Question about Asrock H55M-LE Motherboard
Asrock h55mle sound problems - Asrock H55M-LE Motherboard
I want change out my ASRock H55M-LE easy as possible
Are you wanting to transfer the Asrock motherboard to another chassis, or exchange it with another motherboard?
Please clarify your question.
Jan 24, 2014 | Asrock H55MLE Motherboard Intel Socket...
I want to replace ASRock H55M-LE
Google "replacement Motherboards". You can find it from many different vendors.
Just bought a system. It boots but no video. Removed video card, tried onboard still no video.
if you mean that you cant get your screen
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket hope this helps
May 19, 2011 | Asrock H55M-LE LGA1156/ Intel H55/ DDR3/...
My motherboard is asrock h55m-le it is showing some problem.. on starting windows.. my windows sign hangs on startup.. please advice me what to do.. i think it is over heating problem..
where your screen hangs....
1 if using XP did it hangs when xp is bootig??
or any other time.
and if yes then it is not mother board problem ...rather it is a hard disk problem.
you will have to zero fill your hard disk.\
if helped ..please thum up
Jan 09, 2011 | Asrock H55M-LE LGA1156/ Intel H55/ DDR3/...
Trouble finding all the correct drivers
Hi Angele,
Click on the ASRock link below where you can download the drivers for the Motherboad 775VM800:
http://www.asrock.com/mb/download.asp?Model=775vm800
Download the sound driver named, (C-Media audio driver ver:AC97Integrate003 File size 25.16MB).
Download the VGA driver named, (Onboard VGA driver ver:16.01.23.15 File size, 7.69MB).
Save the above ASRock link above in case you need other driver software.
Good luck Angele!
If you run into any other trouble, just post the problem here & I'll help you further.
Mike
Nov 29, 2008 | Asrock 775VM800 Motherboard
AsRock soundrivers
http://www.asrock.com/mb/download.asp?Model=K7S41GX
Nov 19, 2008 | Asrock K8Upgrade-VM800 Motherboard
Sound driver problem and unknown devive driver problem
Hi
C-Media Audio driver for ASRock 775i65GV
Windows XP, 2K, 9X - http://www.asrock.com/mb/from.asp?Model=775i65GV&s=&T=D&ID=162
Let me nkow if you need further help.
Regards
Mike
Mar 22, 2008 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Here:
http://www.asrock.com/mb/download.asp?Model=845GV-M
Mar 20, 2008 | Asrock 845GV (P4I45GV) Motherboard
Asrock H55M-LE Motherboard Logo
46 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
