators
I have a Kitchenaide Superba side by side refrigerator model #KSRB25FKSS02 and for the last 2 months nothing seems to last more than 3 days in the frig side (it seems warmer), and there is water leaking...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Nov 05, 2009 | Cars & Trucks
Water leaking from freezer into the bottem part of the fridge and into the crispers
Oct 29, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Automatic defroster stays on to log and water runs
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
Oct 23, 2009 | Refrigerators
GE side by side leaks water from icemaker tube
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer door won't stay shut
This indicates that you do not have good airflow and return airflow between your freezer and refrigerator sections. That is why the pressure from closing one door is causing the other one to pop open.
Check the drain tube on the back of the machine to make sure it is not clogged or blocked with frozen water inside. Also check any return air flow vents inside the unit for clear ice.
Jan 18, 2009 | Refrigerators
Samsung RS2534 Side by Side Refrigerator Logo
44 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
