Question about Boating
Needs a skippers licence manual for rsa - Boating
1999 Piaggio Skipper 125 lx fork oil capacity Best regards Pawel
Hi, Pawel for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Piaggio, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Piaggio and Vespa Haynes Online Manual for Piaggio Sfera Typhoon Zip Fly...
https://www.oemmotorparts.com/oem3.asp?M=piaggio&T=skipper%20lx%20125-150
Piaggio Skipper ST 125 2005
Piaggio Wikipedia
Apr 12, 2017 | Piaggio Motorcycles
Usb RSA securID when plug into the usb port, windows 7 says "finding drivers and then errors out with "Unable to find smart card driver"
This pop up only occurs with older versions of the RSA software. Customers should download the latest version of RSA Authentication Client from RSA.com. bres can obtain the SD800 smart card driver -- which is Windows 7 certified -- directly from RSA, but it is not available through Windows Update.
The SecurID "token" from RSA, the security division of EMC, is a two-factor strong authentication mechanism (something you know, plus something you hold). In tandem with a RSA authentication server, a SecurID is used to ID trusted users for firewalls and other restricted networked applications. (It is not itself a firewall.)
RSA's SD800 is a hybrid hand-held authenticator. The SD800 displays a series of one-time passwords, which change every 60 seconds, on a small LCD, but it also has a USB plug that allows it to directly connect to an accessible USB port to offer the full functionality of a smartcard. These include an automated SecurID exchange, cert-based authentication, an array of classic PKI crypto functions, and supplementary key and credential storage.
These are complex services, and they require a sophisticated setup.
The SD800 is intended for Enterprise rather than consumer use. Since the driver must be properly configured by an Enterprise to work in its environment, the SD800 is designed to be installed manually or pushed out by an Enterprise using SMS (along with its complementary GPOs, group policy objects).
The quick solution here is for an Enterprise admin to go back to the vendor, RSA, for the right stuff.
_Vin
Jan 12, 2011 | RSA Security RSA SecurID Appliance...
How do you progran the day of the weeks it should water the lawn
Turn black skipper wheel COUNTER-CLOCKWISE until todays day is in front of "14" arrow. Press pins DOWN on days of NO watering. The skipper wheel must have all pins UP for daily watering
I hope that shud solve the problem, taken directly from the manual
Dec 24, 2010 | Intermatic R8806P101C -...
KERO SUN RADIANT 8 HEATER-I NEED TO KNOW HOW TO ADJUST THE WICK WHEN IT BURNS DOWN
Click on this link to download the manual for your Radiant 8 heater.(it's now sold as a Toyotomi RSA 8 but is exactly the same). All the info you need is there.
http://www.toyotomiusa.com/products/manuals/RSA-8.pdf
Dec 02, 2010 | Heating & Cooling
How do you set the days that you want the system to operate ?
R88 series timers at Intermatic.
Click on model number to see manual:
http://www.intermatic.com/products/timers/mechanical%20time%20switches/sprinkler%20irrigation%20timers.aspx
Add a comment if you have different timer
At fixya, we're not supposed to copy-paste from manual, but manual says information clearly.
If timer has the day-skipper wheel located lower left of large yellow dial:
Not every timer has day-skipper wheel, in which case timer works same for each day.
TO SKIP DAYS: Turn black skipper wheel COUNTER-CLOCKWISE
until today's day is in front of "14" arrow. Press pins DOWN on days
watering.
Additional instructions:
1. TO SET FIRST ZONE: For watering, push gold pin into slot on yellow
dial at desired ON time. For each 12 minutes of additional watering
add one pin WITHOUT skipping a slot.
2. TO CHANGE ZONES: Leave one blank slot on yellow dial after ON
line (gold pin), and valve will automatically advance to next zone.
3. TO SET ADDITIONAL ZONES: Repeat steps 1 and 2. REMEMBER
to leave blank space between zones
4. TO SET TIME OF DAY: Turn yellow dial CLOCKWISE, until correct
line is at end of silver time pointer. Do NOT turn silver pointer.
5. TO SKIP DAYS: Turn black skipper wheel COUNTER-CLOCKWISE
watering.
6. PUT SELECTOR SWITCH IN AUTO: This switch can be used to turn
the system ON or OFF for manual operation without affecting the set
program.
Nov 24, 2010 | Intermatic R8816P101C -...
HOW DO I SET TODAY MONDAY, SO THE PUMP WILL START ON WEDNESDAY? I PUT MONDAY IN FRONT OF 14 ARROW AND PULL THE PIN OUT FOR WEDNESDAY BUT AS ALL PINS PASS ON YELLOW DIAL TO GET TO WEDNESDAY AND THE 12 MIN....
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
http://waterheatertimer.org/images/R8806P101C-timer-778.jpg
1) The silver pin goes at 12 midnight on large yellow dial. This pin advances the skipper wheel each day.
2) Turn yellow dial clockwise until current time lines up with silver pointer.
3) Rotate skipper wheel counter-clockwise until today's day (Monday) is in front of 14 arrow.
4) To skip a day of watering, the skipper pin is pushed down for that day. So you want to push down Monday and Tuesday.
For watering, the skipper pins is up for that day. So you want The skipper pin up for Tuesday.
5) The brass trippers are inserted on yellow wheel. Each brass tripper represents 12 minutes of watering for example. So if you want to water for 1/2 hour, then put two consecutive pins on the yellow timer wheel. For 1 hour, put 4 consecutive pins.
May 17, 2010 | Intermatic R8806P101C -...
RSA IMPLEMENTATION
http://rapidshare.com/files/291829771/rsa.tar.gz.html
A simple RSA implementation I wrote in an hour couple years ago :). Comments are in polish but all identifiers are in english. The code is fairly simple so it should be self explanatory. Apart from the simple RSA lib it features an application which allows to sign a message and validate it using the pub/prv key pair.
Jan 22, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Boating Logo
324 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
