Indeset icd661, has a flashing light on (4hr) and it's doing nothing?
How do i regester my indeset dryer to get extrs 4years
did you try going on mfg website there should be an option for that or at least a call number to get answer.have your model number ready for them also hope this helps
Feb 12, 2015 | Dryers
Timer switch mode is inoperable. no lights in timer setting, the lg ld450eal model operates continously. please advise how to program the 2 hour or 4 hour timer
With the Dehumidifier switch on, pressing the Timer Button should changed between 2hr and 4hr mode.
If this is what you're doing and it isn't lighting the LED nextto the 2hr and 4hr can you confirm what setting you have for the humidity?
Jun 25, 2011 | LG LHD45EL Dehumidifier
Indeset washing machine has stopped working. You select the programme the green light comes on but nothing happens. It in not filling up/ draining/ spining nothin, Can you help????
this may sound silly but just had the same problem changed the pump and it works fine now, if the pump does not work it wont let the washer start
Oct 18, 2010 | Indesit W 123 Front Load Washer
Poweredge 600-SC RC 4Hr J3717 ASSY, Tray, (5Y002) Motherboard: what does it mean when an dell poweredge 600 sc pr...
Three sets of beeps, or three individual beeps? Does it repeat? If so, then check this for the code you are hearing:
http://support.dell.com/support/edocs/systems/pe600sc/en/it/1r237c20.htm#1046231
If it is a steady once-per-second beep - or a constant screech - and it is able to boot to the OS (or even most the way), then it is probably your RAID controller. Boot to CTRL-A or CTRL-M to check the status of your array.
May 16, 2010 | Dell Poweredge 600-SC RC 4Hr J3717 ASSY,...
Indeset w101 washing machine programer, we set the
Depending on the model you may have a reset point on the selector switch dial.
This is usually indicated by 2 or 3 black dots on the dial.
If it has , then switch the m/c off, set the dial to one of these points, switch on and wait until light fashes, switch off, and reselect your programme.
It should now work normally.
If it does not, then there is probably a control board fault.
If there is no reset point, then again it is likely to be a control board fault.
Please rate my solution.
Thankyou.
Jan 15, 2010 | Washing Machines
Door latch broken on indeset wd12x, how do i open to empty and replace part?
got a front loader electrolux washing machine & i broke the door latch.
still got clothes in it, how can i open the door?
Oct 30, 2009 | Washing Machines
Washing machine has broken down
try to put your washer on a drain and see you can hear the pump workng. you should hear a buzzing.if you dont it mite be your pump that as gone. to get the water out pull whasher out near your back door if poss and lie the drain pipe flat the waser will then empty. if there is a buz then you could have a blockage. but if not a pump is no more then 25 pound and are not that had to do
Jun 24, 2009 | Indesit W 123 Front Load Washer
Indesit di260
if its the latch tongue remove the top panel...if its the door remove the console
Aug 17, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
