Question about HP LaserJet 4250 Printer
Fuser output paper stopped jam - HP LaserJet 4250 Printer
Soulvisitor
  • 1113 Answers
SOURCE: HP LASERJET 4250n PRINTER-PROBLEM WITH PAPER JAMS AND "FUSER ERROR"
Put a maintence kit in your machine, easy install, everything just clicks in, Every 200 000 prints it should be done, it includes the fuser, all feed rollers, sep pad and transfer roller.
These are great printing machine, they only ever need the MK and on this model a fuser drive gear wears and get noisy, but once that has been done once, it is ok from then on.
KIts seem expensive but they are meant to last 200 000 prints and usally do. These are one of the best most reliable printers in the market.
fee693c.jpg LINK to part info
Posted on Jan 09, 2008
Printerguru
  • 10 Answers
SOURCE: hp 4250 paper jam erro
Is it a new or refurbished fuser? Where exactly does it jam. By trays, registration or before fuser? Problem can be with various sections. Need to know more.
Posted on Feb 13, 2008
  • 42 Answers
SOURCE: 4600 color replaced fuser get paper jam error
Check fuser for broken tabs that would engage sensors.
clean 3 sensors behind fuser with a blowerbrush or makeup brush.
make sure you did not break output full bin arm on back of fuser{happens a lot}.
need more help? just ask.
Posted on Aug 26, 2008
  • 66 Answers
SOURCE: HP Laserjet 4100 series , paper jam output tray
Hi F_bulsara,
First thing to try is to flip the paper over in the input tray. There are 2 sides to paper. One side may curl a bit too much due to heat of the fuser and get caught near the output rollers.
Unless the Output Assembly was assembled wrong, it is impossible for the rollers to turn the wrong way. The gear in the fuser drives the output assembly. The top rollers are rolling out.
If the rollers are not rolling, then one of the gears must be broken or missing. The output rolllers might need cleaning.
Next check the fuser unit. Disconnect power to printer and turn printer round. Remove the back output tray and the two small covers (left and right). Undo the 2 screws that hold the fuser in place. Pull the fuser out. Check the gears on side of the fuser. A broken gear in the fuser could cause this problem.
S88
Posted on Dec 18, 2008
SOURCE: HP laserjet 5500dn paper jam at fuser
I was able to fix my problem. On the left side of the fuser assembly there are two small plastic tabs or flags that move up & down. One is attached to the plastic rod/flap that you can see from the top of the fuser and moves when the paper comes out of the "chute". The other tab, which is below the first tab and moves when the paper has passed some point in the fuser, was broken off. I glued the tab back on and now the paper is ejected from the printer like it is suppose to.
I'm thinking that the broken tab was part of a page sensor flag that would tell the printer to stop rolling the fuser assembly when the paper was ejected. Without the flag, the sensor would disengage the fuser prematurely and stop ejecting the paper while the paper was still in the fuser.
Charlotte
Posted on Apr 21, 2009
My paper keeps jamming
I can't believe no one has mentioned the fuser yet. Is the first page actually making it out all the way or is it stopping in the output?
Feb 27, 2015 | Brother HL-2040 Laser Printer
Paper Jam errror
Jam in output bin - duplex area
Error message
Jam in output bin
alternates with
Open door and clear jam
Description
Paper jam in duplex reversing area
Action
  1. Clear the jam.
  2. Press the (SELECT) button on the control panel.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Jam in output bin - fuser area
Error message
Jam in output bin
alternates with
Description
A paper jam has occurred in the output bin near the fuser area.
Action
  1. Clear the jam.
Goodluck..
May 14, 2008 | HP Color LaserJet 2600n Printer
Paper jam cartridge area
If it's a new printer, you may be using incompatible media. If the paper stops so that part of it is past the toner drum and part of it is before the toner drum, then the feed-roller assembly is not feeding properly. If the paper stops at the fuser, then the fuser rollers are not picking up the paper the way they should.
If there is toner on the paper, or part of it, but it just stops before it reaches the output tray, the output rollers are probably worn. If the printer sat unused for a long time, the rollers can dry out and not grip the paper correctly.
If the paper doesn't make it into the printer at all, the feed roller and separations pad are bad. I hope this helps.
Jan 20, 2014 | HP LaserJet P2055d Printer
Charlotte
Apr 17, 2009 | HP LaserJet 5500DN Printer
HP LJ P3005 13.31.00 ERROR
As i can understand whenever you try to print with rear door closed printed page should come on top from top output roller however paper gets jammed.
Solution:
Try to print a page using rear door open and it should come out from the rear drop down tray it printed page comes out successfully with rear flap open than paper gets jammed at top due to faulty top output roller.
However if the paper gets jammed at fuser with rear door closed than it is issue with fuser in that case you need to get fuser replaced at the same time replace 20 tooth gear next to fuser.
Thanks and Regards
Neeraj Sharma
Apr 11, 2009 | HP LaserJet P3005n Printer
Hp 4100 paper is jammed between rollers the back panel should come off? and then how do I get fuser out to unjam paper
Hi Jacque,
I gather the paper has got into the fuser and cannot get into the output bin. Few things...
1. Clean output rollers. Are rollers moving?
2. Check gears on the fuser unit. Any broken or worn gears?
3. Check default paper size setting in printer, paper size setting on tray, paper size setting in printer driver and document page.
4. Leave the back door open. Does the printer still jams? If it does, see it could be paper pick up problem. Use different trays or the manual feed. Also the fuser unit could be the problem.
5. All else fails, replace the output assembly.
Rgds
S88
Dec 18, 2008 | HP LaserJet 4100 Printer
Brother hl-2070n; Paper jams half way through drum unit.
Usually there is a sensor right before the paper enters the fuser. If the paper sensor is bad the machine will stop feeding and output the error paper jam. This is probably the cuase if the paper stops in the same position all the time.
Nov 19, 2008 | Brother HL-2070N Laser Printer
HP Laserjet 4100 series , paper jam output tray.( on top of the printer ). The roller under the topcover is turning the wrong way. The paper can't get out of the printer, and jams between the upper roller...
Hi F_bulsara,
S88
Nov 18, 2008 | HP LaserJet 4100 Printer
Aug 14, 2008 | HP LaserJet 4600dn Color Printer
HP LJ 1020 Output Page Jams @ Fuser input
either your fuser is bad or output rollers, I put my money on the fuser
Mar 26, 2008 | Office Equipment & Supplies
HP LaserJet 4250 Printer Logo
29 people viewed this question
Seeker5211
Seeker5211
