Question about Electrolux Washing Machines
Problems electrolux ewf1083
Error code E94
  • Electrolux
    Electrolux May 21, 2014
    Good Morning Friend, I understand that you are receiving an E94 error code on your Electrolux washer, model# EWF1083. This appears to be an Australian Electrolux dishwasher; however, if you have a US Electrolux model, I would suggest resetting your washer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power is restored, if you are still receiving an E94 error code, I suggest contacting the manufacturer for further assistance. Hope this is helpful. -Best Regards- WP
  • 327 Answers
SOURCE: Hi, Our Electrolux EWF1083 is not spinning and ...
Hello,E20 is "A problem with water draining"
Solutions:
The drain hose may be squashed or kinked
The drain pump may be blocke.check www.serviceforce.co.uk
Thanks
Posted on May 21, 2010
SOURCE: TRYING TO FIND AN ELECTROLUX EWF1083 MANUAL
You can download from here: http://www.electrolux-ui.com/2008/147/143581EN.pdf
Posted on Feb 25, 2011
SOURCE: My Electrolux Front Loader EWF1083 displays E20
E20 means problem draining. Clean the drain pump filter and check the drain hose.
you can download a copy of the manual here: http://www.electrolux-ui.com/2008/147/143581EN.pdf
  • 6277 Answers
SOURCE: Is a user manual available
Unfortunately this forum does not supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
Posted on Mar 26, 2011
  • 123 Answers
SOURCE: Where can i get a manual for electrolux ewf1083 front loader
You can download one from here:http://userguides.50webs.com/
They carry every electrolux manual ever produced.
Posted on Mar 02, 2013
I have an error code of E94 on my intex portable spa what does it mean?
If alarm code E94 is displayed on the control panel, it means the water temperature is too low. If alarm code E94 appears, unplug and plug back in the GFCI/RCD and test the GFCI/RCD to restart the system when the spa water temperature is higher than 39?F (4?C).
Jan 25, 2016 | Intex Pool & Spa
Model EWF1048W. Won't start. What does error e94 indicate?
E94 - Washing cycle configuration error.
Incongruence of configuration values at the switching on of the appliance. Check that all the connectors are inserted correctly.
Possible configuration error. Replace the circuit board.
Dado
Dec 12, 2015 | Electrolux Washing Machines
Electrolux time manager 7kg washing machine keeps stopping mid cycle and has an error code E94
E94 means: "Console control problem. Replace control board."
However fault codes are not absolutes. They simply tell a service person where to look for a problem. For example, if i was a service man and i had a control board like yours on the truck i would switch it out first to see if it solved the problem. If it did i would charge you for the part and labor and be on my way, even if it was just a loose wire or connector that was causing the problem. Or if i was a washer warranty rep and the machine was under warranty and you said you were getting an E94 fault code i'd ship you a control board and consider the problem solved.
I am not a service man or a warranty rep so my advice is to wiggle the wires going to the control board. Also, disconnect then reconnect any plastic conectors you see. Let me know.
Jan 30, 2013 | Electrolux Washing Machines
Electrolux ewf1083 stops mid cycle displays e10 .press start button and continues but can happen up to 4 times per wash.any ideas?
We had the E10 error on EWF1083, I opened the top cover and looked into it. It's the 2 way solenoid valve and should be a easy replacement. Looked on ebay and $59 for the part ex postage
Oct 12, 2011 | Washing Machines
Solutions:
Thanks
May 19, 2010 | Washing Machines
Where can i get a manual for electrolux ewf1083 front loader washing machine
May 14, 2010 | Washing Machines
Error code E94 paper jam
I used compressed gas duster to clean the resgister and it worked. It is called Duster Destroyer and I got it at the Staples for $9.99
May 30, 2008 | Casio Parts Cash Register PC Desktop
Washing Machines Logo
16 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
