Question about Samsung RF217ABBP Bottom Freezer French Door Refrigerator
MY SAMSUNG RF217ABBP REFRIGERATOR FREEZER WON'T STAY ON
    Scholar:
  • 73 Answers
Same as the last post...If the refrigerator wont stay on the start relay may be defective. This may have been caused by the leaking door that overloaded the system. The relay is a small box mounted to the side of the compressor and provides power to the compressor start winding for a split second at start-up to help get the compressor get started. If its defective the compressor may run off and on (a lot) or not at all and the refrigerator will not get cold enough. Fairly easy to do and reasonable
Posted on May 17, 2014
There is a vibration noise on my Samsung #RF217ABBP. The vibration is loudest on back midway up. Anyone know what causes this vibration and is there a fix?
Try cleaning the condenser coil underneath the refrigerator. A dirty coil can make the compressor run extremely hard and vibrate. If this coil is clean, a compressor mount maybe loose or broken.
Feb 06, 2015 | Samsung RF217ABBP Bottom Freezer French...
Why won't the unit stay on?
Fridge FAN CONTINUALLY STAYS ON OR SHUTS OFF WHEN DOOR IS OPENED:
NORMALLY WHEN THIS HAPPENS U EITHER HAVE A DOOR CONTINUALLY OPEN ISSUE OR A BAD DOOR SEAL LETTING AIR IN AND CAUSING FAN TO OVERWORK ITSELF. ANOTHER CAUSE CAN BE DIRTY COILS AND CONDENSER AND LASTLY NOT TO COMMON IS A SHORT IN THE FAN SYSTEM ITSELF. A MORE PROBABLE CAUSE COULD BE BAD THERMISTORS OR EVEN COLD CONTROL THERMOSTAT ( WHEN THE THERMISTORS OR THERMOSTAT DO NOT GET/GIVE A PROPER READING, THEY CAN CAUSE THE FAN TO CONTINUE TO OPERATE AS THEY FAIL TO RECOGNIZE OR REGULATE THE PROPER TEMPERATURE.
May 17, 2014 | Samsung RF217ABBP Bottom Freezer French...
Water in my crisper and bottom of the refrigerator
Sounds like the drain pipe at the back lower side of the fridge may be blocked pull out the crisper to locate and try putting some water in it and see if it drains away if not try clear it with a small hose .
Feb 24, 2014 | Samsung RF217ABBP Bottom Freezer French...
Freezer won't stay cold
What is the model number of your unit?
Feb 10, 2013 | Gladiator Chillerator Top Freezer...
Amana Br22tw refridge door won't stay closed
Check all the screws for the hinge and be sure the door is lining up properly.
Oct 23, 2012 | Amana ABB1927DE Bottom Freezer...
Freezer dropped to -12 won't stay at -1
freezer light does't work, I put in new bulbs and it doesn't stay cold.
Dec 06, 2011 | Sub-Zero 632 / S
Freezer is set on -2 degrees, actual temp in freezer is -20. What sensor is causing this problem
I suspect that you do not have a problem. . The standard operating temperature of a freezer is around -20 degrees CENTIGRADE (-2 Farenheit)
Your freezer has an option to display degrees C and degrees F, I suspect it is showing farenheit
I have taken a look at a copy of the manual, which can be found at:
http://www.manualowl.com/m/Samsung/RF217ABBP/Manual/142915
But for the life of me, I can't see how to change the display from C to F and back anywhere in the guide. If I am right, swapping the display back to Farenheit will solve the display issue.
If you are unable to change the display, you can try calling Samsung in arlington NJ on 1-800-726-7864.
Hope this helps. Please add a comment to this thread to let me know if the problem is solved or if you need more help
Sep 15, 2011 | Samsung RF217ABBP Bottom Freezer French...
In my side by side samsung RS2534WW the rerigerator is warm
I read elsewhere that if you hold the power cool and power freeze buttons down for 12 seconds it will restart the system. I did it the other day (because we were having the same issues) and it has seemed to work for the last few weeks. Frige temp stays at 34F and freezer temp stays at -2F
Mar 13, 2009 | Samsung RS2534 Side by Side Refrigerator
Samsung RF217ABBP Bottom Freezer French Door Refrigerator Logo
50 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
