Question about Air Tools & Compressors
I have a 20gallon,1.7 HP, and it wont hold any air in tank, what could be the problem.its a Campbell Hausfeld.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
I would suspect the seals have perished. they are cheap to replace but make sure u very lightly grease them. very lightly!
Posted on May 17, 2014
  • Joe Rodriguez May 17, 2014
    Where are the seals located
  • 89 Answers
SOURCE: Gas air compressor shuts down
IS IT BUILDING TO THE UNLOAD PRESSURE AND THEN STALLING OR JUST SHUTTING DOWN ANYTIME. IS THE UNIT SITTING AT AN ANGLE?
DOES IT WORK FINE WITH THE LOW OIL SWITCH UNPLUGGED? UNPLUG SWITCH AND LEAVE IT UNPLUGGED FOREVER.THEY'RE ALL P.O.S.
Posted on Mar 14, 2009
  • 8 Answers
SOURCE: Campbell Hausfeld Air Compressor auto shut off switch not working
i have the same one and mine was broken by my kids , i had to replace the entire component, DONT RUN COMPRESSOR with out the regulator working IT CAN EXPLODE IF OVERFILLED,a must fix situation i believe i got mine from sears , a great unit ive used it painting and with many air tools over many years now , well worth fixing mine is a little loud but dependable good luck.
Posted on Mar 15, 2009
  • 234 Answers
SOURCE: air compressor not working
If your motor is running and not the pump, the malfunction is either in the pump or the coupling between the motor and the pump.
Some of these compressors are manufactured so cheap now that there can be just a set screw that is loose and the motor shaft is spinning free inside of the crankshaft.
If you drain the oil out of the pump and take off the pump crankcase cover, you should be able to see the problem.
Posted on Apr 15, 2009
  • 98 Answers
SOURCE: I have a Campbell Hausfeld Quick Air DK618300AV without a fuse...
3.5 amp fuse
Posted on Jul 22, 2009
SOURCE: Campbell Hausfeld Air Compressor won't start
The compressor starting problem is common to most of the small portable compressors. Poor design and undersized components are to blame. If you have one of these units i suggest looking into a product called the Smart Start by Conrader Valves. It is interchangeable with the standard air filters and allows the compressor to start without fail. check it out- www.conrader.com.
Posted on Jul 23, 2009
Campbell Hausfeld 4.5 H.P. 20 gallon tank , I have an air leak in the unit that houses the on / off switch and the guages ....
They call it a pressure switch the tube maybe lose and use a wrench to tighten you can buy the switches on eBay or online home depot
Jan 28, 2015 | Campbell Hausfeld Air Tools & Compressors
My campbell 0.33 runs but won't built a pressure
Check that the drain cock on bottom of tank is shut off,or leaking.?
Jan 28, 2013 | Campbell Hausfeld 0.33 HP 2-Gallon 100 PSI...
My 5 hp campbell hausfeld model hl 7017 pumps up to pressure but when it drops the motor starts but the compressor wont turn the belt just slips until pressure drops off to about 30 psi
Your tank check valve is not closing properly. It's a valve on the tank where the air line from the pump head attaches, It allows air in but not back out of the tank through the pump. When the pressure swtich turns the motor off, valve on the pressure switch lets the air out of the head so the motor can restart without any pressure in the pump head when the pressure in the tank drops. On rare occasion, you can clean the check valve out and it'll work again, more often than not you have to replace it.
Nov 24, 2012 | Campbell Hausfeld Maxus 60 Gallon (Belt...
I need a part number for a check valve on a Campbell Hausfeld model WL506201AJ
there is a check valve on the compressor! it connects to the tank. if it is hissing all the time it wont allow the compressor to turn over due to the back pressure from the tank... Can anyone answer what check valve to get? Tank thread size on one side and the feed tube connection side... Here is the parts diagram but the check valve is not described... http://www.chpower.com/IMAGES/pdfs/manual02/224902_0201.pdf
Feb 19, 2011 | Campbell Hausfeld Air Compressor Check...
My craftsman 1.5hp 20gallon comperssor starts fine with an empty tank, and will fill the tank, but will throw the built in breaker when it needs more pressure.
Your tank valve is stuck open. The valve is on tank where the tube from the air pump goes into the tank. It allows air into the tank but not back out the same way. When the pump stops you hear a short burst of air leaking out that releases the pressure on the piston in the cylinder. If the tank valve sticks open, the pressure in the cylinders is more than the motor can overcome to restart and the breaker pops open so the motor won't burn itself up. The valves are relatively easy to get and easier to replace.
Oct 22, 2010 | Campbell Hausfeld 20 - Gallon Air...
Piston snaped on my husky 1.7 hp 32 gallon
I have had sad service with Campbell Hausfeld. You can go to their website, type in the model number, then ask for recalls on that model. My guess is there is no recall.
If not, you might consider buying a replacement compressor motor to mount on that tank.. The tank is too good to throw away. Try Northerntools.com.
May 07, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
