Question about Fisher and Paykel RF201ADUX Bottom Freezer French Door Refrigerator
Water dispenser cover
How can I remove the front cover to the dispenser?
How do I replace the water dispenser tube for a Kenmore Coldspot model # 106.53769201. The end of the line disintegrated at the spot where you put your glass under the dispenser.
Ice makers and water dispensers are convenient to have on your refrigerator, but can also cause a lot of aggravation if they are not functioning properly.
If your water valves are not defective and you are still experiencing water or ice delays, you may have a clog in your refrigerator hose line.
Instructions and material needed to fix it up.
  • Towel,Flathead screwdriver,New water hose
  1. Turn off the water supply to the refrigerator and place a towel under the line to soak up any residual water that leaks from the hose when you remove it. Unplug the refrigerator.
  2. Disconnect the hose from the back of the refrigerator by pushing in on the collar while pulling the water tube out. If you have a model with an ice and water dispenser, you will need to disassemble the dispenser on the front of the freezer in order to completely remove the water hose.
  3. Remove the water drip tray from beneath the ice/water dispenser and locate the screws at the bottom of the cover (if any). Remove screws and pop off the panel that houses the dispenser. If the unit does not have screws, you will need to pry the cover off with a flat-nosed screwdriver.
  4. Once the cover is removed, you should be able to see the screws that hold the dispenser unit in place. Remove these screws and reposition the unit so you can free the water hose, by pulling it through the dispenser.
  5. Thread the new water line through the freezer door and reassemble dispenser unit. Push the new water hose into the fitting on the back panel, making sure it is properly seated. Turn on water supply and check for any leaks before moving the refrigerator unit back against the wall.
Good Luck and thanks for using fixya.
Jan 16, 2011 | Kenmore 57029 Side by Side Refrigerator
I need to replace the water dispenser on a Regrigerator but I can't find any way to remove the door cover or the water dispenser cover from the front. How do I get to the water dispenser?
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Nov 09, 2010 | Refrigerators
Water dispenser quit dispensing 2 days ago
Sounds like the micro switch has gone bad behind the dispenser cover. locate your handle or push button either you will remove the front cover to find the switch sometimes you remove inside the door behind the dispenser. but that sounds like the trouble your having. Maybe I've helped good luck. BB
Jan 21, 2010 | GE GSH25JFR Side by Side Refrigerator
Model A 512 washer-water pours out from plastic unit on hose at top left after relay water line unit
Sounds like you need a new injector.
Remove the front cover (loosen the 2 Philips screws near the bottom, lift the front cover 90 degrees and pull back). Remove 2 bolts at each corner from to the top cover located up front. Remove the beach dispenser hose, tilt top cover up. The injector will be on the left.
Sep 29, 2009 | Maytag Washing Machines
How to remove water dispencer cover
you must start at the bottom prying the plastic off carfully with a flat head screw driver.
Phil
Jun 11, 2009 | Refrigerators
Replacing water fitting assembly
water dispenser continues to run too long after removing glass
Oct 23, 2008 | Refrigerators
Front Cover to Ice/water dispenser
YOU WILL FIND TWO PHILLIPS SCREWS UNDER THE FRONT PANEL AT THE BOTTOM YOU NEED TO BEND DOWN TO SEE THEM.IT THEY ARE NOT THERE THEN YOU WILL NEED TO REMOVE THE ENTIRE DOOR LINER ITS BEST YOU GET THE HELP OF A TECH.LET ME NO IF YOU NEED FURTHER ASSISTANCE.GOODLUCK.MOHAMED
Sep 15, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice door for ice dispenser not shutting.
How do I remove the ice/water dispenser front cover assembly
May 22, 2008 | Kenmore 53542 / 53544 Side by Side...
Kenmore refrigerator
1. Remove the switch cap and unsnap the two (2) tabs at the bottom of the front cover from the
housing first. Pull the bottom out and lift and the front cover from the housing. (Fig. 27)
2. Remove the two (2) hex-head screws securing the metal control panel cover to the dispenser
housing. This will also free the control bracket from the housing although it will remain tethered
to the freezer door by the wiring harness. (Fig. 28)
3. Disconnect the wiring harness connectors from the terminals
on the switches and light fixture in the control bracket.
Removing the Dispenser Assembly
1. Do the previous three procedures.
2. Remove the eight (8) hex-head screws securing
the dispenser housing to the freezer door. (Fig. 29)
3. Carefully pull the housing from the door.
4. Pull the water supply tube from the top of the dispenser housing.
5. Pull the wiring harness leads from the dispenser housing.
6. Disconnect the wiring harness connectors to the electric
foil heater that should get you in there
Feb 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fisher and Paykel RF201ADUX Bottom Freezer French Door Refrigerator Logo
27 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
