Question about Epson Office Equipment & Supplies
Why is my printer so slow when photocopying, print from laptop is fine, and why is photocopied image larger than original
When attempting to copy the printer tells me to remove the document from the ADF & put in on the glass. I do this & after an eternity a photocopy is produced. Unfortunately the copy is bigger than the original & the glass. Printing from the laptop is fine
  • Epson Master
  • 783 Answers
I have an Epson SX405 and it has been getting slower and slower since I got a Windows 7 laptop.
Finally discovered (a tip from another help site) the AUD file in C:\ProgramData\Epson\PRINTER. The bigger it grows, the slower it gets.
So just delete that file. The driver will create another one next time you print, but nice and small.
After that, keep deleting it from time to time, before it gets big again.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Epson Printer Support
Posted on May 30, 2014
Epson SX405
Just set is copy as is. or one to one. Standard auto fit will always enlarge any image smaller than a full page.
Jul 16, 2014 | Office Equipment & Supplies
Bizhub C652 has horizontal lines.
its important to find out whether the \'lines\' are in scan direction/ or only through Radf or only from scan glass,
if the lines are only showing when documents are fed throught the Radf, then the problem lies with the document scan plate( left of the main glass platen (about 2" in width)) or with the scan plate blade cleaner
if the lines ONLY appear when copying from the Glass then the issue lies within the optics (probably nothing more than a clean will be needed)
another question would be to ask if the lines are solid (black line overprinting image) or if they are \'missing\' lines where the image has failed to copy, sometimes it can be hard to work out which side the fault lies,so try shaded greys as a copy original .
if the scan lines are appearing on both Radf and Glassplatten ,mode then the issue may be dirty optics/ccd sensor or it could e an indication of the ccd failing or image control pwb in error while interpreting the image file.
what to do
1) place a grey sheet of paper in the Radf and have the copier photocopy both sides of the original and print to single sided sheets ( so the printer turns the original over to complete the task)
observe the result.
2) have the copier photocopy directly from the platten glass- single sided.
observe the result.
ckeck to see if the error has appeared on both sets of prints ,
if the error has only appeared in the first set of prints then the issue may be a tiny DOT on the slit glass (left of platten) - a dot on this glass will indeed appear as a Line as the original is scanned across the glass.
hhope thhis helps
Feb 19, 2014 | Konica Minolta Bizhub C652 Color&b/w...
How to scan in two faces in one side for exmaple ID in photocopy scan and printer " canon IR3045N"
select special function on screen>image combination>2 on 1>original size a5R(if u r copying on a4R paper then original size a5) then scan both faces to be printed and >done
Feb 03, 2011 | Canon Office Equipment & Supplies
Error code P9 and P21 appears on screen and when printing or photocopying using color black, blank copies are outputed
hi piz Error code P9 and P21 appears on screen and when printing or photocopying using color black, blank copies are outputed
Apr 29, 2010 | Konica Minolta bizhub C250 All-In-One...
Lexmark x215 MFP All in one - prints fine but photocopy and faxes
you should clean the optics situed in the upper place of the machine, retirate the originals glass en clean all the mirrors are inside...
good luck...
Feb 11, 2009 | Lexmark X215 MFP All-In-One Laser Printer
In copy mode I can't get Image Quality to change from Fine
Ok what I just found out is that if you use the paper key then the menu key to get down to image quality the n the + and - keys to change the selection.
Jan 05, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Blank printing
Make sure the original is face down on the platen (glass copy surface).
or u might download its manual from :
http://www.sharpusa.com/files/cop_man_AR5316.pdf
Nov 12, 2008 | Sharp AR-5316 Advanced Digital Imager...
Dell printer will print fine but when scanning or photocopying, the left side of the page will not copy.
Refer to this free online website for dell
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?treeid=4F006C0C8C044866841FEF0842919C1D&~ck=gp&servicetag=
Please tell me if you need more info
Aug 01, 2008 | Dell Photo 964 All-In-One InkJet Printer
116 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
