Question about Canon imageRUNNER 5000 Copier
What maybe the reason why Canon IR2010 & IR271 having data error problem?
3 Suggested Answers
  • 71 Answers
SOURCE: canon ir2010 marca error.00000000 no imprime
Error 0000000 is the fixing unit, need to replace.
Posted on Jan 02, 2011
  • 109 Answers
SOURCE: Hie, i have a problem with two printers, the canon
Error E000
Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000
Error "check printer cover"
I think your problem is fairly simple if you have technical background. just check door compartment carefully there is a plastic part which presses the sensor switch or cover the optical sensor may be broken.
If not, then take a digital meter and ground the common probe and positive probe touch to the related sensor.there are two type sensor 1) switch type 2)optical, that they use.
If the switch type is used, when door is open voltage is 0,door close voltage is 5 volt although this may be reversed.
In the optical sensor case, one side is diode that is on 1.5 volt and other side photo transistor.
connect probe to trs side to collector or emitter depending on what biasing they use, then open door and see if the emitter goes high or low, repeat in door close position also if it goes properly high and low, if not then some other part is faulty.
If you are not sure how to do this then call in a technician
Posted on Jul 26, 2011
My Canon 2010f in error 0000
I found this for you.
I can clear error code e000 of ir2010
press *function and # and arrow to #7 press ok and #4 printer reset press ok
May 09, 2015 | Canon Office Equipment & Supplies
How can i fix an E007 error code on CANON IR 2022?
As far as i can work out, an Error Code 007 on the Canon IR 2022 photocopier means there is a problem with the "Fixing Assembly".
To reset the code hold the * key then press 2 & 8 keys at the same time.
If it reoccurs then possible reasons for the error are a torn sleeve in the mechanism or the film roller is not working. To fix means disassembling the fixing mechanism. If it is a ripped sleeve then replace it. If it isn't then try greasing the roller mechanism.
Just to note that it is maybe a good idea to clean the all the temperature sensors with ethyl alcohol while you have the unit apart.
Sep 18, 2014 | Canon iR 2022i Printer
How can I fix data error in IR271/ Ir2010
Whenever I experience data error with my photocopier machine, this is what I do.
1. unscrew the machine from the back panel removing all the plastic casing.
2. Get a blower and a dusting brush and clean all the dust particles and tonner that has fallen on the circuit board.
3. brush off the dust particles from the sensors and use a blower to blow off the dust.
4. Perform an indepth cleaning.
5. Re-assemble all the parts that was taken off.
6. Power on the machine. I hope this will work.
May 14, 2014 | Canon iR 2016i Black and White Copier
What is the problem of error code 000013-0000
Thanks a lot , i can clear error code e000 of ir2010 by your solution ,I press *function and # and arrow to #7 press ok and #4 printer reset press ok
Dec 17, 2013 | Canon imageRUNNER 2010F Copier
Canon ir2010 marca error.00000000 no imprime
Nov 10, 2010 | Canon iR 2016i Black and White Copier
Canon ir2010 errorcode E000, hoe te verhelpen
the fixing assy that heat and sets the toner to the paper is faulty. it would have to be replaced as the element is broken
Oct 31, 2010 | Canon Office Equipment & Supplies
Error code E000
can u please check the fixing
Aug 03, 2009 | Canon imageRUNNER 2270 Copier
Hi ya have a canon ir2010 copier which prints but with a band of toner across the top of the page any ideas
Looks like a worn out or dirty drum unit. I believe you need a service center to replace this drum or service it.
Aug 19, 2008 | Canon Office Equipment & Supplies
Canon imageRUNNER 5000 Copier Logo
26 people viewed this question
old marine
old marine
