How to install a toilet? - Computers & Internet
How to tighten a vitro nupva toilet seat.
Christina, how to tighten or install hidden fasteners on your toilet seat. check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Remove Vitra Shift toilet seat
Soft Close and Quick Release Toilet Seats Installation
How to fix loose toilet seat
http://vitraglobal.com/
Jun 27, 2016 | VitrA Home
How do I install wax ring on toilet when no holes for bottom bolts?
The wax ring gets installed on the bottom of the toilet, then the toilet gets installed over the bolts, which poke their way through the wax ring and extend through the mounting holes. This ensures a good seal around the bolts. Be sure to press down firmly on the bowl to seat the wax ring before you install the nuts.
Nov 10, 2015 | Home
Uberhaus dual flush toilet keeps running
The flapper may not be seating properly after a flush. Even though you say the toilets are brand new, something may be askew in the flushing assembly or may have been affected during installation
May 27, 2013 | Home
Leak from the toilet every time it is flushed. It is a new toilet, flange, extender, and wax ring all installed 1 year ago.
Lift your toilet off again and replace the wax ring check the bottom of the toilet for cracks and make sure it is clean. Then install the toilet make sure to tighten flange bolts evenly DON'T OVER TIGHTEN. Try that to start with.
Feb 02, 2013 | Home
I would like too see a video on how too install a toilet
Hi mary
Here is one video and a webpage that may help you a lot on the installation of your toilet.
You mentioned that you wanted to move the toilet in the same room, that will only be possible if you have a wooden floor.
Otherwise if you have a concrete floor, it can be done, but it will be really expensive to move the toilet to a different location in the same room. The concrete floor would have to have a hole bored thru it and the dirt removed under the house to get to install the necessary pipes...really expensive.
Removing and reinstall the toilet: http://www.youtube.com/watch?v=Y_hVZ3rPzm4
Webpage for plumbing in your toilet.
http://homeguides.sfgate.com/plumb-toilet-start-pipe-34476.html
Please take time to rate me
Bud
Nov 02, 2012 | Home
How do you get the water supply hose, which is behind the toilet to connect with the water supply valve on the wall? Duravit says the back of the toilet is slightly curved, but I don't see how the water...
Are the install correct ?I can't believe an install time frame where the technician is actually on time! Work was done quickly and efficiently. Definitely one of the best install experience I've had. Thank You.
Heated Toilet Seat Installation
Feb 20, 2018 | Duravit 0910100005 Happy D Toilet Cistern ...
Toilet rocked after install, water leaking from under toilet.
This sounds like poor installation.
If you can get the person who installed it to come back to your home & make it right, you certainly should.
There is typically a wax gasket that connects the toilet to the drain pipe at floor level. This gasket needs, first of all, to fit. Then it needs to be well-seated (it's wax, and compressible) by rocking the toilet back & forth before the toilet is securely clamped down.
If it's not a problem of poor installation, it may be that your floor is uneven, or that there are tiles (under the toilet) that are chipped or missing - in other words, physical conditions that are interfering with the secure installation and tightening down of your toilet.
I wish you luck!
Mar 01, 2011 | Toto Guinevere One Piece Toilet 1.6 GPF...
Does anyone know where to get hold of a manual for installing a toilet from Duravit, please? Specifically it is the Duraplus 022901. With many thanks, Fran.
Information on your product can be found here along with measurements for installation. However there does not seem to be detailed installation instructions.
http://www.duravit.com/products/series/duraplus/toilets/toilet-close-coupled--022901_toilets_91994_useo6q3rng.html#
Suggest you review the following series of videos which provides detailed instructions on toilet removal and replacement.
Trust this is helpful.
Jan 04, 2011 | Duravit Duraplus, Two-Piece Toilet -...
We just installed a new one piece toilet from Neptune. It makes a loud noise when you flush it and after the water fills up. In addition, if you flush another toilet or turn on the washing machine it also...
Hello. I doubt that the installer would not install it properly. That said, the issue you are having makes me wonder if your bath drain plumbing is properly vented to the outdoors through the roof. Joe
May 07, 2010 | Neptune FB1602 Roma Elongated Front Toilet
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
