Question about LG Audio Players & Recorders
Power ic number - LG Audio Players & Recorders
Hi, I have a telefunken TTV-2126B, the IC from the power supply burst and I can't see which number was it. can you help me with that.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Power supply sction smps] circuit diagrams to many popular brand TVs and other devices are given. Hope it might help you to find out the IC number.
Mar 28, 2015 | Televison & Video
Ic number of acer lcd monitor v193hqv?
Hi guys the pwm ic number in acer v193hqv is TEA 1530 AP.......
Aug 05, 2014 | Acer Computers & Internet
Green timer light blinking. No picture or power.
Replace Both of your convergence ICs they are big black ICs will have part number on them example STK392-110 go by the number on them Call Mats for ICs you will also need heat silicon compound to put on back of new ICs 1-800-628-1118
Nov 30, 2009 | Mitsubishi WS-65869 65" Rear Projection...
DELL LCD 1901FP PlZ Find IC Number
The 8 pin IC is UC3843A, SMPS controller. The 14 pin IC is TEA1533AT.
Monitor Mike
Jan 28, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
Polkaudio psw202 won't turn on
Got the information from Polkaudio customer srevice. IC number is TDA7294.
Dec 14, 2008 | Polk Audio Audio Players & Recorders
Floor model
If the IC your talking about has a designation number of IC601, the number is MX0841AB-F. Common regulator IC. Sony says that IC is no longer avaialable. You may get lucky and take out the entire G board and have ptscorp.com, or Tristate.com repair the board for you. Good Luck
Sep 17, 2007 | Sony KP-53S65 53" Rear Projection...
Tv won't turn on
Your problem could be the Convergence board is loading down the power supplies and will not let the TV set come on, or the power/deflection board, part number AA94-08574A, or the STR type regulator IC, part number AA13-00105A. If you locate the convergence board, unplug the connectors, and see if the set will come on. if the set does come on, replace both of the STK convergence IC's at once. The part numbers for those IC's are STK392-40. You can get the original replacement IC's from MCM electronics for about 15 to 16 bucks a piece. Do not use the less expensive STK IC's as they are not the same. the replacement IC's should have the name of SANYO printed right on the face of the IC's. Good Luck
Jul 22, 2007 | Samsung HCM4215W 42" Rear Projection...
Top LG Audio Players & Recorders Experts
Electro Med Services...
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
