Question about HP LaserJet 1020 Printer
Windows XP SP3 doesn't recognize HP 1020
I tried a lot to do...
uninstall all hp drivers,
change USB cable,
turn off, turn on printer...,
restart PC...,
check printspooler service, plug and play, tried printer on other computer,
change USB speed in BIOS,...bla bla
nothing is burnt in printer,
but my computer doesn't recognize printer!
Thanks a lot.
Deki
  • 1 more comment
  • ilicd Jun 24, 2009
    Well, I uninstalled all printer drivers when problem appeared. After that I couldn't install printer drivers because system didn't recognize device. I will try to reset BIOS USB params to old value from 12MB/s to 480MB/s. I tried printer on another computer. It didn't work. Man in service didn't find solution for my problem. I tried to connect printer to all USB ports and tried to use diferent cables (from other printer, cable modem).
    I didn't connect cable until it was prompted to do that. I will try to have a cup of tea after unpluging cable. But every time I restarted computer to try with new printer installation.
    In my device manager I can't see any red or yellow exclamation marks. USB is properly installed.
    I'm not sure is it okay but when I try to install drivers from disk Virtual USB port in printer dialog is not offered.
    In last few days I tried to find solution on Internet. Some gays had the same problems. They said that when they changed USB cable (they put shorter one 1.1m) printer was recognized.
    Their opinion is that USB cable 1.8m is not quality enough and that it can cause problems on higher data speeds (USB 2.0 protocol). They also mentioned SP3 as potentional reason for problems.
    I've been using WinXP with SP3 for about five months and USB 2.0 without any similar problems.
    Thanks for your suggestions, I am not able to try to find solutions today, but I'll try tomorrow. I'll also read your links.
    Deki
  • Art Ellison
    Art Ellison May 11, 2010
    USB cables should be 15' or shorter or you might have problems. BTW--there is no such thing as a USB2 cable. that's called marketing. They are all the same.
  • Art Ellison
    You uninstalled everything. But did you reinstall the printer drivers? (BEFORE you plugged the printer in) Next, don't mess with the USB speed in the BIOS. If you've been messing around there, go in and reset all the stuff to default for now. Also--you said you tried the printer on another computer--did that one recognize it? If not, perhaps your logic board on the printer is gone south. Oh--and did you swap out USB cables or try other USB ports?
Lisn....there r only two possible faults (if everything else u stated is goin fine)...use a shorter and new data cable...or check the printer port in which u plug in the cable...u can also chat to the hp xperts on their site if the problem persists
Posted on Nov 12, 2009
Http://forums.techarena.in/hardware-peripherals/1168951.htm
Posted on Aug 08, 2009
    President:
  • HP Master
  • 1,996 Answers
You may have already seen this article, but you have to make sure you don't connect the usb cable until prompted by the software when installing the printer. Home product support, and access to downloads for your model is here. Also consult this document for usb connections., and this for failed installations, this for basics.
Here are some MS links that may help in your situation.
Make sure after your uninstall you unplug the usb cable for at least a few minutes. go have a cup of tea or something. And reboot your computer. Then reinstall the HP software from a download. You could also try, after the printer installation, to visit windows update and run a custom scan of your system, then reboot your computer and see if the printer shows up in the control panel.
Try to take a patient, thoughtful approach, step by step, and if you are connecting via network recognize that it's problematic with these printers (unsupported by HP) and try connecting directly to the computer, then after successful installation try networking...
Best of luck!
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 23, 2009
  • efs_perpends
    efs_perpends Jun 24, 2009
    It might seem obvious, but make sure you are installing the printer from an account with administrative priviledges. (see user accounts).
    If you're running behind a firewall, try disconnecting from the internet and shutting down the firewall completely to install the printer, or use the installation setting if you have one.
    Is the printer being installed into printers and faxes ok?
    If so, you may wish to use MS troubleshooting procedures outlined here and here to help diagnose the problem. And here is a search list of MS support options for printing in xp.
    If not, have you tried resetting the printer? See instructions here.
    Also, when uninstalling the HP software, try using the HP uninstaller in all programs instead of the windows uninstaller from add/remove programs. Then reinstall from a download.
    Have you tried using the built-in printing troublshooter in your xp help & support center? That may help you to narrow it down.
    On the other hand, if you tried to use the printer with a different system, and that system also installed the software ok and was not able to print, the fault could be with the printer. Try to go thru these basic troubleshooting steps from HP, configure according to these directions, and these steps., If no luck there, try a network connection by using these instructions. (Also used to force the printer to print a configuration page.)
    I hope something here is helpful to you and you are able to resolve the issue.
    Sergeant:
    Champion:
  • 253 Answers
Check in control panel/device manager and see if there are any red or yellow exclamation marks and while there see if your USB is installed
and if find problem contact us at our tollfree no 18884276640
Hi
Go here to download and install the correct driver : http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=439320&lc=en&cc=us&dlc=en&lang=en&cc=us
Make sure to download the XP version .
Best regards ,
fanaudi .
Sep 04, 2011 | HP LaserJet 1020 Printer
Hp lj1020 shows completed but printer is still idle. paper does not feed,lights don't flash... nothing
what is OS connect your printer ?
1. If windows,or mac, try delete (uninstall all drivers for them), restart PC, plug-n-play find your printer, so take them your drivers.
2. Connect printer other usb port. Turn off/on printer, restart PC
3. Trying replase USB cable (us cable not long 1,5 m)
Aug 19, 2009 | HP LaserJet 1020 Printer
Cannot print on shared printer
I had the same problem with HP 1018 printer, when I had two computers connected to a domain and had Windows XP SP3 on them and when I shared the printer on one of them - I could only print from the network if the user belonged to the Local Administrators group on the host/server computer. Once the network user is removed from Administrators - the print jobs are stuck in print queue. I used the "HP LaserJet Host Based Print Driver Package" that is on HP web site for HP laserjet 1018 printer.
Then I tried to use a different driver for that printer and was successful with driver for HP LaserJet 1020. After forcing that printer to use the 1020 drivers, the regular users were able to print to that printer.
Oct 26, 2008 | HP LaserJet 1018 Printer
Printing problem
hi,
You need to reinstall the printer driver.
First check which operating system is used with your product? After that download the software from Download  Full Feature Software and Drivers.
How to Uninstall the printer Software :-
Follow the steps below to remove the hp LaserJet 1020 series software from the computer:
  1. Disconnect the USB cable from the computer.
  2. For the Windows Desktop, click Start , click Programs or All Programs , and then clickhp LaserJet xxxx series .
  3. Click Uninstall hp LaserJet xxxx series .
  4. Follow the messages on the screen to remove the software.
  5. Reboot the computer when instructed.
OR
2. For the Windows Desktop, click Start , click Crontrol panel, select add\remove(XP) or program future (VISTA).
 After restart install the printer driver and follow the screen instructed.
Sep 02, 2008 | HP LaserJet 1022 Printer
Windows cannot recnognize my HP laserjet 1020 printer
It's best to put it back in the same port some times XP is just goofy like that. Did you uninstall the printer completely? Are you sure that the USB cable you have works? You can check what port the printer is on by doing the following
Start>Settings>Printers and Faxes Right Click the Brother Printer and select Properties. At the top you have different tabs. Select the third tab labeled Ports.
Jul 04, 2008 | Brother HL-2040 Laser Printer
Windows XP will not recognize Brother HL 2040 Laser printer
you could try this: unistall the HP printer driver first, uninstall the brother driver , restart pc, load brother driver with the usb cable unplugged from printer. Software will prompt for the cable to be connected to printer
Apr 10, 2008 | Brother HL-2040 Laser Printer
Hp laserjet 1020 ( usb device not recognized )!?
I wish that there was a simple, single answer for this. There's only one thing more distressing - no device recognition at all. Here are the most likely culprits:
* The USB device or the USB adapter requires it's own power source. If your USB device or adapter came with an AC power "brick", try connecting it.
* Here's a likely one - the front USB ports on your PC case may be misconnected. I've seen them that way from the factory. It's a good idea to check the connections against specifications. The standard order of connection is Red, White, Green, Black. No more than 4 wires per USB bank are needed.
* Defective device. Do not assume that all PC components work correctly out of the box. I've seen many new USB devices that do not work. If you can, try the device on another PC.
* All drivers are not installed. Some devices will require installing the driver package before plugging in the device. Some devices will also require basic USB files from the Windows CD before the unit will function. The general rule is to always follow installation directions precisely and to have the Windows CD ready.
I will now discuss how to address an unknown device problem which is caused by a driver deficiency.
1. Try to update the unknown device driver from within Device Manager. First try letting Windows search for one. If that fails, go back and choose "Select from a list" and then "Have disk". Browse to the device CD and look for the appropriate Windows folder there. Try browsing to the Windows CD (Win9x folder or i386 folder). Lastly, try updated drivers from the manufacturer's web site.
2. Try uninstalling the unknown device, unplugging the device and rebooting. Replug when back in Windows.
3. Be certain that you have the correct drivers! You may have gotten the wrong CD or a CD with drivers for more than one device on it.
4. Cleaning up in Safe Mode may be necessary. Unplug all USB devices. Reboot the PC. To enter Safe Mode, press the F8 key repeatedly while restarting the PC. Timing is important. Try to press quickly before the Windows logo screen appears. Pressing and holding the CTRL key may work too. Choose Safe Mode and open Device Manager. In Windows 2000 and XP, click View > Show hidden devices. Now locate all USB devices, HID (Human Interface Devices), USB drives and controllers/hubs. Remove all and save the USB Host Controllers for last. When done, restart and replug USB devices one at a time.
Just remember that you are entitled to support from the device maker. If you can't get help, do not hesitate to return the device. Some manufacturers only seem to respond to lost business. It's a shame, but it's true. Send them a message - that you won't accept shoddy goods or lackluster support.
Mar 26, 2008 | HP Photosmart 3210 Printer
I'm not sure, but I think I understand that you're connecting using a USB hub? If so, try connecting it directly to a USB port. Many times an unpowered USB hub does not supply enough power to run a laser printer. Unhook the printer. Go to Printers and Faxes - delete the printer. Hook up directly to a USB port. Let the computer re-install the printer. Let me know Ed
May 05, 2007 | HP LaserJet 1020 Printer
HP LaserJet 1020 Printer Logo
2,114 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
