Question about Health & Beauty
Autogo 550 MY BATTERY IS CHARGED BUT I STILL HAVE NO LIGHTS OR HORN ETC WHAT CAN THE PROBLEM BE?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
If you are not getting any lights/horn, check all connections and ensure they are properly connected including the batteries.
Posted on May 21, 2014
Need to replace key switch for my Auto go 550 Ultra lite scooter
Autogo Vision (Autogo 550) - YouTube
? 2:06
www.youtube.com/watch?v=ljs0x1BMaCk
Aug 12, 2014 - Uploaded by Marc's Mobility
Autogo Vision (Autogo 550) ... model shows a quick release mechanism to remove the drive train but it's not made any more so i'm informed.
Aug 05, 2015 | Health & Beauty
How do i change my wiring for my autogo 550 to adapt it to a trickle charger. it now has 4 wires , I need 2 wires?
this scooter uses lead acid batteries
this type of battery much like a car type
uses constant voltage
like 13,8v from a car alternator
so a trickle charger is no use and wont work
as it only provides a constant current and not a constant voltage type senario for the charge up
use a car battery charger
problem solved for about a fiver....
the scooter will need eather 12v or 24volts
so you need either a car charger or a truck battery charger
at least 15 amp @ 13.8volts...
Sep 14, 2014 | Radio Communications
When battery is being charged the dis light keeps coming on
charger or batteries are dud, or short in the wiring, check all wiring for shorts, check to see if you can charge the batteries with a car charger one at a time, if they charge and hold that charge then you need to replace the charger, if they will not hold a charge or you have a similar problem with the car charger, then the batteries are dud and need replacing,
Aug 25, 2013 | Electric Mobility AutoGo Power Folding...
My Suzuki GS 550 Horn don't work.
CHECK FOR POWER AT HORN IF YOU HAVE POWER THE SWITCH IS THE GROUND.OR IF YOU GET POWER WHEN YOU PRESS THE SWITCH. IF YOU HAVE BOTH POWER AND GROUND WITH THE SWITCH PRESSED REPLACE HORN
Feb 22, 2013 | Suzuki Motorcycles
Have a1993HondaShadow Stopped at storean won't start,nothinf will work.Lights horn Etc.
First check the main fuse, then battery connections,then check battery for voltage,ignition switch. If your battery went dead you need to check the charging system.
Oct 26, 2012 | Motorcycles
I have a Boreem 49cc, new battery but lights, horn etc don't work?
Your alternator might be bad. Check if your alternator is functioning well.
Apr 13, 2012 | Cars & Trucks
Battery for whistler WGPX 550 Gps unit won't
Look for a Fuji NP-60 battery as its a direct replacement.
Sep 28, 2009 | Whistler WGPX-550 GPS Receiver
883 wont start
The battery might just be done or warn out, if you get lights when you turn the key on, and can honk the horn and everything, then it should click, if you are able to honk the horn and lights etc. and they aren't real weak, when you hit the starter it should tick, if your lights are bright and horn is loud and brake light responds quickly, then I'd ask a Harley dealer about it.
Aug 11, 2009 | 2004 Harley Davidson XL 883 Sportster
Ducati 620s - Won't Start - Dead
The battery has died over the winter. Indicators staying on is a sure fire signal of low battery charge.
The battery may have enough amperage to get the headlight and the horn working, but the indicator relays take a bit more.
New battery I'm afraid.
Feb 22, 2009 | 2003 Ducati Monster 620s i.e.
Vivitar DVR 545 - Is this going to work with my MacBook?
I have a VIvitar DVR 545 I can not find out how to recharge the rechargable battery
I just bought this camera and had the same problem.
How DO you charge the battery???!!!
Here goes:
Open the box the camera came in and you should find a little rectangualr black box and a 3-pin plug.
Ignore the other stuff unless you think you may need it (depends what country you're in and what your mains supply wall socket fittings are). Take a close look at the little rectangualr black box and you'll see a slot in it. That's where your battery goes! Remember the battery must be taken out of the camera and slotted into this box! Make sure you align the battery correctly to the litle pins inside the box.
The Vivitar DVR 545 uses a sort of mobile phone/cell phone battery.You must take the battery OUT of the camera. Now you have slotted the battery into the box you connect the 3-pin plug to the box and then insert the plug (attached to the box) into your wall mains supply socket. The box will light up and you'll see a red light. Once this light turns green your camera battery is charged!
RE-INSERT THE BATTERY INTO THE CAMERA.
The whole charging procedure for the DVR 545 is ridiculous but there it is! By the way one drawback about having to remove the battery from the camera to charge it is that you will lose all or most of your camera settings. remember to reset video and photo settings - resolution, flash etc., etc.
Also a word of caution:
The Vivitar DVR 550 is unusual in that the battery is charged using the USB port. If you also happen to have a DVR 550 do NOT attempt to charge the Vivitar 545 using the Vivitar DVR 550 USB charger cable!
You will destroy your DVR 545 in seconds!!!!
Jul 09, 2008 | Cameras
Health & Beauty Logo
79 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
