Question about Refrigerators
Whirlpool refrigerator double door fridge Ice deposits on the vegetables in summer season when placed directly in front of the cooling panel
I keep vegetables in front of the cooling panel through which the cool air comes but in summer season the ice deposits on the vegetables.I adjusted the cooling knob but it has no effect
    Habit-Forming:
  • 64 Answers
Humidity is the most probable culprit. Verify if it is getting in
Examine the door rubber seals to ensure tight sealing. If rubber seals worn out, you may need to replace them
Posted on Jun 21, 2014
landsend
  • 1066 Answers
SOURCE: fridge side wont cool unless the freezer door is open
the little fan motor in the freezer is defective.  It may only be stuck.
Posted on Apr 01, 2009
peyton32034
  • 410 Answers
SOURCE: refrigerator
it has a bad main control board call maytag they will most likely repair it in warranty for you
Posted on Dec 11, 2007
aborcass
  • 2651 Answers
SOURCE: Amana double door freezer side is not working
you can visit the local applaince dealer. frost on onle the top few coils is an indcation of a low charge, restriction of freon, or inneffceint compressor, after 10 years wouldnt image that would be a worth while repair, way expensive here where i am lookna t 500 or so.
Posted on Mar 16, 2008
mikedurland
  • 481 Answers
SOURCE: whirlpool double door fridge side is not cooling,
sounds like a defrost problem. check to see if there is any frost buildup in the back wall of the freezer. if so, it is not defrosting like it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
Posted on Jun 28, 2008
  • 19 Answers
SOURCE: Maytag refrigerator cooling probelm
Defrost the fridge, take everything out of freezer and turn off for at least a day, check the drain is clear after defrosted and try again, if it happens again you may need a new defrost heater of timer.
Posted on Nov 18, 2008
Whirlpool double door fridge. Door wont stay closed. Have to push extra hard to keep it closed
Take out the shelves and drawers. check the rear is clear of ice before putting them back in place, and ensure they are not stopping the door closing. Next check the top and bottom of the door. Is it hitting the frame when closing? If so, straighten it up by tapping the hinge side of the door to make it square to the frame.
Jul 04, 2015 | Whirlpool Refrigerators
LG gn253sqa electro cool- temp. control lights in fridge keep flashing and fridge not cooling so good, help?
This has happened to me a couple of times.The problem is that when the fridge door is opened too may times the warm air of summer will block the cold outlets in the fridge with ice.The cold air comes direct from the freezer and the chamber connecting to the fridge clogs up with ice.What one has to do is completely empty the fridge and freezer,leave open both doors so the the ice build-up can melt.Then after about at least 4-5 hours (very important to stick by this time-frame as I tried a less time,but it did not work.),close both the freezer and fridge doors and switch it on.After about 1/2 hour replace your goods in the fridge.The down-side of this is that you will need the kindness of a neighbor or two to use their fridge to store your food whilst this fix is underway..
Feb 28, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Light inside the refrigerator flickers (or not) and the door makes a buzzing noise when opened. There appears to be a small light flickering inside the fridge behind the vegetable bend. The refrigerator...
Sounds like the electronic control in the rear compartment by compressor may be bad . There is a light in the crisper as well I believe and that one and the main light are controlled by the control in back.
Dec 03, 2010 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Double door fridge stops cooling, autodefrost not working
It wud need a new defrost heater, the fridge gets its air from the freezer , if the defrost heater does not work , ice builds up in the airduct , equals to no cooling in fridge
Feb 01, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Removing fridge door?
Try opening the doors and moving it through the doorway with the doors open? If you have the room twisting the fridge around the doorway with the doors open my work.
Jun 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool double door fridge side is not cooling,
  • possible causes:
Jun 28, 2008 | Whirlpool GS6NBEXR Side by Side...
Water Is accumulating at the bottom of my fridge....below the vegetable/fruit crispers. The fridge however contiues to keep things cold.
The automatic defroster is supposed to drip down a tube and deposit water into a tray underneath the refrigerator. If that tube becomes clogged with either ice or mold, water is supposed to drip down the back of the refrigerator and go under the crispers, but there is a drain under there that takes it to the tray under the refrigerator. That drain might get clogged with mold or food.
So my suggestion is, try to clear out the drains under the crispers. More difficult, remove the floor of the freezing compartment and clear out the drain there. If it is severely clogged with ice under there, you have a defrosting problem.
In this hot, muggy weather you are likely to get lots of condensation. Good luck.
Jun 13, 2008 | Whirlpool Refrigerators
Whirlpool Refrigerator or freezer Doesnot cool
I have a similar top freezer and during the summer
I have had a problem where the frdge part does not get cold. The two holes coming from the bottom of the freezer to the fridge are blocked
with ice. I took the back part off the freezer
got rid of a clump of ice. I also used a hair dryer
in the fridge section to melt the ice in the holes.
Dec 11, 2007 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
